Page 4 of 12 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 111
  1. #31
    Gold Member AGGIE00's Avatar
    Join Date
    May 2010
    Posts
    473
    Default Re: Deere 5083E limited VS. Kubota M8540
    Quote Originally Posted by RedNeckRacin View Post
    AGGIE00- do you have your tires ballasted and front weights? I got all 4 of mine loaded with beet juice and I have 400lbs of front weights. Call me crazy but I think that should be enough, if not, I can always get more weights, or run with the loader on.
    I have a loader which is plenty, but ballast on the front of the tractor is not the issue even when the loader is off. I feel the 3pt is straining especially when roading. It handles the mx8, but for me I wouldn't consider the mx10 for a 3pt with this tractor. Having said that, I haven't tried it and could be wrong.
    MY2012 John Deere 5083e-563 FEL, 2008 CAT 272C with 60" Bradco Mulching Head
  2. #32
    Gold Member
    Join Date
    Jan 2008
    Posts
    363
    Western PA
    John Deere 5083E MWFD, Kubota L3400 HST
    so your saying that it lifts pretty slow?
  3. #33
    Gold Member
    Join Date
    Jan 2008
    Posts
    363
    Western PA
    okay so first impressions after some serious mowing today (4 hours), the 5083 handles the MX10 with no problems. I have more than enough power to run the hog until the grass gets over the back tires which i just dropped a gear and it was fine. I can definately tell its back there if I try and do some quick manuvering but other than that its mostly getting used to a tractor with a nice cab on it. I can hear every noise that used to be drowned out by the roar of the engine. My draft knob rattles like crazy but i think a plastic washer or something simple would fix it. The hydraulics have more than enough power to lift it clear off the ground and it evens drives decent with it up. Now I did have the loader on but even so I'm very happy with my decision to get the big mower. Now I just have to quit leveling the fields and start mowing them!
  4. #34
    Gold Member
    Join Date
    Oct 2007
    Posts
    340
    North Central Mississippi
    JD 4320
    is your mx10 pull behind or 3ph?
  5. #35
    Gold Member
    Join Date
    Jan 2008
    Posts
    363
    Western PA
    full mount 3ph.
  6. #36
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,665
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    We used a Woods 121 10' 3PH for a lot of years with a Case CX80 and it was very manageable though you could sure feel the weight. We needed a heavier duty cutter and went with a pull type due to the extra weight.
    If your tractor will handle the weight of a 3PH 10', they are nice. We have found our tractor "feels" more stable on steep slopes with a pull type though.
  7. #37
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,026
    texas
    kubota M7040 &m7040
    I only have the Kubota MDeere 5083E limited VS. Kubota M8540-shredding2.jpg7040 and pull a Woods DS1440(12ft)all day! Both tractors are nice!!!
  8. #38
    Join Date
    Mar 2009
    Posts
    13,665
    Missouri
    Quote Originally Posted by foreman Etexas View Post
    I only have the Kubota MClick image for larger version.
ID:	2221267040 and pull a Woods DS1440(12ft)all day! Both tractors are nice!!!
    Is yours a pull type or semi-mount?
  9. #39
    Join Date
    Jul 2011
    Posts
    2,026
    texas
    kubota M7040 &m7040
    Quote Originally Posted by TripleR View Post
    Pull-type
    Once you go pull-type you never go back!
    Attached Thumbnails Attached Thumbnails Deere 5083E limited VS. Kubota M8540-shredding3.jpg
  10. #40
    Join Date
    Mar 2009
    Posts
    13,665
    Missouri
    Pull-type
    We sure like ours.
Similar Threads
  1. Buying Advice Kubota compared to John Deere
    By rarvesen in forum Kubota Buying/Pricing
    Last Post: 06-10-2011, 09:43 PM
  2. Buying Advice John Deere compared to Kubota
    By rarvesen in forum John Deere Buying/Pricing
    Last Post: 03-21-2011, 04:14 PM
  3. deere 2720 vs kubota 2630
    By ipwanab in forum Kubota Owning/Operating
    Last Post: 03-28-2010, 06:52 PM
  4. JD855 = YANMAR what?
    By JD855 in forum Parts/Repairs
    Last Post: 01-13-2010, 01:18 AM
  5. John Deere Warranty
    By Big8 in forum John Deere Buying/Pricing
    Last Post: 04-18-2005, 07:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
