Results 21 to 26 of 26
11-02-2012, 10:29 PM #21Bronze Member
- Join Date
- May 2010
- Posts
- 78
- Location
- mo
- Tractor
- 1988 Kubota L2202DT 1998, Bobcat 331 bobcat, F800 dump truck
Re: Takeuchi TB035 Mini-Excavator
If it has a hole for it you can buy a block heater from the parts store for about 60 dollars
11-02-2012 10:29 PM # ADS
11-04-2012, 10:34 AM #22Bronze Member
- Join Date
- Jul 2007
- Posts
- 74
- Location
- Murphy NC
- Tractor
- Wheel Horse, Cub Cadet,Several Speedex's,Allis Chalmers, John Deere, Tuff-bilt, Power Mite, Bonanza, Power King, Bobcat Toolcat, Takeuchi Trackhoe
I think I can get one that fits in the radiator hose. I wasn't sure if that would fix it since one of my friends suggested it might be low on compression. But, would it run really great and not burn any oil if the compression was low?
11-07-2012, 07:49 PM #23Bronze Member
- Join Date
- May 2010
- Posts
- 78
- Location
- mo
- Tractor
That's beyond my level of expertise
11-08-2012, 06:03 PM #24Bronze Member
- Join Date
- May 2010
- Posts
- 78
- Location
- mo
- Tractor
But I can tell you, my dump truck was the same way, took a couple minutes of cranking to get started cold. Ran great, but cold natured. Most of the Cummins motors had grid heaters in em, but for some reason mine didn't. I got one of those cheap block heaters from O'Reilly's or NAPA and it works great.
I never had any experience with the Yanmars. Will it not start cold or just takes a while to start?
11-08-2012, 06:48 PM #25Super Member
- Join Date
- Aug 2001
- Posts
- 8,251
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I'm late to this thread but these machines can be a lot of fun to work with and even tinker on. I have a Bobcat 331 and it has a few items that need to be addressed over the winter. Repair the leaking drive motor and repair or replace the x-change connection as it is worn bad. Other than that it has been great. The cab is nice since I use it a lot when it is cold or raining. It doesn't have AC but it does have heat and even with the windows open it isn't bad to operate in the cold as you just turn the heat up. Then you can still talk to the guys around you as needed.
Mine has an electronic hour meter/dash panel that is messing up and I can't always read the hours or trouble codes properly and I want to replace it but not bad enough to spend $900 for a new one. I would highly recommend one to someone over a 3pt back hoe. You can get used, open station units for around $10k and have a completely dedicated digging machine to play with and help out (every tractor owner needs a second machine for some reason or the other).
God must love stupid people; He made so many
11-08-2012, 07:14 PM #26
Similar Threads
Central Texas Mesquite Clearing/Pond Digging: Midsize Dozer vs. Mini Excavator
By perdurabo in forum ProjectsReplies: 5Last Post: 10-21-2009, 10:16 AM -
By perdurabo in forum Construction EquipmentReplies: 9Last Post: 10-11-2009, 09:33 PM -
SHOOTOUT - Skidsteer Vs Mini Excavator
By dieselfuelonly in forum Buying/Pricing/ComparisonsReplies: 20Last Post: 11-11-2008, 06:35 PM
