Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Feb 2012
    Posts
    1
    Lynnfield, MA
    Ford 1510
    Default Ford vs JD
    tractor rookie here: I am looking at a 1999 John deere 790 FEL with 450 hrs for 11K vs a mid 80's Ford 1510 with 810 hours for 8K. Both have 4wd, comparably powered, 3 pt hitch. I have a small woodlot, would use tractor for moving dirt, rocks, firewood maybe some snow removal. Tractor is not going to get a lot of hours. I have read that JD 790's have front gear problems, and that Ford 1510's from the mid 80's have a tendency to blow pushrods. Opinions?
    I kind of like the JD route just because they are still in business and there's a dealer close by. I take it that Massey Fergeson is the successor to Ford
    I have rented a Kubota 024 and really liked it - but they are hard to find and more expensive.
    thoughts? thanks
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Gold Member
    Join Date
    Jan 2012
    Posts
    338
    Northern Washington
    John Deere 3005
    Default Re: Ford vs JD
    I have a 3005 JD basically the same as the 790, great tractor IMO ! Has plenty of power and just the right size, I have not heard of any issues with the 790 either sounds like a limited problem if there is one at all. Any machine can have problems if it's abused. Ford is also a great tractor so really but the one that suits your needs the best. The JD is hard to beat for dealer support and parts etc.
    2011 John deere 3005, already waxed 5 times.
    I drives me boat ! My wife drives me dingy !
  4. #3
    Veteran Member YesDeere's Avatar
    Join Date
    Dec 2008
    Posts
    1,011
    Merland
    Default
    The front end problems on the 790 were caused by reversing with a loaded bucket and no ballast weight. No doubt the 790 is a tough machine. I traded mine because I wanted hydro and more lifting power. Also a little more weight. Check the specs to see if it will be strong enough for you. I shimmed the relief on mine and it still wouldn't do what I wanted as far as wood moving. I have a pallet mover on the 3 point. I can't comment on the ford.
  5. #4
    Join Date
    Jun 2006
    Posts
    702
    Northern Alabama
    2012 Kioti DK45SE, 1994 JD LX176
    Quote Originally Posted by mmadden7 View Post
    Actually, NewHolland is the successor to Ford.
  6. #5
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    I would recommend the 790. They were excellently made tractors. You didn't state that the Ford had a FEL either, so I would see the clear option to be the deere. A FEL adds a ton of possibilities. And the Deere has less hours to start. I do think there's plenty of room for negotiating for the 790 though.
    As far as the Ford/New Holland thing - Ford actually bought New Holland, but then within a few years Ford sold to Fiat which then rebranded their tractor devision as CNH, which owns New Holland, Ford, Kobelco, as well as a couple others more popular in different countries. But, large company and wouldn't be to worried about parts, have supported the past machines very well.
    Good luck on your search
  7. #6
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,500
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    awfull lot of moey for either of those older CUT's
    I'd keep looking..
  8. #7
    Veteran Member RobertBrown's Avatar
    Join Date
    Jul 2005
    Posts
    1,640
    Florida
    Bolens G192/TS1910 Ford/New Holland 1920
    I think the john deere is the better deal.......because of the FEL.
    Neither sounds like great deal from wher i'm looking. I really don't think your comparing apples to apples with those choices.
    Unless you need a smaller tractor for tight spaces the ford is worth considering. You will most likely have lower operating costs with the ford, but! You want that loader. Even if you don't know it yet..... trust me, you want the loader
Similar Threads
  1. Spring Equip Auction - Central NY
    By JJT in forum Related Topics
    Last Post: 05-04-2011, 07:47 AM
  2. Comparison JD 5075E vs Kubota M7040SUD
    By mdelmarcelle in forum Buying/Pricing/Comparisons
    Last Post: 03-28-2011, 06:30 AM
  3. Comparison JD 5101E vs NH TD5050
    By minterk in forum Buying/Pricing/Comparisons
    Last Post: 12-13-2010, 03:12 PM
  4. Ford & IH finalize diesel divorce
    By Builder in forum Trailers & Transportation
    Last Post: 01-19-2009, 09:17 PM
  5. JD vs Ford Hydraulic Pressure Question
    By nunyabinis in forum John Deere Owning/Operating
    Last Post: 11-30-2008, 07:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
