Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Sep 2011
    Posts
    2
    Default Tractor size and make up questions
    Need some advice on tractor size. Recently bought 33 acres of which about 20 is pasture, some flat some hilly. Remainder is densely wooded Plan to cut fields, perhaps work toward growing hay. Some perimeters overgrown will require bush hog work and perhaps some stump removal Driveway is about 2000 ft and will need periodic regrading and occasional snow removal. Plan also to build some fencing to protect vegetable garden and prefer not to dig post holes manually
    Thanks for any recommendations about size, make up and/or optimal implements and other questions I should be asking
  2. #2
    Member
    Join Date
    Feb 2011
    Posts
    40
    Default
    I recommend Kubota and 50 hp u can do near anything with this combination. Fel and mfwd are an even better combo.
  3. #3
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    Default Re: Tractor size and make up questions
    You didn't mention a budget How much free time you have or are you in a rush to get things done? Open pasture without any low hanging trees? With regards to haying there are a few threads about that... that you should read.
    TractorByNet.com, WAS next best thing to seat time - not any more.
  4. #4
    New Member
    Join Date
    Sep 2011
    Posts
    2
    Thanks. Minimal overhanging trees. I work full-time so much of this farm work will occur on weekends so....want to be as quick as possible. And, like most, am not interested in paying top dollar.
  5. #5
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,686
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Quote Originally Posted by granierimacpherson View Post
    Tractor: speed=hp, so look for something like this:
    45-60 hp pto, 4WD, power steering, shuttle shift gear tranny, FEL with 6-ft wide bucket. For example, my tractor is a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering, gear tranny 8F/2R, triple hydraulic remote couplings) with the ML250 FEL (6-ft bucket, 2950 lb lift to 10.5 ft height, skid steer quick attach option, 3 chain hooks welded on bucket). Cost: about $19K new. Something like this would handle all your jobs with ease.
    Tractor size and make up questions-dscf0061-small-.jpgTractor size and make up questions-dscf0062-small-.jpgTractor size and make up questions-dscf0066-small-.jpgTractor size and make up questions-dscf0067-small-.jpgTractor size and make up questions-dscf0110-small-.jpg
    The small tractor in the photos is my 2005 Kubota B7510HST (21 hp engine, 17 hp pto, 4WD, hydrostatic tranny) that I traded in as part of the 5525 deal.
    Don't make the mistake of buying a tractor without the FEL. It's the single most useful implement on a tractor and generally is less expensive if bought with the tractor as part of the package.
    Good luck
  6. #6
    Gold Member psj12's Avatar
    Join Date
    Oct 2005
    Posts
    464
    Short OK
    KAMA 554
    I am also a fan of the 50-60 HP models. I would look at the quick attach bucket system and also a 6 way bucket.
  7. #7
    Gold Member dmay's Avatar
    Join Date
    May 2010
    Posts
    440
    Winnipeg, MB
    2010 JD2320
    Need some advice on tractor size. Recently bought 33 acres of which about 20 is pasture, some flat some hilly. Remainder is densely wooded Plan to cut fields, perhaps work toward growing hay. Some perimeters overgrown will require bush hog work and perhaps some stump removal Driveway is about 2000 ft and will need periodic regrading and occasional snow removal. Plan also to build some fencing to protect vegetable garden and prefer not to dig post holes manually.
    What type of livestock will be on your pasture? Do you plan on growing hay to bale and feed? If so what type and size of bales?
    Darrell
    JD2320, 200CX, 53" Bucket, 54" QH SnowBlower, iMatch, Ballast Box, LR1072, RC2048, GM3060, 647 Tiller, SS1023B
  8. #8
    Join Date
    Sep 2011
    Posts
    197
    Maryland
    Ford 1710, Ford 5600, NH Workmaster 55
    We have 35 acres of basically the same type terrain you're talking about. We struggled along with a Ford 1710 4x4 with FEL(23 pto hp) for a few years. Then picked up a 2wd Ford 5600 to mow and post drive (12 foot batwing).
    We just upgraded to a Workmaster 55 4wd (47.5 PTO HP) and are quite excited. Plowing, post removal, tree damage clean up, grading etc will be MUCH faster. A small tractor can do most things, but you pay with time.
  9. #9
    Join Date
    Dec 2005
    Posts
    622
    Central Maine
    Everyone here is right. When you work full time and try to manage acreage, you have to substitute money for time, so bigger is going to be better up to a point of course. I also agree that you are in the 50hp tractor category.
    It really comes down to budget and tractors available in your area. For example, the Kioti DK55 is an excellent choice, especially with a cab. So it the DK50 HSE for example. The NH workmaster 55 is a good solid basic tractor.
    The Kubota Grand L is a good tractor, so are the Massey 1600's and the deere 4000's.
    These are all compact's and you could easily go with a used full size utility as well. NH TN's are excellent and the list goes on. the Ford 3930 was a nice full size utility tractor that would work as well.
    Tell us what you think you have to spend. There are lots of used tractors out there. I tend to favor cabs if you can because you have little time to work and anything to make it nicer can be worth it. For example, late season bushogging when the field is overgrown - the cab is nice because you don't get covered with dust, seed, pollen, or grasshoppers ( yup, gross - I hate the bugs all over me).
    Last year I left 10 acres alone all year and bush hogged in september, I hit two hornets nest that were in the tall grass - cab saved my butt and I kept on mowing.
  10. #10
    Join Date
    Jan 2010
    Posts
    1,866
    Mostly East Central Oklahoma
    JD cut
    I highly recommend that you not wear makeup while operating your tractor. That will attract a highly unusual element of society.
Similar Threads
  1. Two specific questions on a Caroni TM1900 flail mower
    By Z-Michigan in forum Attachments
    Last Post: 10-13-2010, 09:35 PM
  2. Buying Advice Potential PT Buyer Questions
    By PTWannaHave in forum Power Trac
    Last Post: 06-21-2010, 11:29 PM
  3. rotory harrows anyone make one?
    By BHD in forum Build-It Yourself
    Last Post: 06-27-2009, 04:39 AM
  4. Need Ideas On How To Make A Mulching Plate
    By Cabinholler in forum Build-It Yourself
    Last Post: 05-17-2005, 03:03 PM
  5. Someone want to make something for $$ on lathe?
    By Richard in forum Related Topics
    Last Post: 03-06-2004, 08:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
