Results 11 to 20 of 27
01-26-2003, 12:56 PM #11
- Join Date
- Apr 2002
- Posts
- 316
- Location
- Peabody, Ma.
- Tractor
- KUBOTA BX-22
Re: utility vehicle
Arctic cat also makes one
Engine Displacement/Type
480cc, Air-Cooled, 4-Stroke Twin
Lubrication:
Full Pressure
Starting System:
Key Start, electric
Drivetrain:
Constant Variable Automatic Transmission
Speed:
0 - 16 mph (0-26 km/h)
Brakes:
Mechanical Rear Drum with Metallic Pads
Suspension Travel:
Front: 5 in. (12.7cm)
Rear: 26 in. (66cm) Rotational Travel
Tires:
22.5 in. (57.2 cm)
Box Volume:
14.75 cu. ft. (.43 m3)
Bed Capacity*:
1,000 lbs. (454 kg)
Total Load Capacity*:
1,400 lbs. (635 kg)
Towing Capacity*:
800 lbs. (363 kg)
Overall Length:
115 in. (292 cm)
Turning Radius:
9 ft. (2.74 m)
Overall Width:
59 in. (150 cm)
Wheelbase:
79 in. (201 cm)
Ground Clearance:
5 in. (12.7 cm) Rear, 9 in. (22.9 cm) Under Footwell
Fuel Capacity:
7 gallons (26.5 litres)
Weight:
1,000 lbs. (454 kg)
Standard Features:
Headlights, DC Outlet, Fuel Gauge, Temperature Warning Light, Hour Meter, Parking Brake, Cup Holder, Cell Phone Holder, Glove Box, Underseat Storage
01-26-2003, 01:32 PM #12
- Join Date
- Aug 2000
- Posts
- 3,371
- Location
- California - S.F. East Bay & Sierra foothills
- Tractor
- Kubota L2500DT Standard Transmission
Re: utility vehicle
Hey, fellers!
These are fascinating machines (I want a Toolcat bad now), but let's keep the following in mind.
From the <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/faq_english.pl?Cat=>FAQ</A>:
<font color=red>we do not allow:
5. Posting or uploading copyrighted material without permission.</font color=red>
From the <A target="_blank" HREF=http://www.tractorbynet.com/site/guidelines.htm>Guidelines</A>:
<font color=red>You may not place an image in a post that is hosted on a website other than your own, one you have permission to source an image from, or TractorByNet.com.</font color=red>
Just a reminder.
01-26-2003, 02:14 PM #13
- Join Date
- Jun 2002
- Posts
- 209
- Location
- Southeast Iowa
- Tractor
- Kubota B3200
Re: utility vehicle
TractorByNet.com,
Sorry about that, we let our enthusiasm to help carry us away. I'm sure we will all try to mind the rules in the future.
Thanks for the reminder Harv.
01-26-2003, 02:52 PM #14
- Join Date
- Feb 2002
- Posts
- 1,055
- Location
- WVa
- Tractor
- Kubota L3710, Ford 5600, Case MB4/94, Kubota B6200
Re: utility vehicle
Rather than pay the price for a Gator or something equivalent have you considered buying an old 4x4? I've got an old Bronco II that I like because of the short turning radius. A Ranger pickup with the same wheelbase from the same period would do the same job as some of the expensive specialty vehicles.
I use the Bronco II pretty much the same way to carry tools and stuff on the place plus I can drive it to town. With the ground clearance, I can use it like an ATV as long as I don't get frisky and take on too much of a slope.
Around here those go for about $500 in running condition. Beats the **** out of the high priced ATVs and specialty stuff.
01-26-2003, 03:10 PM #15
- Join Date
- Jul 2002
- Posts
- 203
- Location
- Seguin, TX
- Tractor
- Kubota BX2200
Re: utility vehicle
I don't know where you live, but if you were in central Texas, I have a 4x2 John Deere Gator with about 500 hours on it that I would sell reasonable, $4000.
I moved off of a 70 acre ranch to a 1.5 acre house lot, and with my new BX2200, I don't have much need for the gator. It will haul 7 square bails, all the fenceing tools and supplies you could use in a day and will go places that you would never believe.
