Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    May 2011
    Posts
    7
    Cedar Crest, NM
    Int'l 441, Farmall Cub, David B rown Tractor,Ferguson 8N, Ford 550 backhoe n Ford 8N
    Default MF Backhoe
    So, I've listened to your advice on buying an American made backhoe in the 5K range. that I shouldnt have to travel hundreds of miles. I found a 1975 Massey Ferg M50A with instant reverse for 5K! It does need a front pump or clutch, as it runs in reverse, but he uses the backhoe to push it into the pile to load the bucket. I'm trying to get him to pay for the repair.
    It has an odd looking hydraulic unit that operates the hoe swing operation. It kind of looks like a small keg. It's round and has the hydraulic hoses coming off of it. Is this something anyone's familiar with? Any idea if parts are available if it need service? It seems to work fine now, but it does show leakage.
    Attached Thumbnails Attached Thumbnails MF Backhoe-mf-hoe-1-jpg
  2. #2
    Join Date
    Aug 2008
    Posts
    151
    NE
    Default Re: MF Backhoe
    I'm guessing without firsthand knowledge of the unit, but it appears to be a hydraulic motor-brake-planetary drive unit. These units are used to rotate the turntables or turrets of cranes, and other boom type equipment.
  3. #3
    New Member
    Join Date
    May 2011
    Posts
    7
    Cedar Crest, NM
    Does it look like something parts may still be available for? I'm more used to straight hydraulic cylinders. Kinda makes me want to shy away from this machine.
  4. #4
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,757
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    In talking with older guys in the trade I was told in the old stuff to stick with JD/Case options. We like our old 1983 JD 310B. Another member just bought a 480 Case with only 2800 hours and stored inside all of its life for $8K. I would look a little harder and buy only if it is in working order. Buying one that is down would have to be very very cheap to get my interest.
  5. #5
    Veteran Member jlsmith's Avatar
    Join Date
    Aug 2010
    Posts
    1,263
    Murchison, Tx.
    MF 285 Long 560 MF2670 CX100
    Those machines were verry good and yes parts r still available. I have a customer that has 3 of them and he works them everday. I would however try to get him to come off the price some with the problems u stated
  6. #6
    Member
    Join Date
    Aug 2012
    Posts
    28
    New Glasgow,NS
    1975 Massey Ferguson 50A 2008 Kioti CK20s HST, 2012 B2630 w BH77
    I just bought the exact same machine as the one pictured did you end up buying it? I am rebuilding the dipper stick cylinder (the one with the external rod showing) does any one know if it is just the o rings that hold the rod in place or is there a spacer behind the plug?
Similar Threads
  1. Backhoe MF 50A Backhoe Barrel Cylinder
    By kpmcneil in forum Massey Ferguson Owning/Operating
    Last Post: 05-25-2011, 08:49 PM
  2. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 04:12 PM
  3. mf 860 backhoe gear problem
    By aviek in forum Parts/Repairs
    Last Post: 02-06-2009, 04:40 AM
  4. Backhoe & Power Beyond Question
    By R_squared in forum Hydraulics
    Last Post: 09-28-2008, 01:44 PM
  5. Backhoe MF 1020 backhoe compatibility question
    By kirkl57 in forum Attachments
    Last Post: 09-19-2008, 10:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
