Results 1 to 10 of 12
11-12-2012, 10:39 AM #1
The ""THUMB""?
I was just wondering if anyone has this
The Thumb. And mostly interested in if the base plate has bolt holes or is that what id have to add when I get it??
My thought is if It can be bolted that I can use it on more than one unit.
Thanks..Cant seem to find many pics at the site.
Al
11-12-2012, 11:29 AM #2Elite Member
- Join Date
- Sep 2009
- Posts
- 3,185
- Location
- Murray, KY
- Tractor
- 265 MF / JD 310B Backhoe
Re: The ""THUMB""?
Thumb mounting base
Looks like you just buy more base plates for swapping to different units.
I know adding a thumb to the back hoe was most useful add on ever purchased.
11-12-2012, 11:44 AM #3Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Re: The ""THUMB""?
It looks like it is designed to be welded on, but by drilling some holes on each side of the swivel points, I believe that it could be bolted on. I think I would add some angle or channel to the top of the FEL bucket prior to attaching it just for extra strength. If you dont have a welding machine, I think that could also be bolted in several spots also. Use large thick washers on the underside.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
11-12-2012, 12:49 PM #4Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,481
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Re: The ""THUMB""?
I welded one of these thumb kits for my BH
CDP-Backhoe.com -back hoe thumbs kits, 6 model available from $139.00
CDP backhoe > backhoes & thumb kitsJ.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
11-12-2012, 05:08 PM #5Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,476
- Location
- north of upstate ny
- Tractor
- Kubota L4240 HST Cab
Re: The ""THUMB""?
I have one.I welded an angle iron to the top of my HD bucket and tacked the nuts to the underside.The Green Machine's Thumb has bolt holes.I can easily remove the whole thing if required.
11-12-2012, 05:30 PM #6Elite Member
- Join Date
- Sep 2009
- Posts
- 3,185
- Location
- Murray, KY
- Tractor
Re: The ""THUMB""?
Is it electric operated? Their web site said they were now black power coated. Looks very nice the way you mounted it.
11-12-2012, 07:12 PM #7Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,476
- Location
- Tractor
Re: The ""THUMB""?
I had the Kubota "third function" installed on my tractor.About $1,000.So it's hydraulic operated by a additional electric valve.
11-12-2012, 08:08 PM #8Veteran Member
- Join Date
- Oct 2011
- Posts
- 1,829
- Location
- Monrovia, California
- Tractor
- Kubota BX25
Re: The ""THUMB""?
Do a search for " BX25 GrappleOmatic "
Regards,
Artisan
Kubota 2012 BX25 (23H.P. / 17.7pto)
14' Dump / Carson 12K Tow Trailer w/ movable Winch,
Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
Stayin' Alive (This click could save a life...)
11-12-2012, 10:00 PM #9Veteran Member
- Join Date
- Jun 2010
- Posts
- 1,063
- Location
- Somewhere north of Roseau,MN
- Tractor
- Fordson Major Diesel, Ford 1510, John Deere L111
Re: The ""THUMB""?
I also have The Thumb. I built up a base to bolt the mounting plate on, as I have a homemade bucket and it's not a standard size. The Thumb is very sturdy and has performed every bit as well as I have hoped it would. I think I can safely say I'm not babying it, and it has never even hinted at bending or breaking.
JoeFordson Major Diesel
Ford 1510
Du-Al 105 Loader
"The Thumb" Grapple
Bush Hog RBC60 Rear Blade
Woods HC54 Rotary Cutter
Tarter 5' Heavy-Duty Hinge Back Box Blade
Buhler Farm King Y600 Snowblower
11-13-2012, 06:13 AM #10
Re: The ""THUMB""?
Looks like its a good thing to have. Im curious is that a 'homemade' bucket there?
Luckily mine is pretty beefy on the top lip. Apparently 18 years ago the dealer added some metal to it when I bought it new. I didnt think much of it then. But It was a good touch for a dealer to add the extra metal to re inforce the top lip. Ive pulled and pushed with it alot and had chains hooked and surely id have bent it it it were not for the extra piece of metal he added.
Im also looking at this setup.
http://dehnerwelding.com/BigArm.html
It doesnt have the 'teeth' but is a bit wider.It says it had 1 inch pins where the thumn im not sure the size. of pins. I believe for what it is 1 inch pins would be quite hefty myself..Not sure if anyone has this setup or not.
Im also doing a el-cheapo bucket buld that will be another post here.LOLLast edited by chopped; 11-13-2012 at 06:22 AM. Reason: Spelling of cource LOL
Similar Threads
RVS "Rear View Safety" Camera install short review "pics"
By Jamming in forum John Deere Owning/OperatingReplies: 13Last Post: 03-19-2012, 10:00 AM -
Bump and go string feed vs the "pivot heads" - Lowe's "The Ugly Head"
By schiker in forum Garden ToolsReplies: 0Last Post: 08-20-2011, 08:34 AM -
Diff. between "Cold Finish" & "Hot Rolled" steel?
By beppington in forum WeldingReplies: 23Last Post: 03-03-2011, 07:45 PM -
"Home work" from "Log Splitter Hydraulic Filter, Gauge Questions"
By AKKAMAAN in forum HydraulicsReplies: 0Last Post: 02-08-2011, 01:46 PM
