Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,718
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Default Re: do not buy too big of tractor!
    Wise move. [img]/forums/images/graemlins/smile.gif[/img]
  2. #22
    Join Date
    Apr 2001
    Posts
    388
    Southern Maryland
    L3010DT
    Don,
    Be careful. I think the big one wants to eat the little one. He looks hungry. Probably jealous of having full time parents and a place to live too. [img]/forums/images/graemlins/smile.gif[/img]
    Nick
  3. #23
    New Member
    Join Date
    Sep 2005
    Posts
    0
    What I should have dones was pick up the rake on the Cat and hover it over the little guy - the rake is serious! (attachment).
    Attached Images Attached Images
  4. #24
    Join Date
    Apr 2001
    Posts
    388
    Southern Maryland
    L3010DT
    Gawd [img]/forums/images/graemlins/ooo.gif[/img] Does processed boomer look anything like processed dog chow??? [img]/forums/images/graemlins/grin.gif[/img] You are right, that rake looks like it could do a good job of clearing debris. Looks like a nice rental, what do they get for a day of play time?
  5. #25
    Join Date
    Aug 2002
    Posts
    247
    mid- Maine
    Century 3045
    BWS, Here's the problem: When you get to the basic definition of what a tractor is, it is a TOY err. errr. I mean TOOL. I have some tools worth hundreds of dollars and some worth a few dollars. If I need a tool for a specific task that I don't have I usually just buy it. I can do this because they're really not that expensive in relation to what I save by paying someone else to do the job. When it comes to a tractor that philosophy certainly changes. I am not buying an ideal tractor to bushhog, one to mow grass, one to do FEL work etc. If you intend to do multiple tasks, what you end up with is either a perfect solution for some chores and a compromise for others, or possibly a compromise for all. Capable of everything, but isn't the best at any one thing. What you have in the 3830 is the perfect solution to improve your property and a compromise to maintain it. Personally I think you can alleviate most of your woes by changing to unloaded R3's and using some ballast when you use the FEL. You might want to consider removing the loader, depends on frequency that you switch and how difficult you find it. I have a #7000 lb open car hauler that handles an old Chrysler Imperial or Chevy Suburban no problem. I find it hard to believe it would have trouble with a kubota. Bottom line, I really don't believe you went too big, I think you have to fine tune it for your requirements, Changing the tires should do wonders.
    Good Luck
    Pacesetter
  6. #26
    New Member
    Join Date
    Sep 2005
    Posts
    0
    </font><font color="blue" class="small">( You are right, that rake looks like it could do a good job of clearing debris.)</font>
    Attachment shows what it can do without breathing hard.
    </font><font color="blue" class="small">( Looks like a nice rental, what do they get for a day of play time? )</font>
    I think I'm lucky. It's owned by a nice, local, young feller who uses it on contract with the local power company to clear power lines, and, with heavy pallet forks, to move pallets of sod. He lives right down the road and usually just drives it to my property, although he's dropped it off and picked it up using a heavy equipment trailer. All he wants is a little extra $$$ to cover maintenance on the tractor - letting me use it on the weekends is maximiaing the use; it doesn't sit idle for a couple of days. Therefore, he charges me $150/day when one of us is running it. When it gets into really heavy work, though, he has a couple of buddies who are so much more efficient at running it than we are that it often pays to hire the operator, too. They can sometimes do more in one day at $65/hour (usually a ten hour day - $650) than we could in 5 days of renting it (5@$150=$750). I've rented it for about 6 full days, so far, and paid them for another 3 full days of operation. The rough clearing is almost done at a total cost of $2850, compared to a land clearing company who quoted $5,000 for the same work (You have to remember, there was a lot of trash pepper trees and wild grape vines - the place was like a jungle when we started).
  7. #27
    Join Date
    Jul 2002
    Posts
    1,598
    Greene Co, Arkansas
    JD 1050 2wd, Case 580D 2wd
    Best get that vine/stick out of the grill. Blocking the grill is bad mojo. Looks like a fun machine.... I need one. [img]/forums/images/graemlins/smile.gif[/img]
  8. #28
    Join Date
    Dec 2002
    Posts
    208
    seattle area
    kubota l3830 hst/723 fel
    at the 50hr service i will have the tires emptied.i sure have made a mess around our barn and the driveway back to it.the dealer said 4800-5000lb tractor/loader/h.d.bucket/fluids/large r/4's filled.he ships them allover so i would guess he would be close.dont get me wrong i love the tractor but have stuck it a couple times.[truck yanked it out no problem].we have some wet ground around my area.we will be needing a hoe for perk tests and running new well waterline so this size may pay off in the short term.thinking bradco 408/509.we will be doing some tile work to dry the property out too.bws.p.s. wish i could post more but somebody's locking up the computors where i hang.see ya.
  9. #29
    Join Date
    May 2002
    Posts
    113
    Adamsville Pa / Williamsport Md
    John Deere 2640 / Ford 1710 / MTD 2554 ZERO TURN MOWER
    BWS
    It has been a wet spring !!!!!!!
    It's got to dry out sooner or later. I own a 1710 4WD with AG tires (2500 lbs I think)I mowed for the first last week and half of the property is still under water.
    The finish mower even left ruts, the AG tires left 6" ruts when I was 30 yards from the standing water
    I was able to mow last year without leaving any ruts and hardly a sign of my being there. Sometime the front AG tires left a mark if I turned too sharp and fast
    My 1710 is on an acre and a half piece of land and I too am looking for turfs and to take off the FEL once I get done clearing the land and putting in the yard
    Once you start other projects on your 6 acres Ithink you will be glad you have the bigger tractor.Maybe switch to turfs and get a set of chains if you have to
    LAter Bartman
  10. #30
    Join Date
    Sep 2000
    Posts
    1,862
    The Fabulous Foothills of Northern California
    BWS, good to hear from you, was hoping you could read all the comments about your situation. The ground conditions dictate for me when I can get out and use my tractor. Your right, you can really make a mess if you get on wet soil conditions to early. If the grass is long but the soil too wet, I just wait, especially on my hills here. The soil dries out quickly for me once the rain stops since I have hills, but the low areas can stop wet for quite some time. I plan to remove my loader for mowing and not fill the tires until I'm sure whether it will be needed. I fill and unload the tires myself.
    The bare tractor is just over 3000lbs but the loader adds another 1500lbs and the filled tire is about 600lbs. Hope it works out well.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
