Page 13 of 13 FirstFirst ... 310111213
Results 121 to 126 of 126
  1. #121
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    *Ford* -'47 2N - '63 4000-
    Default Re: A little bit more technical advice please
    I'm sorry soundguy, I didn't understand your last post. Are you saying the spring under the float isn't necessary...?
  2. #122
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    think of it as optional
    souNdguy
    sent from my NOKIA LUMIA
  3. #123
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    Ok, I guess I will take the carb apart again and look it over again. I did read in a form somewhere (i think ytm) that you had replaced one of your carbs I believe on a 600 series that was badly pitted. What areas inside were bad?
  4. #124
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Quote Originally Posted by MickeyC View Post
    on my 660, the oem small carb was just eroded to bits.. like swiss cheese. was when ethanol gas first hit florida, and was after it sat that winter. was green coroded inside.
    eroded out unde rmany of the ports for setas and whatnot.
    Needing that unit that day.. I put on a ms repop carb for a 601. different ear spacing. i used a file to slot my oem manifold so the new wider spaed cab studs would fit...
    no issues...
    souNdguy
  5. #125
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    Ok, I don't believe my carb to be anything like you describe with your 660. I have read and re-read so I will go through the carb again and re-check flow. Although I am not sure how else to check flow other than the method I already tried...? Am I possibly missing anything else? Thank soundguy.
  6. #126
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    flow thru botom of carb tells you about screens and flaot valve.
    souNdguy
Similar Threads
  1. Mowing I can use a bit of advice
    By epictx in forum Case-IH
    Last Post: 03-28-2016, 06:56 PM
  2. Replies: 6
    Last Post: 07-08-2012, 11:26 AM
  3. A bit less sport, a bit more utility?
    By KentT in forum ATVs & Utility Vehicles
    Last Post: 05-28-2009, 05:18 PM
  4. Logging tongs...need a bit of advice.
    By adegiulio in forum Attachments
    Last Post: 07-19-2003, 11:56 AM
  5. Technical Question
    By BigE in forum Kubota Owning/Operating
    Last Post: 05-14-2001, 04:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
