Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 44
  1. #1
    New Member Taftag's Avatar
    Join Date
    Aug 2011
    Posts
    10
    Millis, MA
    2012 Kubota GR2021
    Default 4wd garden tractors
    I have 2 mowable acres with fairly steep side hill/ down hill areas. I bought a cub cadet zero turn tractor 3 yrs ago and have regretted it because it cant handle the hills well and i get scuffs. Thinking about replacing it. Looking for suggestions and if a trade in might be an option because i'm into the cub cadet for over $4k with attachments
  2. #2
    Administrator Muhammad's Avatar
    Join Date
    Mar 1998
    Posts
    16,129
    San Diego, CA
    None currently
    Default
    Welcome to TBN.
    Muhammad Chishti
    Administrator
  3. #3
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,297
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Default Re: 4wd garden tractors
    Deere has (or had...I don't follow the lawn tractor market) a couple AWD models (not zero-turn machines though).
    Before you trade off....can you mow up and down slope? Think that would reduce the slippage and scuffing? Maybe a more aggressive tire tread? Or, filling your tires (probably not much weight can be added due to their size) or weights to increase traction?
    I suggest you investigate these options before seriously considering a trade. You'd likely take a pretty good hit on any trade at this point in time.
    Welcome to TBN!!
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  4. #4
    Join Date
    Aug 2011
    Posts
    10
    Millis, MA
    2012 Kubota GR2021
    There is no way I could possibly go sideways without flipping in a couple places so I do go up and down, but a little bit on an angle because there is also a steep side hill in the middle due to a 12 ft underground wall from when the septic system was upgraded before I bought the property. I've also got a huge bed on the steepest part of the hill that I need to drive around and half of it is under pine trees where I have to make the turn at the top and its always a scary moment. I also have a cyclone raking system that I inherited from the prior owner, but can't use it in the front because its not powerful enough to pull the weight.
  5. #5
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Sounds like you are on the same path that I was on. I bought a ZTR and tried to mow my hills and that didn't work out so well as you have described. I ended up getting a BX1500 with a 54" deck and that is the tool for the job.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  6. #6
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    I have similar problems, i.e., I have to trim around trees on a 20 degree slope. I want a Simplicity 4WD lawn tractor for this, but another 12 grand on top of the price of my compact tractor is something I just can't bring myself to do. Guess I could look for a used one...
    Until then, I'll just keep using with old JD 185 with rear weights to help with traction.
    Attached Thumbnails Attached Thumbnails 4wd garden tractors-nv43802_1-jpg
    Runner
  7. #7
    Elite Member Briana03's Avatar
    Join Date
    Jul 2010
    Posts
    3,292
    San Diego, California
    None
    Hello & WELCOME to TBN!
    I moved your thread to the Buying/Pricing/Comparisons Forum.
    Briana
    TBN Support
  8. #8
    Veteran Member Wolfy's Avatar
    Join Date
    Apr 2011
    Posts
    1,152
    a small town
    Ford 1710 & 1600, Kubota G6200, Simplicty 2010, Allis Chalmers B110, Montgomery Wards Squire 9, John Deere 214
    I mow a few steep hills. Cast iron wheel weights and R-1 tires will make a giant difference. Lower the rear tire air pressure as much as you feel comfortable with. Also, if you can, drive up the steepest hills and go down the shallower hills. There really isnt a safe way to go down a steep hill.
  9. #9
    Join Date
    Aug 2011
    Posts
    10
    Millis, MA
    2012 Kubota GR2021
    Default
    What is involved with wheel weights in terms of installation and cost? It might be worth a try but i dont want to throw good money after bad
  10. #10
    Join Date
    Jan 2010
    Posts
    2,484
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    Several companies make some pretty neat equipment for mowing on hills and slopes. For example, kubota has a 4wd ztr-type mower (The "F" series), and you should also check out Ventrac and Steiner.
    Those units are commercial type equipment, so unfortunately they are pretty pricey. A good used unit might be more affordable yet still have years of useful life. The trick would be finding one. Ebay, Craig's, dealers, on-line equipment traders, etc.
Similar Threads
  1. Craftsman Garden Tractors ("THOUGHTS ONLY")
    By machmeter62 in forum Parts/Repairs
    Last Post: 09-20-2016, 09:27 AM
  2. Mahindra 35 series
    By JerryTSummers in forum Mahindra Buying/Pricing
    Last Post: 07-18-2009, 04:36 AM
  3. Your favorite lawn and garden tractors Past and Present
    By Fordlords in forum General Lawn & Garden
    Last Post: 08-25-2006, 07:04 PM
  4. need dealer with used garden tractors
    By rbig in forum General Lawn & Garden
    Last Post: 06-19-2006, 01:39 PM
  5. Advice on Garden / Compact Tractors
    By baray in forum Buying/Pricing/Comparisons
    Last Post: 04-09-2005, 08:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
