Results 11 to 16 of 16
12-02-2012, 07:38 PM #11Gold Member
- Join Date
- Jul 2011
- Posts
- 321
- Location
- NY
- Tractor
- John Deere and New Holland/Ford Tractors
Re: A Kioti DK45SE(C) vs. a John Deere of compariable size.
Vince,
You make a good point. My previous post was for regular loaders and not self-leveling loaders. Yes, the 400CX's pivot pin's are at 2194lbs and the 500mm is at 2339lbs. The 400CX is a mechanical self-leveling loader so it is stronger at 500mm. When lifting something with a regular loader, the force exerted by the bucket's load tends to make the bucket want to tip outward. On a mechanical self-leveling type loader like the 400CX, the mechanical linkages causes the bucket's outward tip force to be exerted on the linkage apparatus which applies the lift force to the arms; in turn this helps to augment the loader's hydraulic lift capacity.Last edited by eagle107; 12-03-2012 at 07:28 AM.
John Deere and New Holland/Ford Tractors and stuff
12-02-2012 07:38 PM # ADS
12-03-2012, 07:22 PM #12Platinum Member
- Join Date
- May 2011
- Posts
- 702
- Location
- Trent Hills, ON
- Tractor
- Kioti DK40SE HST
Interesting, how a self-leveling loader works near full height. I think in low and mid-level lifting the DK would still lift a bit more but unless the OP is going to be moving large square bales, I doubt a couple hundred pounds is going to matter too much.
I'm interested to see how the OP compares the two. I never bothered even to look in the cabbed tractors when I was buying so I don't know how they compare.2011 DK40SE HST
12-03-2012, 10:05 PM #13Gold Member
- Join Date
- Jul 2011
- Posts
- 321
- Location
- NY
- Tractor
12-04-2012, 06:21 PM #14Elite Member
- Join Date
- Feb 2002
- Posts
- 3,375
- Location
- western,pa.
- Tractor
- John Deere 850/Kioti DK 35 with top and tilt, kl1450 fel with quick detach bucket
Vince,
Kioti DK 35/Rhino 85 backhoe
John Deere 850 72" MMM
Hustler Fastrak 54"
12-04-2012, 06:26 PM #15Elite Member
- Join Date
- Feb 2011
- Posts
- 4,164
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
I think self leveling is mainly good for pallet forks and loading hay.
Roger
My Threads
12-04-2012, 07:25 PM #16Super Star Member
- Join Date
- Sep 2005
- Posts
- 11,640
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
People tend to focus on lift to max height but that is not a task that most people do with their loaders regularly. A full bucket of just about anything other than enriched uranium ore is going to weigh much less than what any of the loaders (Kioti,Kubota,JD) are capable of lifting to full height. I suppose someone lifting big round bales would want to be able to lift those higher than a pickup for storage but there aren't too many other really heavy loads that tend to get lifted high. To me the best figures would be total lift to pickup bed height and breakout force. I use breakout force all the time when grappling stumps. Moving heavy stuff up four or five feet for transport is also a common task. The reason I make this point is that the geometry that favors a high lift to full height may well not be optimal for maximum middle height lift or breakout. If I recall correctly the Kubota LA852 loses to the Kioti KL401 at full height by a few hundred pounds or more but still beats the Kioti in breakout.
Similar Threads
Comparison 2008 Kioti DK45SE HST vs. 2011 DK45SE HST?
By jkski in forum Kioti Buying/PricingReplies: 14Last Post: 06-22-2011, 08:05 PM -
Kioti DK45SE HST
By maxx123 in forum Kioti Owning/OperatingReplies: 2Last Post: 08-06-2009, 10:27 PM -
Size of implements for a DK45SE
By warhammer in forum Kioti Owning/OperatingReplies: 18Last Post: 08-28-2008, 09:13 PM -
Comparison NH TC45DA versus Kioti DK45SE
By Dreamin_Tractors in forum Buying/Pricing/ComparisonsReplies: 2Last Post: 10-07-2007, 11:11 AM -
Kioti DK45SE HST
By tamarack in forum Kioti Buying/PricingReplies: 4Last Post: 08-16-2007, 06:42 AM
