Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    Join Date
    May 2009
    Posts
    927
    South Mississippi
    2008 John Deere 5303 MFWD
    Default Re: John Deer 5065 vrs Kubota 5640
    Checked TractorData.com to verify, on my JD5303 B2 runs 5 mph and B3 runs 7.5 mph. Could not find the stated ground speed for the Low 2nd on the M5040, but I am still impressed by the M5040 in that application. Maybe I just underestimate what is possible if needed. I wouldn't mind having a 10' to 12' cutter, but would be limited in it's applications due to mostly wooded areas I work in and around. Still enjoy looking at what others are doing and enjoy looking at equipment.
  2. #32
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,714
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    You guys have some awesome pictures!
    I hope you remember to take (and post) some updated pics of the new 5065
    Congrats by the way.....
    Also, not to try and change your mind, but my father and I picked up a nice, used 1985 (not positive of year) JD 410B for the heavy work. My dad only uses it for snow removal in the winter so I use it the rest of the year.
    Martian is correct in that it will completely outdig (as in, not even a contest) the ability of the JD backhoe you are thinking of. My neighbor has the 485 on his 4720 and it is great for drainage work in tight areas, but I wouldn't even consider doing a big job with it. (for reference, you are talking about excavating a lot more ground that even a large house with full basement would require, and a small backhoe is not up to that task for practical purposes)
    However, I completely understand wanting to buy one and if you really want one and know what to expect then there is nothing wrong with that
    Here is what we got for less than the price of what you were quoted for the hoe....
    (Oh, and...I'm extremely jealous of your new purchase )
    John Deer 5065 vrs Kubota 5640-i-cd5wzzp-l-jpg
    John Deer 5065 vrs Kubota 5640-i-8q6bbm5-l-jpg
  3. #33
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    Quote Originally Posted by deere5105 View Post
    May bad its around 2mph,it was either that or go faster and have to go over it twice cause it was leaving scragglers. I usually pull the 8ft here cause it floods and cant get into here most of the year but my father-in-law had it on his 2wd cause its easier for me to pull him out and I kept mine away from the known wet spots,let him fool with cleaning those up. He only got stuck once but didnt get a picture for some reason.
  4. #34
    Gold Member BleedGreen's Avatar
    Join Date
    Nov 2006
    Posts
    471
    Iowa
    John Deere LX178
    Quote Originally Posted by Martian View Post
    Are you sure the 485 can fit on the 5065e? According to JD's website it can only go up to the 4x20 series. I think you need an aftermarket backhoe as I don't believe Deere makes a BH to fit the 5065e.
    That is a really big trench. I would offer the same advice as mentioned.
    Hey Martian - just for your info the 485BH fits the 5E Series just fine...
    485 Backhoe
    (For 3120-3720 Open Station, 4120-4720, 4300-4400, 4310-4410, 4500-4700, 4510-4710, 5045E-5075E, 5103-5403 Tractors)
    Subframe Mounting Brackets, Hydraulics and Hardware For 5045E-5075E Series Tractors and 5103-5403 Series Tractors
    Compatible with serial numbers after PY5103UO13641, PY5203U005570, PY5303U007753, and PY5403U000735.
    I agree the JD Configurator sometimes leaves a bit to be desired. And I also agree that a full-size dedicated BH would be better in this situation...
    I can run a D100 and a 9560RT (and most of the models in between) all in the same day!!!
Similar Threads
  1. Kubota 5640 and 7040
    By Porkie in forum Kubota Owning/Operating
    Last Post: 08-24-2013, 08:48 AM
  2. Kubota BX2360 - John Deer 1023E Tractor Comparisons
    By rudiface in forum Buying/Pricing/Comparisons
    Last Post: 04-05-2012, 07:11 PM
  3. Price Check John Deer vs. Kubota
    By dannylink in forum Buying/Pricing/Comparisons
    Last Post: 06-08-2010, 12:11 PM
  4. John Deere 145 vrs Husqvarna 23-HP 48" Cut
    By passgas55 in forum John Deere Lawn & Garden
    Last Post: 03-23-2010, 02:54 PM
  5. Ford vrs Kubota
    By JonE in forum Photos
    Last Post: 12-12-2000, 11:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
