Results 21 to 30 of 36
06-26-2012, 09:30 AM #21Bronze Member
- Join Date
- Jun 2012
- Posts
- 53
- Location
- Bethany, CT
- Tractor
- 1983 John Deere 212, 1988 John Deere 1050
Re: Newbie TBN looking for advice on 4x4 tractor
Interesting points. I won't be plowing fields or planting seed (I only have 2 acres, only 1/2 of it is lawn and flower garden). My main need for a machine (skid steer/TLB) is for moving dirt around (a LOT of rock in my soil, so there's chances that I'll have a heavy bucket load), working on gathering firewood (I use a fireplace all winter to save $$ on oil heat) and other odd-jobs that require power to lift.
So...I guess my MAIN requirements are lifting power at this time. I would love to have a back hoe, chipper (tons of brush in my forest) and maybe splitter (although I have a tow-behind 25ton horizontal that I use frequently). This leans me back and forth between the skid steer (compact but powerful; implements extremely expensive) vs. the tractor TLB/FEL (not as powerful, but very versatile and implements are much more affordable).
Eric
06-26-2012, 04:00 PM #22Padawan Tractor Learner
Advertiser
- Join Date
- Mar 2009
- Posts
- 6,336
- Location
- NW Oregon
- Tractor
- Deere 317 & L118
Those were also some problems that I have come to with having the skid steer, i want to mow brush around the property but don't want to shell out $3500 for a mid level bush hog. So I am working on making a 3 point hitch w/hydraulic PTO adapter. I kept the John deere imatch from my Yanmar and will mount it to a blank SSQA plate along with the hydraulic gear box. So far I almost have everything, I just need to get some tube steel, hydraulic lines with quick couplers, and a hydraulic relief valve so the mower can spin down when the hydraulic flow is shut off. Sounds complicated and expensive but in the end I should be in it around $700-$750 and have it completely built in a couple days. Plus I will then gain the ability to run most 3 point attachments and save some money when it comes time to buy a mower.
My Fleet:
2004 Deere 317 Skid Steer Loader
66" Construction bucket, imatch QA adapter, CU72 Jake Rake, Middle Buster, 60" Landscape rake, 54"x 48" Pallet forks
2005 John Deere L118
42" deck
Check out my rakes: www.Jakesimplements.com
Check out the latest small engine I am working on: http://www.northwestsmallenginerepair.weebly.com
Member of the TBN "Young gun" Club
06-26-2012, 04:02 PM #23Padawan Tractor Learner
Advertiser
- Join Date
- Mar 2009
- Posts
- 6,336
- Location
- NW Oregon
- Tractor
- Deere 317 & L118
My Fleet:
42" deck
06-26-2012, 07:05 PM #24
I mentioned this as i thought i read that you were thinking of doing foodplots for money. This is a huge business is tractoring aroune here. But also is mowing. Folks who have 3-10 acres may have a tiny 1-2 acre pasture that they want cut but have no tractor and dont want to mow with a lawnmower every few weeks so they pay to bushhog it once a year. If you have a tractor you capture this business. You wont get rich doing this but if there close you can run up there and mow it in a few hours or so and make a quick $100.
YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
1991 Javalen 17ft w/same year 150 Johnson GT
Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
06-27-2012, 10:10 PM #25Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,842
- Location
- First organized permanent settlement in the northwest territory
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
1*I'd Stay Away from refurbished cause it dosen't mean rebuilt or restored like they want you to think it does.
Usually all you get is a little new paint and maybe some cosmetic work.
2*Don't forget you can run this in your tractor .
Its the same stuff that cost 25 to 50 cents more at the gas station .
3*You need a 7000 pound equipment or car hauler trailer with brakes on all 4 wheels to haul a TLB on.
You also need a 3/4 ton pick up to pull the trailer with .
A Skid steer is much heavier than a TLB say 10000 to 12000.
A 7000 pound trailer won't handle that so you need to move up to a 12000 pound trailer and a 1 ton truck.
You have to be careful of weight restrictions in order to avoid having to go with a CDL license and all the hassle and regulations that go along with that .
06-28-2012, 03:49 PM #26
06-28-2012, 09:01 PM #27
OP / Eric - Just checking searchtempest for you around your area. There appear to be several good tractors for sale!
06-29-2012, 06:45 PM #28Bronze Member
- Join Date
- Jun 2012
- Posts
- 53
- Location
- Bethany, CT
- Tractor
I am going to see the JD 1050 tomorrow afternoon. I'll let you know how it goes.
-=1983 JD 212=-
-=1988 John Deere 1050 MFWD=-
-=Attachments - Model 75 Loader / Model 1650 Backhoe=-
06-29-2012, 08:15 PM #29Super Member
- Join Date
- Feb 2008
- Posts
- 7,736
- Location
- somewhere usa
- Tractor
- stuff
If it was me I would buy the 1050 tlb package as it is more versatile for a first piece of machinery. I might consider more specialized equipment afterwards but a tlb has a lot of bang for the buck.
08-06-2012, 03:49 PM #30Bronze Member
- Join Date
- Jun 2012
- Posts
- 53
- Location
- Bethany, CT
- Tractor
-=1983 JD 212=-
Similar Threads
Newbie looking for advice on new tractor
By maltese farmer in forum New Member IntroductionsReplies: 6Last Post: 01-23-2011, 06:36 PM -
Buying Advice Please help newbie with tractor/backhoe advice
By mitchelli in forum Buying/Pricing/ComparisonsReplies: 19Last Post: 04-19-2010, 04:35 PM -
Newbie Tractor advice
By argeaux in forum Buying/Pricing/ComparisonsReplies: 22Last Post: 04-15-2009, 01:29 PM -
tractor newbie needs advice
By peter_vii in forum Kubota Buying/PricingReplies: 5Last Post: 10-25-2008, 12:55 AM -
Newbie needs advice on tractor selection
By CajunRider in forum Buying/Pricing/ComparisonsReplies: 12Last Post: 01-07-2005, 06:40 AM
