Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Join Date
    Feb 2002
    Posts
    1,055
    WVa
    Kubota L3710, Ford 5600, Case MB4/94, Kubota B6200
    Default Re: Pond tool.
    Maybe you can get by if you just scrape up half a yard instead of a whole yard.
  2. #12
    Super Member ronjhall's Avatar
    Join Date
    Apr 2000
    Posts
    9,682
    SE Michigan
    Kubota 2910 HST
    Default Re: new toys for the new boys
    midlifecrisis
    At this site are some pictures I took during construction of our pond. Click Here.The 2910 and 4690 are a good choice for a garden pond. [img]/forums/images/graemlins/smile.gif[/img]
    Most of the post Iíve seen on TBN are for Ĺ acre and larger ponds over 10 ft deep. Which would be a lot of work for a 2910 and itís attachments. [img]/forums/images/graemlins/tongue.gif[/img]
    I would recommend the 72" MMM though. It will get the lawn cut faster. Also it is easier to move around when removing and installing. Because it has caster wheels on all 4 corners of the mower deck.
  3. #13
    New Member
    Join Date
    Sep 2005
    Posts
    0
    thcri- I'm about 200 miles North of you, right outside of Duluth.
    Ron- AWESOME pond. That's exactly the reason I need a bota at the new house. Exactly. You did fine work and your fine tractor was a major asset. It looks a tad bit bigger than what I had in mind for my turn-around pond. Any words of advice are more than appreciated. I'll be digging in light clay/sand for the most part. How much time was invested? If you don't mind, how many $$$ total. If that's private info, I understand completely. Do you have a gallon estimate for vloume? I was thinking of having the local milk hauler bring home a tank of water after his final rinse and fill it that way. I don't want to run my new well dry the first year. LOL
    I will also check into the 72" MMM today.
    The belly scraper has it's purpose, but I'd hate to be stuck at the bottom of a hole. I'd rather be on the outside looking in.
    thanx everyone
  4. #14
    Elite Member thcri's Avatar
    Join Date
    Jan 2003
    Posts
    4,693
    Minnesota SE
    New Holland TC29D, 2001
    Wow,
    I get up to Scanlon and Banning Juction 4 wheelin alot.
    murph
  5. #15
    Join Date
    Apr 2000
    Posts
    9,682
    SE Michigan
    Kubota 2910 HST
    I started the pond last Memorial Day weekend. Put water in it 4th of July weekend. Put fish in it before August. It took awhile. I work for a company that supports automotive assembly plants. From the first of June until the end of August is our busiest time. This meant that I only had one or 2 days to work on projects. I had to buy all the rocks and other landscaping materials. They were expensive to say the least. [img]/forums/images/graemlins/tongue.gif[/img]
    Pond is 11ft. X 16ft X 2ft. Pond is a little over 2000 gallons.
    I purchased a kit from a local store in my home town. Price was about $1500 including liner, under layment, skimmer, bio filter falls, pump, plumbing, and UV light.
    There are quite a few sites on the Internet for Water Garden information. Here are some that I have used.
    Grass Roots
    Pond Supplies of America
    The Pond Doc
    The Water Garden
    One of the best written references I have found is the Pond Doctor.
  6. #16
    Join Date
    Jul 2002
    Posts
    1,598
    Greene Co, Arkansas
    JD 1050 2wd, Case 580D 2wd
    Do you have any info on these attachments? I don't see any prices listed on their website...
  7. #17
    Gold Member FamilyFarm's Avatar
    Join Date
    Jul 2002
    Posts
    476
    Crane, MO
    Kubota L4740HST, Kubota RTV 1140 Camo
    </font><font color="blue" class="small">( Do you have any info on these attachments? I don't see any prices listed on their website... )</font>
    5 ft model $3,850
    6 ft model $3,950
    Terry
  8. #18
    Join Date
    May 2001
    Posts
    336
    Summerside, OH
    NH TC33D; RTV900; Gravely Professional
    Here's what I think of when I think of digging a pond!
    Attached Images Attached Images
  9. #19
    New Member
    Join Date
    Sep 2005
    Posts
    0
    I own a 2910 and I love it. I think that you will be very happy with it. I would like to suggest getting the RMM instead of the MMM. I think that you will be happier with it. It is easier to take on and off. It is easier to get around things.
    I would also like to suggest looking at the Woods 7500 backhoe. They make a nice backhoe. If not the same a little better in quality. You can save about $1,000.00 by getting this for other attachments. Just something to check out.
    I think that if you have a lot of time that you can dig that pond with the tractor. With a toothbar and a little patients you can do it. They are powerful machines and will do a lot. As long as you aren't beating through rock it won't be bad. You also have the backhoe if you need it. I say go for it. It doesn't hurt to try.
    Knowles
  10. #20
    Join Date
    Jan 2003
    Posts
    4,693
    Minnesota SE
    </font><font color="blue" class="small">( I would like to suggest getting the RMM instead of the MMM. I think that you will be happier with it. It is easier to take on and off. It is easier to get around things. )</font>
    I would totally agree that putting the RMM on and off is a lot easier than a MMM. If fact I believe the RMM will actually do a better job of mowing if it is a finish mower. But there is no way a RMM makes it easier to get around things. You constantly have to be watching your front end and the back end. (sore neck the next day). The lenght of your tractor ends up being 5 ft longer. If you have trees to go around the MMM will allow you to just go around the tree, with a rear mount as you go around a tree the mower keeps working its way away from the tree. If you have open area and nothing to really go around, then the RMM is the better deal, otherwise not.
    murph
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
