Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    2,120
    Northeastern Minnesota
    Kubota M7-171, Kubota M110GX, IH 4386, IH1486, Case 301.8, Kubota L6060, plus many others
    Default Re: John Deere 4720 temperature gauge problem
    Running hotter because of Tier IV should not be a response. They could easily put in a temperature gauge calibrated to run with the needle at the vertical position even with a new thermostat setting. The important thing, however, is that you worked the tractor hard under load and the needle didn't move. That is the best indication there is no problem but there is a lower margin of safety so you might overlook the needle climbing into the red as your radiator begins to get covered with crap from shredding. My kubota has a LCD bar graph display and it is easy to miss the temp climbing. I have caught myself a couple times with all the bar segments lit except the high temp. They should have a light at that point like in the cockpit of the airliner in Airplane - "A Little Hot". Like when my bar graph on the fuel gauge drops down to 1 segment it changes to Low Fuel. When it drops that last bar it should say "You're Screwed" but instead the engine dies.
    Kubota M7-171, L6060, RTV 900XT, GR2120
  2. #22
    Gold Member eagle107's Avatar
    Join Date
    Jul 2011
    Posts
    376
    NY
    John Deere and New Holland/Ford Tractors
    Quote Originally Posted by MHarryE View Post
    Mine looks just like "YesDeere's" picture. As soon as the needle hits the tip of the red area, the warning light starts blinking on the dash and the LCD states "Hot Temp" if I remember correctly. This only happened to me once when brush hogging and all the air vents got clogged with debris.
    John Deere and New Holland/Ford Tractors and stuff
  3. #23
    Veteran Member YesDeere's Avatar
    Join Date
    Dec 2008
    Posts
    1,140
    Merland
    Default
    Now this is after roto-tilling for half an hour on my 4310. Just a different beast. I'm glad of this thread for my new attention to the temp.
    Attached Thumbnails Attached Thumbnails John Deere 4720 temperature gauge problem-image-43589490-jpg
  4. #24
    Join Date
    Jan 2010
    Posts
    610
    East Coast
    Many
    My 2011 4720 runs the same way. I had a 3720 that never went over the middle range and raised the same consern to this site when i first ran my 4720...it seems I got the same answer and "it's normal". i have close to 200 hours and it runs to the hot side but have not had any problems. i did have the red "hot temp" light and "STOP" come on once, but that was my fault due to very clogged radiator and ac units...clean out and it's running fine...the ac was much better after the cleaning as well
  5. #25
    Join Date
    Dec 2008
    Posts
    1,140
    Merland
    Default
    I used a bottle brush on my fathers 4720 this weekend. Kind of an ill design no removable screens.
  6. #26
    New Member
    Join Date
    May 2012
    Posts
    9
    Damon, Tx
    JD 6310
    Late post to this thread, but I found it interesting, because my 6310 runs at the same place. Always has. Engine never feels (hands on test) too hot and believe me I have checked it dozens if not hundreds of times. I just never liked how that gauge reads. Makes me nervous.
Similar Threads
  1. NAA - Problem replacing temperature gauge
    By jgayman in forum Ford Vintage Tractors
    Last Post: 05-08-2014, 07:18 AM
  2. Price Check John Deere 4720
    By Jusrich1 in forum Buying/Pricing/Comparisons
    Last Post: 09-30-2010, 03:08 PM
  3. JD 4310 temperature gauge problem
    By RockyDeere in forum John Deere Owning/Operating
    Last Post: 05-02-2010, 09:38 PM
  4. John Deere 4720 58 hp hydro only ??
    By CountryJoe in forum John Deere Buying/Pricing
    Last Post: 09-12-2004, 12:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
