Results 21 to 23 of 23
06-05-2011, 10:26 AM #21Super Member
- Join Date
- Jun 2005
- Posts
- 5,684
- Location
- Northern California-Tehama Co.
- Tractor
- 2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
Re: looking for best equipment to clean a mountain
That LX at 49hp would be OK for cleaning up the loose stuff laying around on the ground. But cleaning 90+ acres is going to take a lot of seat time.
How about stumps? I assume the loggers left you a whole mess of them. Are you planning to leave them or dig them out?
Have you considered construction equipment--my neighbor uses an old Cat D7 for leveling irrigated alfalfa fields. Something like that (with a bulldozer blade) would make the job go a lot faster
Your steep terrain is a safety problem with a tractor like the LX which is a general purpose utility tractor more suited to flat/moderately sloped topography. These tractors are not mountain goats. So be careful. Don't know how steep is steep in your case, but I'd consider some type of modified tractor set up for steep slopes--like my 1964 Massey Ferguson 135 diesel which has been modified to squat low for work in the olive orchards around my place.
This 135 is a field tractor modified by switching from 28" diameter rear rims to 16" diameter rims to handle those wide 18.6-16A tires and installing shorter spindles on the front axle to keep the tractor level.
Whatever you decide, be careful out there.
06-07-2011, 01:21 AM #22Elite Member
- Join Date
- Oct 2004
- Posts
- 4,860
- Location
- Kasilof, Alaska
- Tractor
- JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
I know this is a forum about tractors... and you want to buy a mid-sized utility type tractor with possibly a backhoe and HD brush hog mower.
I get it...
That said; I've been clearing timber these past 4-5 years on my 20 acres using a JD 110TLB with hyd thumb. I started out with a smaller (33hp) JD 970TLB. Trees, stumps, logs and brush are murder on tractors!
Ever take a good look at USED logging equipment...
It's a slow hoe to row, too! Better be looking over your retirement investments -- if you're gonna get it all done with a 50hp< tractor!
I'm with the buy a piece or two of heavy equipment crowd! Especially an excavator with blade and thumb! If you're only gonna buy one piece of equipment - get the hoe before a dozer - IMO.
There... I said it - and I feel better, already!
Good luck with your decision.
AKfish"Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
02-11-2013, 11:01 AM #23New Member
- Join Date
- May 2011
- Posts
- 4
- Tractor
- Cub Volunteer w/Kolpin 3pt hitch
Wow, excellent forum gize! thanks for all the experience. To answer some of the questions:
- It is very steep, so I hear the advice about tractors on mountains. I'm thinking bulldozer.
- No I will not clear all 96 acres. just the flat areas at the bottom and the top. But to get to the top I have to clear a lot of logging trails. sounds like a dozer job, and ongoing dozer maintenance also.
- There are loggers in the "neighborhood" so hiring out a few weeks sounds like a great way to start. They work the land around here, so they should do a good job. And its neighborly to hire them.
- shop around. bigger is better. got it.
thanks again!
Similar Threads
New Bobcat Construction Equipment Forum
By Muhammad in forum Construction EquipmentReplies: 7Last Post: 04-10-2013, 04:13 PM -
McGee Farm Equipment - McCormick Dealer
By Muhammad in forum McCormickReplies: 5Last Post: 06-28-2012, 06:03 PM -
Equipment Needed to Renovate Pastures
By Billy_S in forum Owning/OperatingReplies: 27Last Post: 05-31-2011, 09:03 PM -
Townline Equipment...
By Thomas in forum Related TopicsReplies: 0Last Post: 04-14-2007, 03:51 PM -
Mountain v Regular -- Goats
By Mith in forum Related TopicsReplies: 1Last Post: 08-01-2005, 07:27 AM
