Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Veteran Member big bubba's Avatar
    Join Date
    Mar 2007
    Posts
    1,333
    arkansas
    m8540
    Default Re: What Bush Hog would you buy?
    nice equip, but the predator 8' lift 3ph is way too much for the OP tractor in question. otherwise, lots of good options out there....
  2. #22
    Member melanelly's Avatar
    Join Date
    Apr 2011
    Posts
    32
    Good old Franklin, GA
    Massey 1533 w/FEL
    I have the 5' competitor. Works great with my MF1533. Weighs in at just 608 lbs. Just checked the specs and looks like he could go with the 6' with no problem. http://www.modernusa.com/images/com-pop.pdf
    Melanelly
  3. #23
    Member
    Join Date
    Jul 2006
    Posts
    27
    L4310, M7040, KX161, RTV900, RTV1140
    Wow lots of good info, any opinions on the who has the best clutch / gear box design? I have had to do 2 clutch rebuilds on my Land pride over the years.
  4. #24
    Platinum Member BlacknTan's Avatar
    Join Date
    May 2006
    Posts
    973
    Adirondacks of NY
    Kubota B-7800
    As for gearboxes, I guess it's anyone's guess... There is really no "rocket science" here. A simple right angle drive. The one's with the heaviest input and output (particularly) are probable the most durable.
    The slip clutches are all designed by others, and seem to fall into two basic types. As the HP requirement goes up, so does the number of friction discs in the clutch. The specs on the springs are tighter than one would expect... Only about .060 if memory serves.. I think one would need gage blocks or a decent caliper to set the clutch up properly.
  5. #25
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    I took some pictures of my 2 shredders and you can see why I like the LandPride over my Woods both are the HD models
    Attached Thumbnails Attached Thumbnails What Bush Hog would you buy?-lp3596-jpg   What Bush Hog would you buy?-ds1440-jpg
  6. #26
    Gold Member the6shooter's Avatar
    Join Date
    Dec 2006
    Posts
    455
    oklahoma
    MF 1643
    Modern Ag products, I have the 6' compeditor, made in America 5Yr. on the galvanized deck. heavy deck. the top and sides are more rugged. bought mine this spring, and no dents yet. I have never regreated my purchase. this one should last a good many years of service.
  7. #27
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,205
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    Quote Originally Posted by foreman Etexas View Post
    kubota L4310 Power:
    Engine: 43 hp [32.1 kW]
    PTO (claimed): 38 hp [28.3 kW]
    Im gonna say a 6ft is going to be at the biggest you can go(3pt),just my opinion. . .
    ^What he said. Anything bigger, and you will be overloading your tractor. It will be putting a strain on the hydraulics and will greatly decrease the life of your PTO clutch.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    '18 Kubota RTV-X900
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '01 Peterbilt 379.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
Similar Threads
  1. Rotary Cutter Bush Hog 295 vs Woods BB600X
    By jibron in forum Attachments
    Last Post: 07-28-2011, 02:48 PM
  2. Question, I Match won't lift Bush hog
    By wooden in forum John Deere Owning/Operating
    Last Post: 04-22-2011, 10:12 AM
  3. Bush Hog (Rake) - don't buy, IMHO
    By Jay4200 in forum Attachments
    Last Post: 12-09-2010, 01:54 PM
  4. Bush Hog advice
    By stlawrence in forum Buying/Pricing/Comparisons
    Last Post: 10-12-2010, 12:23 PM
  5. Rotary Cutter Scalping problem 72 bush hog, can i add front wheels?
    By runwme in forum Attachments
    Last Post: 08-09-2007, 10:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
