Results 41 to 50 of 89
12-06-2011, 03:09 PM #41Silver Member
- Join Date
- Oct 2010
- Posts
- 151
- Location
- Santa Cruz, Ca
- Tractor
- BCS735/720 Ford1200
Re: Aurora Silent Diesel Generator
Due to my well being powered from my power pole and not the house, I use a 5kw for the well just to keep the toilets full and when showering and doing dishes. Putting in a larger airtank helps with the bleed down of pressure. I got a 8kw that my FIL bought us when power was out for a couple of days about 7-8 years ago that is still going fine, older Generac I think. I just have to rob the battery out of my mower since it is electric start and don't use it enough to need a second battery. Last weeks wind storm was about the most we've been out of power, 52hrs straight and used less than 15 gallons of gas. I just run a few hrs and shut it off. Also don't forget about your hook up connection so you don't power the entire neighborhood. My old well pump I pulled so many times I now have it on a dryer plug, so it is just plug into the genny and pull the cord. Like wise the house has a DPDT switch that feeds the fridge, freezer and a few lights with a special wall plug and short cord from the generator.
12-06-2011, 04:42 PM #42Gold Member
- Join Date
- Jul 2009
- Posts
- 367
- Location
- Conifer, Colorado
- Tractor
- Kioti DK45SE HST, 401FEL, RB40-96 pivoting Rear Blade
Hey TractorBob,
I was looking for a diesel gen about a year ago and from what I can recall the Aurora silent Gen was also avail under different names for less than the $1600.
I ended up going with ETQ Diesel generator .. I think it's 6kw .. I will admit since I've got it the power has not gone out for more than a few moments .. so I don't have any feedback on prolonged running. I did run it for a full 2 hours when I first got it and then changed oil ... I start it now and then and it still works ... ??
Hope that helps.
Tractor / Gen On.================================================== ===
Kioti DK40SE HST
Our 2nd Amendment RIGHT comes from God and protects all the others!
12-06-2011, 05:16 PM #43Elite Member
- Join Date
- Aug 2008
- Posts
- 3,482
- Location
- N. of Charleston WV
- Tractor
- Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I have about 60 hours on my Aurora diesel generator. The hour meter quit working the last time I used it. Other than that it has run well. I serviced it at 25 hours of run time and I noticed no metal or shavings in the oil when I changed it out at 25 hours. I adjusted the valves at 25 hours and they were not far out of adjustment. The battery has held up well for the 2 years that I have had the generator. I run it for an hour or so every couple of months if there are no power outages.
Randall
1Timothy Chapter 2:
3 For this is good and acceptable in the sight of God our Saviour;
4 Who will have all men to be saved, and to come unto the knowledge of the truth.
5 For there is one God, and one mediator between God and men, the man Christ Jesus.
12-06-2011, 10:04 PM #44
12-06-2011, 10:53 PM #45
dex3361, thanks for the update on that genny. Disregard the message from the other thread.
beefort, I have the same well setup. Its on another power meter.
My well house is about 200ft away from my house...if I have the genny running the house, can I run a line of proper size down to the well. Is the hassle of runnig the line more of hassle of moving the genny.
Really considering the Silent Diesel...Sams Club has one that for $1250...is that about the same as the Aurora?MF 1529 w/FEL Kubota KX121-3 w/Thumb Ford F8000
MF Box Blade, Woods Scrape Blade, KK Rock Rake, LP Land Plane
Walenstien BXM42 Chipper, KK Tiller
Still more to come
12-06-2011, 11:14 PM #46
Bob Rip
Tell me and I will hear.
Show me and I will see.
Let me do and I will learn.
Let me fail and I will understand.
12-06-2011, 11:29 PM #47
The well house has it's own meter, power box, and everything else. I was going to run a line to the breaker box and power the pump that way...if I could.
Still more to come
12-07-2011, 12:48 AM #48Veteran Member
- Join Date
- Mar 2002
- Posts
- 2,189
- Location
- Bahamas
- Tractor
- Yanmars = Fx235- F255- FX335... branson 4220i tlb - hinomoto JF1 New Holland 7610 Branson 3510 tlb
Please get your facts straight.
Our Yanmar 12kw diesel runs at 1800 rpm, its a whisper watt enclosed unit. You can stand next to it and talk while its running. Both 3 ph and single ph.
It runs all day on almost 2 gallons of diesel. Best investment I ever made for the homestead.
12-07-2011, 07:13 AM #49Super Star Member
- Join Date
- Sep 2005
- Posts
- 11,497
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Glad to be corrected regarding 1800 vs 3600 rpm. I was thinking of smaller 6000w genny units.
Originally Posted by tractorErnie
Two gallons a day to run a 12KW genset? Wow. I have owned two Yanmar 3GM marine diesels that would be about the size to run a 12KW generator and at 1800rpm I used about 0.5gal/hr.Last edited by IslandTractor; 12-07-2011 at 07:54 AM.
12-07-2011, 11:00 PM #50Super Member
- Join Date
- Feb 2008
- Posts
- 7,742
- Location
- somewhere usa
- Tractor
- stuff
Similar Threads
Video of a 60 kW diesel generator being overload tested
By sewerzuk in forum Construction EquipmentReplies: 3Last Post: 10-12-2011, 12:46 PM -
NG, Propane, gas or diesel generator??
By Dargo in forum Rural LivingReplies: 59Last Post: 02-02-2009, 01:08 PM -
Chinese diesel generator?
By John White in forum Construction EquipmentReplies: 33Last Post: 10-22-2008, 11:18 AM -
Generator
By Whitey in forum ProjectsReplies: 44Last Post: 10-09-2008, 11:49 AM -
New Low Sulfer Diesel in 2006 -PROBLEMS?
By Bob_Skurka in forum Oil, Fuel & LubricantsReplies: 66Last Post: 01-13-2005, 07:37 AM
