Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Member
    Join Date
    Jul 2008
    Posts
    42
    Western Oregon
    Ford/NH Model 1920, Allis Chalmers Model G
    Default Re: What would be a good tractor for my hobby farm?
    Just one point to make... regarding the 5 HP per rotary cutter foot in diameter...
    I have a Ford 1920 (31 HP at PTO), and a JD 5 foot rotary cutter. In theory, I have more horsepower than I need according to rule of thumb. However, there are situations I run into where even my tractor/cutter combination requires me to gear down to a pretty slow speed to get through a rough patch of blackberries, or tall grass. Something to keep in mind: there's "able to do it," and then there's "able to do it at the speed I want to do it." Those are often two different horsepower ratings!
    Kurt
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    550
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    Man, 30 acres is a lot of mowing for a 6 foot bush hog. I agree with buying a 50 horse machine, but I'm sure I'd want a wider mower.
    I really like the Massey 1648 4wd FEL and HST and would have bought one last winter, but it wouldn't fit in my barn. Massey's 2625 is a beast of a machine and would handle a batwing mower.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  4. #23
    Join Date
    Sep 2009
    Posts
    550
    Maryland
  5. #24
    RPW
    RPW is offline
    Platinum Member RPW's Avatar
    Join Date
    Aug 2009
    Posts
    661
    30 acres is a lot especially if you want to do it in one shot. However unless your're doing if commercially you can knock it out in 2 - 3 days with a 6 - 7 ft mower. It will also depend on what your're mowing and how tall. HST is great but mowing generally you set and forget so don't overlook geared. If you got hills or slopes then 4wd is your best friend but if it's mostly flat then 2wd will work just fine. I'd also look at what else you need to do over the long time.
    Good luck
    2008 JD 5103, FEL, 6' Frontier, 6' HD boxblade, 7' Landscape rake, More impliments to come, Bobcat (clark) 742 SS.
  6. #25
    Silver Member Airedale's Avatar
    Join Date
    Jul 2003
    Posts
    174
    Central NY
    Ferguson TO 30 - TYM T433 Cab - Power King 1614
    I have a small operation about the size you have and raise a few head of Irish Dexter cattle and use my tractor much the way you are planning to do, as most here have stated a mid size tractor in the 40 hp and up range would be best suited for what you are wanting to do. There are plenty of good tractor brands available that size both new and used, the main thing is to find a good dealer.
    My own choice was a TYM 453 cab and so far it has worked out fine for me.
    Al
    Serious Dogs For Serious Work
  7. #26
    Member
    Join Date
    Jun 2012
    Posts
    40
    Riner, VA
    Kubota M6040HD
    Default
    I was all set to buy a Kioti DK40SE with HST, but I ended up buying a used Kubota M6040 with hydraulic shuttle instead. I found it listed for sale not too far away at a good price, and I couldn't resist. I have had the tractor since Saturday and have been able to put in a few hours of seat time, mostly grading driveways and around barns with an 8' scraper blade and the front end loader. We tried out the bale spear as well. So far I am very impressed with the power and ease of use of the tractor. I couldn't be happier. Tomorrow I will pick up a 7' Kodiak rotary cutter, and this weekend I hope to start mowing about 20 acres at my inlaws, most of which hasn't been touched since last summer.
    What would be a good tractor for my hobby farm?-forumrunner_20120828_210410.png
    What would be a good tractor for my hobby farm?-forumrunner_20120828_210458.png
    What would be a good tractor for my hobby farm?-forumrunner_20120828_210525.png
    What would be a good tractor for my hobby farm?-forumrunner_20120828_210245.png
  8. #27
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,066
    texas
    kubota M7040 &m7040
    That should do it
  9. #28
    Member JBowie's Avatar
    Join Date
    Aug 2012
    Posts
    33
    Bastrop County, Texas
    Kubota M5140HD
    Default
    Great choice. Enjoy your new tractor.
  10. #29
    Silver Member scaredychicken's Avatar
    Join Date
    Jul 2012
    Posts
    143
    Salmon Arm BC, Canada
    John Deere LT160, Arctic Cat 400 ATV
    Congrats, the previous posts had your questions covered. this was outta my league (as I'm only considering the 30 hp range personally), but you found a great tractor.
    don't forget to update your tractor profile from "none" to "Kubota M6040" and you'll be all set. Congrats and have fun doing the work.
  11. #30
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,124
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Nice unit!! ....that's what she said!!
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
Similar Threads
  1. Buying Advice Advice on purchasing new JD 4520 tractor and needed attachments - 50 acre hobby farm
    By rclow in forum John Deere Buying/Pricing
    Last Post: 02-06-2010, 11:13 AM
  2. Hobby farm troubles
    By NH-Rob in forum Projects
    Last Post: 08-04-2009, 07:28 PM
  3. hobby farm equipt.
    By 1TOYMAN in forum Cub Cadet Yanmar & CUTs
    Last Post: 08-07-2006, 09:17 PM
  4. Hobby Farm Options
    By BungeeII in forum Buying/Pricing/Comparisons
    Last Post: 06-09-2006, 06:33 PM
  5. Tractor recommendations for hobby farm
    By reconmarine in forum Buying/Pricing/Comparisons
    Last Post: 01-29-2002, 12:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