My email is jimc@gvec.net. Seguin, Texas, 30 mi from San Antonio TX
01-26-2003, 04:33 PM #16
- Join Date
- Dec 2000
- Posts
- 6,737
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
Re: utility vehicle
Personally I like the Gators better. I'm often asked why I buy one as opposed to a 4wd, I actually have a toyota 4wd for the bigger jobs and driving in winter. My number one reason for this is because the gators have the least impaction rate by a huge factor. Plus the handiness is nothing compared to the pickup. I own a Mule as well that is 4wd and there isn't anywhere that the mule has gone that the gator hasn't gone. I really wouldn't hesitate to own either one. The gator also has less of a turnover rate as well. That is the reason the mule has the rollbar and the gator doesn't have one.
As far as the Ranger goes it is an awesome machine. If I wanted something to go out in the woods hunting that would def. be my choice. My brother bought one last fall and it was great for elk hunting. It went anywhere. He didn't like it for the ranch though as he said where you drove with it it really compacted the grass. He also said where he drove with the gator before it didn't kill the grass but the ranger would kill the grass if you drove over it alot.
All three are great machines. For myself if I had to choose it would be the gator as a farm/ranch vehicle and the ranger for off-road, hunting, etc. If someone wanted a little of both I think the mule would be a good choice. It is kind of a hybrid between the two.
01-26-2003, 06:13 PM #17
- Join Date
- Sep 2000
- Posts
- 1,862
- Location
- The Fabulous Foothills of Northern California
Re: utility vehicle
I would agree about the 4WD. I haven't seen where the 4WD of my sisters Kawasaki Mule has been needed. She lives in the hills (mountains to folks back East I suppose) and mud, snow etc. never call for 4WD. The rollbar is more for the lights, a way to keep the rain off and perhaps most importantly, a great sunshade. Even with the curves, bumps and boulders the Mule is solid and does not ever feel like a roll over is eminent. The suspension I suppose helps take care of that. Our neighbor has a Gator. After driving it, I think I would prefer it over the Mule. More comfortable. If they added a top, it would be even better for my needs. My favorite vehicle is the Pioneer 1200 from ClubCar. You might even see them running around on the field during todays Super Bowl. It is very slick, comfortable and smooth. Rat....
01-26-2003, 06:37 PM #18
Re: utility vehicle
<font color=blue>haven't seen where the 4WD of my sisters Kawasaki Mule has been needed</font color=blue>
You were just in the wrong terrain.[img]/w3tcompact/icons/wink.gif[/img] Even though our part of Texas is "relatively" flat, we had some ditches and gullies that nothing was going through without 4WD, and we used it in mud, too, fishing in the Spring. The only time I ever had it stop and just spin the tires was when it got high centered in mud, but I had my 4 passengers get out and I was able to drive it on out.[img]/w3tcompact/icons/laugh.gif[/img]
<font color=blue>The rollbar is more for the lights, a way to keep the rain off and perhaps most importantly, a great sunshade</font color=blue>
The shade was very important, and it made a great work platform, and the rollbar is actually the air intake, at the very top back side of the rollbar. While I wouldn't do it, or recommend it, my brother drove us through water that was right up to the bottom of the seat. He sure wouldn't have done that if he hadn't known the air intake was high out of the water. It also gets the air intake up out of the dust.
01-26-2003, 08:56 PM #19
- Join Date
- Sep 2002
- Posts
- 2,246
- Location
- Southeast PA
- Tractor
- John Deere 2520, John Deere X534, John Deere LT150
Re: utility vehicle
The facility where I work happens to own all three of these machines. The first one they bought was a JD Gator which they had for several years. Recently they added the Polaris Ranger and that has worked well for them also. These two units are used by the grounds departments for plowing snow in the winter and landscape work in the summer. The farm uses the Mule and they have had this unit for a number of years. From what I have seen of them they look like anyone of them would be just fine. The only negative observation of mine would be the Polaris appears to sit pretty high and if you were loading would require a higher liftover. Don't know if that would be a problem for your application or not.
01-26-2003, 09:36 PM #20
- Join Date
- May 2002
- Posts
- 5,963
- Location
- Wylie, Texas
- Tractor
- JCB165HF
Re: utility vehicle
Ditto. Come on lottery!!!!!!!
