Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. #21
    Veteran Member MESSMAKER's Avatar
    Join Date
    May 2009
    Posts
    1,649
    Bluegrass,KY
    Bobcat ct 225
    Default Re: 4wd garden tractors
    I understand if you want to buy something new, but Your Cub Cadet with filled tires(fluid) and wheel weights should take you most anywhere. Lug or atv tires will make it nearly unstoppable.
  2. #22
    New Member Taftag's Avatar
    Join Date
    Aug 2011
    Posts
    10
    Millis, MA
    2012 Kubota GR2021
    Default
    Ive never heard of filling tires with fluid. How does that work?
  3. #23
    Elite Member Gittyup's Avatar
    Join Date
    Oct 2007
    Posts
    3,143
    Mid Atlantic
    Kioti CK25 Shuttle Shift, loaded tires, JD X739
    An x749/x749 with AWS will be way more stable than a bx. Lower center of gravity. Drive wheels always facing drive direction. Wider stance. Add OEM spacers to the rear and I doubt you could turn it over. You'd fall out of the seat first. The best mowing tractor you can buy. BX's are nice little do-it-all machines, but they wouldn't perform as well for the OP's problem.
  4. #24
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by MESSMAKER View Post
    I used a cub cadet 129 garden tractor with ATV tires and they were fluid filled up until I got my BX1500 which is 4WD. The old and I mean old cub cadet was made in 1973 and it was a real quality machine. Set up with the ATV tires that were fluid filled it was a tank but not like the 4WD.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  5. #25
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Quote Originally Posted by Taftag View Post
    It is a common practice to fill the rear and sometimes front tires with fluid for weight. There are several fluids you can use but most people now days use windshield washer fluid or a glycol mix.
    There are some fluids made from beet juice that are heavier than glycol based fluids. The old way was to mix a fluid out of calcium and water but it is corrosive and would eat rims in a hurry if allowed to stay in contact with metal.
    Tires are usually filled to slightly above the height of the rim leaving a bit of an air space for cushioning. The fluid is pumped in through the valve stem.
    The fluid adds weight to the tractor below the center of gravity and helps to keep it from turning over.
    Randall
    1Timothy Chapter 2:
  6. #26
    Veteran Member scoutcub's Avatar
    Join Date
    Aug 2008
    Posts
    2,368
    Ohio
    Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
    The jd 749is what i was thinking about but its expensive. However it would probably seem less expensive if i hadnt blown a few grand already on my cub ztt 46" with bagger. The jd dealer said blue book on it would be about $1k but i dont't know how to check that. Also wold consider buying used but nobody seems to want to get rid of those 749's in any of the used places ive seem online
    Taft - Seems like I've misread your equipment - thought you own a typical zero-turn mower, but I now see it's a ZTT. I'm quite surprised it's giving you issues on slopes, mine is very stable on side slopes. Perhaps you have REALLY steep slopes! I've never tipped mine over, but I'm leaning so far on in the seat the safety switch is activated a few times..... and, before I had thick grass the whole tractor would slide sideways down the slope, so I would have to turn into the slide and drive out of it.
    In your particular situation, you could try the fluid filled tires, but something like the X749 might suit you better, they are nice machines. Any pics of your slopes?
    Good luck!
  7. #27
    Silver Member skspurling's Avatar
    Join Date
    Mar 2011
    Posts
    249
    Missouri
    Kubota B2620
    Default
    I have 2 mowable acres with fairly steep side hill/ down hill areas. I bought a cub cadet zero turn tractor 3 yrs ago and have regretted it because it cant handle the hills well and i get scuffs. Thinking about replacing it. Looking for suggestions and if a trade in might be an option because i'm into the cub cadet for over $4k with attachments
    I have the same mower. Ditch the bagger and use the mulch plug. If your clutch isn't adjusted properly, you don't get full power to both drive wheels. Do a search. I paid 25 bucks for a pdf shop manual to figure out something that should have been in the owners manual. When the clutch is released, the pin on the end of the clutch rod should be in the middle of the slot on the idler arm. If it isn't one wheel pulls and ends up scuffing trying to compensate, and it becomes weak on hills it normally pulls like a mule. I figured that out last winter when i was pushing snow... then snowpocolipse occured and i bought a kubota b2620. Anything above 8 inches was too much for the little tractor. LOL!!!
  8. #28
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I agree with the others to try all the simple less expensive fixes first such as hdap tires, wheel weights or fluid and adjustment of control levers to specs.
    About the x749,
    I really like the hdap tires as they have great traction without damaging the lawn. I do have 3pt a boxblade, rearblade, landscape rake, pine needle rake, chipper and other tow type spreaders and carts so far it has done a good job handling all of these implements. The thing that sold me on this model was the tight turning radius with all four wheels engaged and the variable hydraulic front wheel drive axle, much less scuffing if all the wheels are pulling at the right speeds. For lawn work I felt this is better than mfwd.
    Most of my uses for the x749 is to perform cleanup in tight places where the larger compact tractors won't fit, so far it has performed admirably. Backing implements such as rakes between trees is much easier with the 4 wheel steer and is something that comes up all the time for me.
    The BX series Kubotas' are good garden tractors as well and a better comparision would be the kubota BX2360 or BX2660 to a Deere x748. The x749 with all wheel steer is quite different from any of these in handling. If you compare the prices I don't see much difference when comparing apples to apples.
  9. #29
    Elite Member
    Join Date
    Jan 2010
    Posts
    2,537
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    Did not aim to launch a product A vs. product B debate by mentioning the BX. The X749 may be John Deere's rendition of the world's finest lawn mower, but there is other equipment out there that would also be a big improvement over his current setup, including the BX. Considering no one else has seen Taftag's place or knows his specific work requirements, it may - or may not - be that a different product would serve him better. Being that we are all eminently sensible, reasonable people, I'm sure we'd all want the OP to consider all the options.
  10. #30
    Join Date
    Aug 2011
    Posts
    10
    Millis, MA
    2012 Kubota GR2021
    Here are some pics that I brought with me when I bought my ZTT1046 in 2008.
    Attached Thumbnails Attached Thumbnails 4wd garden tractors-img_0064-jpg   4wd garden tractors-img_0066-jpg   4wd garden tractors-img_0063-jpg   4wd garden tractors-img_0069-jpg
Similar Threads
  1. Craftsman Garden Tractors ("THOUGHTS ONLY")
    By machmeter62 in forum Parts/Repairs
    Last Post: 09-20-2016, 08:27 AM
  2. Mahindra 35 series
    By JerryTSummers in forum Mahindra Buying/Pricing
    Last Post: 07-18-2009, 03:36 AM
  3. Your favorite lawn and garden tractors Past and Present
    By Fordlords in forum General Lawn & Garden
    Last Post: 08-25-2006, 06:04 PM
  4. need dealer with used garden tractors
    By rbig in forum General Lawn & Garden
    Last Post: 06-19-2006, 12:39 PM
  5. Advice on Garden / Compact Tractors
    By baray in forum Buying/Pricing/Comparisons
    Last Post: 04-09-2005, 07:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
