Results 81 to 89 of 89
08-25-2012, 08:27 AM #81
08-25-2012 08:27 AM # ADS
08-25-2012, 08:58 AM #82Gold Member
- Join Date
- Dec 2010
- Posts
- 278
- Tractor
- Massey
Re: Aurora Silent Diesel Generator
Boy's, go back a couple of pages and re-read-try page 7. Wet stacking was why he had to tear apart the engine.
Field magnetism is re-established in milliseconds. You don't need to run it for any duration.
08-25-2012, 09:08 AM #83
Warming up the engine oil and drying out the generator head windings take a lot more time. Basically any mechanism needs to be run under similar conditions to operational use to make sure it works. A loose connection may not show up in a two minute run, but might fail after 20 minutes. I also make sure it will run my house loads at least once a year.
Bob Rip
Tell me and I will hear.
Show me and I will see.
Let me do and I will learn.
Let me fail and I will understand.
08-25-2012, 09:32 AM #84Gold Member
- Join Date
- Dec 2010
- Posts
- 278
- Tractor
- Massey
I agree with your last post. I'm talking about the poster who wet stacked a diesel and now because he doesn't want to tear his engine apart again, went out and bought resistance loads and plans on always keeping it loaded over 50%. My gas genny is stored indoors in a heated area so there is no moisture issues. When I do loose power, I connect it outside and let it rip. Sometimes it's just powering some lights, the t.v., and small motors for the heat system, and that's a very small load. I love that it can just sip some gas during those long days of running. Like I said it would suck to have to worry about keeping it loaded over 50% because you worry about wet stacking. I only have to worry about too much load. It's a double pain to also have to worry about not enough.
08-25-2012, 09:38 AM #85
Bob Rip
08-26-2012, 10:05 AM #86Super Member
- Join Date
- Feb 2008
- Posts
- 7,868
- Location
- somewhere usa
- Tractor
- stuff
If I thought it was necessary to keep the genset loaded with resistance heat strips all the time I would buy a smaller genset instead.
I get a little humored by the guys who need a 50kw genset to get by with power outages. Unless you have a dairy farm or other critical need it might behoove you to learn how to get by with less. Might be good for the rest of the family to learn how to get by with less too.
08-26-2012, 10:53 AM #87Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,753
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
08-26-2012, 12:48 PM #88Gold Member
- Join Date
- Dec 2010
- Posts
- 278
- Tractor
- Massey
I've contemplated getting a small diesel to replace my gas genny, but I think every design has pros/cons, and I'm coming to the conclusion that for small single cylinder air cooled apps, gas is better. I think I'll stay with petrol, for this, but I like the diesel tractor, but that's water cooled, with varing rpm's and load.
Also on a genny which must run when you need it, I can take apart a gas engine and make it work if there was a fuel issue, on the spot during a snow storm. No such luck with diesel injection system.
08-31-2012, 08:08 PM #89Gold Member
- Join Date
- Sep 2008
- Posts
- 399
- Location
- Russell, PA
- Tractor
- BX24
All good now with bells on my toes!: Aurora Silent Diesel Generator
I replaced the injector pump and the generator is purring again! The exhaust runs clear and hot, and the tone of the generator is quite smooth now. I'll let it cool off over night and check the valve clearances in the a.m.
My gas generator has half the capacity of the diesel generator, so I needed a way to monitor the load regardless of which generator was connected to to the ATS. I installed current transformer/meters on L1 and L1 (before the load bank) so that I can see the load and reduce it reliably if necessary.
The CT/meters were 50A, and the maximum that I'd expect for either leg would be 30A (the breaker on the diesel generator). I put a second loop through each CT to set the range to 25A, and relabeled the meter faces for the new range.
I compared deflection between the single and double-loop CTs, and the linearity on the inexpensive meters was quite acceptable. I mechanically adjusted the meters so that the mid-scale reading matched my two other current meters.
Photos attached for your consideration.
Al Yelvington
Russell, PA
Kubota BX-24 & Kubota RTV-900
FEL, BH, chipper, box grader, back blade, ford rake, disc harrow, sub-soiler, mid-soil buster, post hole digger, brush hog, spreader, sprayer, quick hitch, log splitter, block heater and lots of lights!
www.youtube.com/ayelvington
Similar Threads
Video of a 60 kW diesel generator being overload tested
By sewerzuk in forum Construction EquipmentReplies: 3Last Post: 10-12-2011, 12:46 PM -
NG, Propane, gas or diesel generator??
By Dargo in forum Rural LivingReplies: 59Last Post: 02-02-2009, 01:08 PM -
Chinese diesel generator?
By John White in forum Construction EquipmentReplies: 33Last Post: 10-22-2008, 11:18 AM -
Generator
By Whitey in forum ProjectsReplies: 44Last Post: 10-09-2008, 11:49 AM -
New Low Sulfer Diesel in 2006 -PROBLEMS?
By Bob_Skurka in forum Oil, Fuel & LubricantsReplies: 66Last Post: 01-13-2005, 07:37 AM
