Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    New Member
    Join Date
    Oct 2010
    Posts
    10
    Default Re: Best tractor to get to mow under trees
    The trees are spread out and the terrain is relatively flat, but rough. We cut down thick vines and small yaupons, so there may be some smaller stumps that the blade will hit. I was thinking that the ZTRs may not be ideal for this, but I'm not sure. Any thoughts?
  2. #12
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    I would also agree with cut the limbs up or higher tree service to do it. If not just get you an old ford 2000 or something like and an 5/6ft shredder,probaly find good older shape tractor and shredder for around 3500...
  3. #13
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Sounds to me like more handwork is needed before putting a mower under the trees. I would recommend cutting the stumps off at ground level, maybe a cordless sawsall would work for you. I also agree with the others about using a pole saw, I have had good success with a Florian telescopic 12' model. If you clean it up well enough you should be able to run a small mower beneath the trees. Trim the branches high enough and you could use your existing tractor.
  4. #14
    Elite Member Gittyup's Avatar
    Join Date
    Oct 2007
    Posts
    3,141
    Mid Atlantic
    Kioti CK25 Shuttle Shift, loaded tires, JD X739
    How about a used JD 400 series? Maybe in aws. Cost about 3k - 5k. Even a restored 8n with mower would be pretty cheap.
  5. #15
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    I have the same problem with cherries and walnuts. Anything that won't fit over the tractor gets trimmed off. Now that the trees have gotten older and the branches higher it's not the problem it used to be.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
Similar Threads
  1. Replies: 4
    Last Post: 04-13-2010, 03:32 PM
  2. 240 year old Elm Trees
    By WayneB in forum Rural Living
    Last Post: 01-11-2010, 10:07 PM
  3. Pushing over trees
    By BrentD in forum Owning/Operating
    Last Post: 12-05-2009, 02:33 AM
  4. Charge to plant trees?
    By NLWoods in forum Owning/Operating
    Last Post: 04-26-2007, 09:36 AM
  5. Fruit trees falling over ?
    By Mrwurm in forum Rural Living
    Last Post: 06-07-2004, 12:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
