Results 21 to 30 of 37
08-22-2011, 07:52 PM #21
Advertiser
- Join Date
- Mar 2005
- Posts
- 9,414
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Re: Bobcat CT122 vs CT225/30 and Kioti CK27/30
Gene, DO NOT
get a 60" rear blade for your CK30.
A 60" box blade yes, but not a rear blade. Get at a minimum of a 72" and I would go with an 84" rear blade, as heavy as you can afford which means higher quality and much more $$$$. You want a blade that will do something, not one that will only move loose material.
If you need to do some road building, you should check into getting a good heavy 60"-66" box blade. Around 600-800lbs, that along with the rear blade and you will be set pretty good for working on your roads. Get a land plane grading scraper later on down the road. Great for maintaining a road, not needed for building the roads though.
You should double check about rear remotes also. Sooner or later your going to want 2 of them.
08-22-2011, 09:34 PM #22
- Join Date
- Jan 2011
- Posts
- 263
- Location
- IN
- Tractor
- Kioti CK30, JD X475. HPX Gator, Woodmizer LT10
Boy Mr. Wallace, I had heard you were kind of a jerk, now you just proved it. I'm glad you know everything about tractors. I know a little more than you think I do. Only been in the tractor business for 25 yrs. At least I know now Bobcat has extended through 2016. I won't make that mistake again.
I know about Daedong and who builds what. Sorry I said the wrong thing.
08-23-2011, 12:36 AM #23
- Join Date
- Aug 2011
- Posts
- 30
- Location
- Helena, Montana
- Tractor
- Kioti CK30HST
Bought the tractor today! They had everything but the pallet forks and canopy. Ended up going with a 72" rear blade. with the blade angled it is still wider than the tractor which will be great come winter! I also has tilt and side to side adjustment. I am going to rent a box blade and see how we get along as well as borrow a grader attachment. I am still going to add one of the tooth blade sets from W.R.Long not sure which one. Also looked at their tree spade. Has anyone used one?
Thanks,
Gene
08-23-2011, 08:58 PM #24
- Join Date
- Oct 2007
- Posts
- 3,143
- Location
- Mid Atlantic
- Tractor
- Kioti CK25 Shuttle Shift, loaded tires, JD X739
congrats. Post some photos!
08-23-2011, 10:21 PM #25
- Join Date
- Aug 2011
- Posts
- 30
- Location
- Helena, Montana
- Tractor
- Kioti CK30HST
So here it is! They just started mounting the loader and ordered the goodies!
08-23-2011, 10:35 PM #26
- Join Date
- Dec 2010
- Posts
- 42
Give 'em **** Wallace
08-24-2011, 12:20 AM #27
- Join Date
- Aug 2011
- Posts
- 30
- Location
- Helena, Montana
- Tractor
- Kioti CK30HST
And here is the front yard a couple of little rolls in the hill to get up to the house with a steep gully to the left(west) and steeper behind the house. It isnt the most aggressive topography but probably because the ground is mostly clay and shale. We have a lot of projects to button up before snow flie! New windows in the bottom half and a new section of road to build. plus plowing to prep for and dead trees to gather!
08-24-2011, 07:10 AM #28
Looks good.
Congrats and Welcome to the Pack!Derek
Kioti CK20HST
KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
Sims-Cab Depot heated cab
Originally Posted by DiamondPilot
08-24-2011, 06:45 PM #29
08-24-2011, 06:49 PM #30
Good looking tractor.
Similar Threads
What happens to Bobcat when Kioti contract ends?
By whiskywizard in forum Bobcat TractorsReplies: 49Last Post: 02-21-2011, 10:26 PM -
Kioti or BOBCAT
By kayaker in forum Kioti Buying/PricingReplies: 19Last Post: 02-15-2011, 01:50 PM -
Bobcat CT122 vs Kubota 1816 vs New Holland 1020
By CPTKILLER in forum Buying/Pricing/ComparisonsReplies: 14Last Post: 10-24-2010, 07:48 PM -
Kioti owners - Proud?
By lcisled in forum Kioti Buying/PricingReplies: 39Last Post: 09-30-2005, 10:59 AM -
Is Kioti Viable for the Long Term??
By viking65 in forum Kioti Buying/PricingReplies: 87Last Post: 05-16-2005, 09:41 AM
