I would still lean towards the TYM 233 series and it comes with a loader, cab option too.
Model T233HST
Engine Manufacturer Mitsubishi
Engine Model S3L
Engine HP(kw)-Gross 23(16.9)
PTO HP(kw) 17.4(15.9)
Rated engine speed 2700
Number of cylinders 3
Displacement-cu.in. (cc) 68.7(1125)
Air Cleaner Dual Dry
Alternator 12V.50A
Fuel System Type Indirect Fuel Injection
Powertrain T233HST
Transmission type HST
Number of Speeds Infinite / 2 Range
MaxTravellingspeed,mph(km/h) 10.5(17)
Brakes Wet Disc
Steering Hydrostatic
Clutch N/A
Hydraulic system T233HST
Pump type Dual Gear Pump
Implement pump cap.gpm(L/Min) 5.0 (18.9)
Steering pump cap. gpm (L/Min) 2.6 (10)
Max Total flow gpm (L/Min) 7.6(28.9)
Category, 3 Point Hitch 1
Hitch lift capacity, lb. (kg) 1534(700)
at 24 inches behind link ends, lb(kg) 1102(500)
Lift Control type Position
Joy Stick Valve Standard
No. of standard remote valves-option 1
PTO T233HST
PTO Type Independent
PTO Control Electric/Hydro
PTO Mid (rpm)-Option 2000
PTO Rear (rpm) 540
PTO Shaft Diameter in. (mm) 1 3/8 (35)
Capacities T233HST
Fuel Tank, U.S. gal. (L) 6.6 (25)
Cooling system U.S. qt. (L) 9.3(8.8)
Crankcase (witd filter) U.S. qt. (L) 6.0(5.7)
Trans & Hydr. System, U.S. gal. (L) 9.5(36)
Front Axle qt. (L) 8.6(8.2)
Dimensions T233HST
Overall lengtd, in. (mm) with 3P 107.8(2740)
Overall widtd, in. (mm) 52.8(1342)
Wheelbase, in. (mm) 58.3(1480)
Height to top of ROPS, in. (mm) 97.2(2470)
Min. Ground Cleareance, in. (mm) 7.71(196)
Min. Turn Radius, in (mm) witd Brakes 98.5(2502)
Min. Turn Radius, in (mm) w/o brakes 105.5(2682)
Standards and Weights T233HST
Industrial Front 23x8.5-12
Industrial Rear 12x16.5
Roll Over Protection Standard ROPS
Total Weight, lb (kg) 2028(920)
T233/T273/T293 Cabin Cab
Height, in. (mm) 66.9 (1,700)
Width, in. (mm) 44.5 (1,130)
Length in. (mm) 54.7 (1,390)
Weight lbs (kg) 220.5 (100)
Working Lamps Front 2
Working Lamps Rear 1
Room Lamp Standard
Front Window Wiper Standard
Doors 2
Floor sealing Standard
Rear Window (Open/Close) Standard
Heater (Front Air Vent) 2 Outlets
