Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Default Re: What is a 'remote valve' and why do I want one?
    Quote Originally Posted by grsthegreat View Post
    ah nope. While looking at 40-50 HP tractors, i found that JD and Kubots offered them as extras ONLY. not sure why....all tractors SHOULD come with at least 1 rear remote, but they dont. and its a $900 - 1250 extra to add. Their LARGE farm tractors all had them as standard though
    That's why they are extra cost items...mo' money for the company.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  2. #12
    Veteran Member Rockgod's Avatar
    Join Date
    Oct 2010
    Posts
    1,396
    CNY
    JD Cabbed 3720
    Quote Originally Posted by jdbnh View Post
    usually unless you are in the compact size tractor, most of the tractors come with one standard
    The MF 16xx's series come with one set of rear remotes standard. Other CUT in the same size range do not
    JD 3720 Premium Cab, 300CX, 59" Front Mt. Blower, 72d MMM auto-connect deck.
  3. #13
    Gold Member
    Join Date
    Apr 2010
    Posts
    347
    Waynesfield, OH
    Kubota B2920
    seems like I saw them installed on a CUT to work the chute rotation and elevation on a 3 PH snowblower....just another reason to have them, I guess.
    B2920/FEL/BH
  4. #14
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by LMan1967 View Post
    ...and yes, I have "The Book" and its not in there
    Here are the triple hydraulic remotes on my 2008 Mahindra 5525
    What is a 'remote valve' and why do I want one?-dscf0066-small-jpgWhat is a 'remote valve' and why do I want one?-dscf0067-small-jpg
    These auxiliary ports are used to operate implements that require hydraulic power (e.g. hydraulic motors on post hole diggers, hydraulic cylinders (rams) on a variety of equipment). For example, my wheel disc has a large hydraulic ram to raise and lower the transport wheels
    What is a 'remote valve' and why do I want one?-dscf0132-small-jpgWhat is a 'remote valve' and why do I want one?-dscf0133-small-jpg
    Dealer installed remotes generally cost $500-800 per unit (including the hydraulic control valve, hoses, hydraulic quick disconnects). I was lucky. When I bought my new 5525 in 2008, the dealer installed the triple remotes for $750--couldn't pass up that deal.
    Hope this info helps.
  5. #15
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    Flusher:
    Your rig shows the benefits of flat top fenders.
  6. #16
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Quote Originally Posted by mjncad View Post
    Flusher:
    Yep--makes the installation job a lot easier.
  7. #17
    Veteran Member jake98's Avatar
    Join Date
    Nov 2007
    Posts
    1,914
    Dingmans Ferry PA
    53 Cub, 70's JD 410, Kioti 25hst
    Flusher:
    But that's the problem with places to put stuff, they always get filled up..
    Kioti's come (mine did anyway..) without the valves, but with the location for them. I think it cost me about 550 to have the dual remotes installed.
    Kioti CK 25 Hydro: box blade, brush hog, rake, roto-till, grapple, bucket forks, de-stump cyl, Wallenstein Chipper
    John Deere 410 Backhoe Loader: 25 hoses ready to blow
    Thus by the beneficence of Providence, we shall behold our empire arising, founded on justice and the voluntary consent of the people, and giving full scope to the exercise of those faculties and rights which most ennoble our species.
    Samuel Adams
  8. #18
    Member
    Join Date
    May 2011
    Posts
    48
    Ft. Bragg, Ca.
    Kubota B3200
    Here, the local kubota dealer wants $2,000 for the set-up and no implements. I think that it is a little steep so I'm looking to buy and install myself with sons help. Just need to know where to locate source. Any suggestions?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
