Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Join Date
    Jan 2012
    Posts
    1,418
    Ma
    Kubota b2920
    Default Re: Build Stone Walls
    I use my kubota b2920 to do that on my property. Its got good clearance, enough muscle for the work, but is still small enough to work in the woods without having to trim trees. I use the backhoe with a thumb for most of my wall building and it works great. Once in a while i use the Fel to help, but don't have a grapple yet.
  2. #12
    New Member
    Join Date
    Apr 2012
    Posts
    14
    Chesapeake, VA
    Kubota B3300SU
    MarkV,
    Thanks for the tip on hydraulics. As you can tell by my questions I am totally unfamiliar with tractors and their capabilities. My only experience is years ago where I used a large tractor to move wall panels and trusses through sandy/muddy water.
    GFL
  3. #13
    New Member
    Join Date
    Apr 2012
    Posts
    14
    Chesapeake, VA
    Kubota B3300SU
    I was only hopping on the manual intervention. We would like to use as large a rock as we can handle with the equipment we will eventually purchase. There have been folks dismantling the walls to make openings for ATV vehicles and we want to discourage this - therefore the larger the rocks, the better.
    GFL
  4. #14
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    Sounds like the job for a BX25 w/ EMP BH Thumb and FEL Grapple.
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  5. #15
    Super Member Mace Canute's Avatar
    Join Date
    Nov 2006
    Posts
    8,563
    Saskatoon, Saskatchewan
    Quote Originally Posted by magicheater View Post
    I do it with a B7800 and a small grapple I designed and built. The rock in the picture weighs 600-700 lbs. The pile is what I stacked using it.
    That's a pretty nice unit!
  6. #16
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,668
    central Wisconsin
    Kubota B7800, B26 TLB
    Quote Originally Posted by Mace Canute View Post
    Thank You!
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  7. #17
    Veteran Member Luremaker's Avatar
    Join Date
    Aug 2004
    Posts
    1,250
    Ontario
    Kubota L3130HST & NH TC18
    Great Post! I'd like to build a stone wall. I live in an area where there are many stone walls. Farmers had to do something with all the stones. I hope to get a thumb for my backhoe this summer which should make stone wall building a little easier.
    Here's a neighbors stone wall.
  8. #18
    Veteran Member JDGreenGrass's Avatar
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Quote Originally Posted by Luremaker View Post
    Wow. That's an incredible rock wall. The real deal right there.
    Thanks for posting the photo.
    JD770 '92 4x4 SMC FEL JD Ballast Box 6' CountyLine Back Blade 6' CountyLine Rake CountyLine CarryAll
    64" Frontier Snowblower
    Favorite Color....Green
    The sky was yellow and the sun was blue.
  9. #19
    New Member
    Join Date
    Apr 2012
    Posts
    14
    Chesapeake, VA
    Kubota B3300SU
    Magicheater, what you have is what we are looking for!! Thanks for the info
    GFL
  10. #20
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Quote Originally Posted by GFL View Post
    GFL
    Jery makes REALLY nice stuff and the prices are more than fair.
    Regards,
    Artisan
Similar Threads
  1. A custom build.
    By 4shorts in forum Projects
    Last Post: 03-16-2012, 08:56 AM
  2. How to do natural stone work the correct way.
    By machmeter62 in forum Projects
    Last Post: 06-27-2011, 12:52 PM
  3. Replies: 41
    Last Post: 05-28-2011, 10:55 PM
  4. stick built or other ??????
    By Beavis in forum Projects
    Last Post: 03-31-2010, 08:26 PM
  5. Build an underground shop - why not?
    By jinman in forum Projects
    Last Post: 07-29-2009, 06:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
