Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Bronze Member 1969grandpa's Avatar
    Join Date
    Oct 2011
    Posts
    93
    Belton, SC
    Kubota L3540
    Default Re: Grapple 'Bucket vs. Grapple 'Rake"
    Quote Originally Posted by murphy1244 View Post
    How much can you lift?
    1800+ lbs.
    Chris
    2012 Kubota L 3540 w/ paddle shifter
    3rd function valve for the CA 72" root grapple
    PTO generator
    hay Speer, forks, yada yada yada
    Toro Z Master commercial mower
  2. #12
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,544
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    Quote Originally Posted by chopped View Post
    Hi I was loing at these two attachments and trying to weigh out which is better for my needs,I was wondering if anyone had had use of one and would like to comment.My use is basically, instead of buying a chipper, I could have one of these for less money and maint. I have a spot to put the brush to rot naturally, so it seems like a good fit.
    I like the bucket as it has more of a bed to it.(considering other uses). But the rake opens wider in the Jaws.
    I think it would come in real handy to hold logs as I cut them to rounds.In which case I might not neet a wide one. I have a 60 inch bucket now, but these also come in 48 inch. So im also considering the 48 inch one for the use id give it.
    Any thoughts or comments are surely welcome thanks.
    the bucket.
    60" LW Root Grapple Bucket $1095.00 | Grapple Bucket Attachments | 60" LW Grapple Bucket | palletforks.com
    the rake
    60" Root Grapple Rake $1375.00 | Grapple Bucket Attachments | 60" Grapple Rake | palletforks.com
    What size tractor will the grapple be installed on ?
    A Fredricks Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Honda 300 4 trax
    Yamaha Timberwolf
    liquid logic coupe kayak
    16' Tow Master Dump Trailer ,20' Yanmar Hauler
  3. #13
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    Quote Originally Posted by kenmac View Post
    28 horse power four wheel drive. hydraulic system with a 7.1 gallon capacity and a 7.8 gpm valve flow.
    It presently has a 60 inch bucket on front.I'Il probably get a 60 inch whatever I decide on but the 48 inch looks inviting, If Im more looking to just grab stuff. like logs.
    Im still back ad forth about the bucket type or rake type.I can see benefits of both.The 'rake' one has a larger opening of the grapple so that is good for brush.Id think.
    I have 1/4 inch hose to the front and would have to reduce down the hydraulics. i assume this might just make it slower to open and close.
    ??It seems like it comes with 1/2 inch lines. Even all the 'regular' lines on my tractor are 3/8....
  4. #14
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by 1969grandpa View Post
    1800+ lbs.
    -512lbs now.
    Murph
  5. #15
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    1800+ lbs.
    According to tractor data you can lift 1300 lbs - the 512 lbs your grapple weighs. Too heavy imop
    Murph
  6. #16
    Join Date
    Feb 2005
    Posts
    7,544
    The Heart of Dixie
    I added 1 of these Thumb grapple 24" to my 60'' bucket. less weight on the front my 35 hp tractor
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    Honda 300 4 trax
    Yamaha Timberwolf
  7. #17
    Super Member
    Join Date
    Oct 2003
    Posts
    7,345
    Northeast, Ohio
    TC-40D SS New Holland
    I used a bolt on grapple because I didn't want to give up the use of the bucket but still wanted to be able to lift fallen trees and large rocks. I consider the grapple to be one of the most useful additions made to the tractor.
    Attached Images Attached Images
  8. #18
    Join Date
    Oct 2011
    Posts
    93
    Belton, SC
    Kubota L3540
    What data are you looking at ,Murphy? I got that info from the owners manual. I've been moving everything from telephone poles to as much brush as the grapple will hold and everything in between and have has no problems lifting anything. It struggled a little on a big stump with roots and dirt but only because I couldn't get a good grip on it. I had to carry it really low. Aside of that, this is a 72", the OP is looking at a smaller grapple and you'll be hard pressed to find one much lighter than 512 lbs.
    From the kubota website "FRONT LOADER PACKAGE (1,865 LIFT CAPACITY AT PIVOT PIN)"
    Chris
    PTO generator
  9. #19
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    From tractordata.com Lift to full height (at 500mm): 1,360 lbs [616 kg What loader do you have?
    Murph
  10. #20
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    Just wondering , when the rate lifting capoacity is that with any bucket all? Mine weights aroud 450. and I figure it wouldnt be any difference with the grapple.The bucket would be off when I use the grapple.
    I also like the thumb idea.its refreshed my mind now.
    I might consider that.thanks for jogging my mind lol
Similar Threads
  1. Grapple Rake versus Grapple Bucket for handling brush
    By tommcintire in forum Owning/Operating
    Last Post: 01-08-2013, 10:09 AM
  2. Loader 60" or 72" grapple rake on JD 110 TLB?
    By mechatgsk in forum John Deere Owning/Operating
    Last Post: 03-11-2012, 12:17 AM
  3. Controlled Study - Root grapple vs. Light Duty Grapple Rake
    By Mr. 5000 in forum Owning/Operating
    Last Post: 08-13-2010, 07:35 PM
  4. Grapple New Grapple - pictures working - Light Duty Grapple Rake
    By scuvnut in forum Attachments
    Last Post: 07-03-2009, 12:32 AM
  5. Grapple Grapple Rake or Grapple Bucket?
    By sparkkky in forum Attachments
    Last Post: 04-24-2006, 11:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
