Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,461
    Oklahoma
    JD cut
    Default Re: John Deere 4720 temperature gauge problem
    Isn't that the M$ line, "That's not a flaw, it is a feature."
  2. #12
    Super Star Member
    Join Date
    Dec 2003
    Posts
    12,338
    NC
    Kubota Grand L3830
    Quote Originally Posted by NebraskaKen View Post
    Following is the official response to my query from John Deere's customer service department:
    Per our discussion earlier today it is normal for the temperature gauge to read above the 1/2 mark, this is considered normal operation for your 4720. There are some tests your dealer can perform to ensure your unit is operating properly, but I believe you said the dealer has done these test and stated your unit is working as designed. If that is not the case please let me know I will give your dealer a call.
    Thank you,
    Kimberly
    Customer Advisor
    Needless to say I am very dissapointed in JD's customer service and this trite response. Take a look at the attached photo of the temp gauge. Does this look "NORMAL" to anyone?
    It would be of concern to me also. A few minutes of hard work and the needle will then be in the red, then what?
  3. #13
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by Gator6x4 View Post
    Not necessarily, I have worked my 4520 pretty hard and the temperature guage holds steady.
  4. #14
    New Member
    Join Date
    Jun 2007
    Posts
    8
    Nebraska
    John Deere 4720 CAB, John Deere X728SE, John Deere LT180
    Well, I guess it's time for me to throw in the towel on this one. It's just that I've never had a machine that ran past the half way mark, ever, in 50 years of buying anything on two, three, or four wheels. This is a first. Everything else about the machine I like, now that the AC is fixed. My trade in was a good running 4710 JD, and it's temp gauge never went above the 1/4 mark. I think that difference is what really surprised me when I took the wheel of the new 4720. Thanks everyone for your input. What a great resource you are !
  5. #15
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Get a real temp gauge that shows how hot it is.
    Murph
  6. #16
    Join Date
    Mar 2011
    Posts
    83
    Prairieville, louisiana
    john deere 4120
    My new 4120 runs in that range which concerned me at first as my old 3320 ran about 1/4 on the temp gauge. Was told the powertech deere engines are designed to run hotter than the yanmar engines found on the 3000 series. Anyway, love the tractor so far and have had no issues the turbo really provides a lot of grunt on these engines.
  7. #17
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Your 4710 had a Yanmar engine and the 4720 has a Deere engine so I wouldn't expect the reading to be the same.
  8. #18
    Join Date
    Mar 2011
    Posts
    83
    john deere 4120
    There is a thread under john deere owning operating from someone asking the same thing about a new 4520. If you check it you will find pretty much the same responses from other owners, seems to be normal.
  9. #19
    Join Date
    Apr 2002
    Posts
    595
    SE Minnesota
    John Deere 4720 Cab
    I too was expecting the gauge to show higher. It looks like mine did on my 4720. I think everything looks fine.
  10. #20
    Veteran Member YesDeere's Avatar
    Join Date
    Dec 2008
    Posts
    1,140
    Merland
    Default
    Was out for several hours shredding in the heat. Temp stayed like this the whole time.
    Attached Thumbnails Attached Thumbnails John Deere 4720 temperature gauge problem-image-993307784-jpg
Similar Threads
  1. NAA - Problem replacing temperature gauge
    By jgayman in forum Ford Vintage Tractors
    Last Post: 05-08-2014, 07:18 AM
  2. Price Check John Deere 4720
    By Jusrich1 in forum Buying/Pricing/Comparisons
    Last Post: 09-30-2010, 03:08 PM
  3. JD 4310 temperature gauge problem
    By RockyDeere in forum John Deere Owning/Operating
    Last Post: 05-02-2010, 09:38 PM
  4. John Deere 4720 58 hp hydro only ??
    By CountryJoe in forum John Deere Buying/Pricing
    Last Post: 09-12-2004, 12:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
