Page 7 of 13 FirstFirst ... 45678910 ... LastLast
Results 61 to 70 of 126
  1. #61
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,624
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: A little bit more technical advice please
    smoke on throttle up is likely valve guides.
    at least you know the top end is oiling.
    gen sounds like a 6v...
    DO check gov for adjustment. wrong spring tension will cause hunt and bounce.
  2. #62
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    *Ford* -'47 2N - '63 4000-
    Thanks Soundman. I went to the dealer today to get some parts for my finish mower and got a Ford/NH genuine parts rotor for the distributor, so I will try it and see what I come up with. Still ran great today with your masking tape trick. Yeah I have a feeling the govenor linkage needs to be adjusted. Like I said when I got it, it was missing a spring and the throttle wouldn't hold pass half throttle without holding it by hand. The battery trickle charged for about 32 hours and when put back in today, she fired right up and re-fired a couple more times after that... Thanks soundguy. I will get to that linkage and let you know.
  3. #63
    Join Date
    Mar 2002
    Posts
    52,624
    Central florida
    if you didn't get the 6$ oem clip.. that oem rotor likely won't fit any better than a tisco one. unless you leave the masking tape on.. then it will likely work fine.
  4. #64
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    Soundguy, the rotor I bought doesn't seem to have any place/spot that I can see or saw on the IPL at the dealership where a clip would go...? Maybe you can tell what/where I am overlooking. This rotor is just black plastic push on type from what it looks like...
  5. #65
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    The clip is basically a steel spacer that slides over the top of the distributor shaft to take up the slop, they all need this clip it is just the way they are built.
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  6. #66
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    Thanks Guesseral, that's makes sense... I will have to see if I can the find that clip/space on an IPL.
  7. #67
    Veteran Member kf4uda's Avatar
    Join Date
    Apr 2009
    Posts
    1,067
    Middle TN
    NH TD5030, 861 Ford Powermaster, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
    Here is a link to a diagram of the distributor. The clip is item #38:
    Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
    Here is a link to purchase one or at least see a better picture:
    Ford Electrical System 8N12213 Rotor Clip
    Good luck
    Chris
  8. #68
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    Thanks kf4uda, I was able to view the second link of the part, but not the NH IPL link for some reason. I have tried that part look up before and had no luck either. I get the point from the pic on that second link, and I know for sure I do not have that clip on the distributor drive shaft. Appreciate the links and help, thanks.
  9. #69
    Join Date
    Apr 2009
    Posts
    1,067
    Middle TN
    Not sure why the link is not working for you but here is a screenshot of it.
    A little bit more technical advice please-ford-4000-dist-jpg
    Chris
  10. #70
    Join Date
    Nov 2012
    Posts
    60
    Fort Mill, SC
    Thanks Chris, that's the ticket. Looking at that diagram.... I need to go out and check, but I think I am missing a couple other things too. The gasket for sure. I appreciate the diagram.
Similar Threads
  1. Mowing I can use a bit of advice
    By epictx in forum Case-IH
    Last Post: 03-28-2016, 06:56 PM
  2. Replies: 6
    Last Post: 07-08-2012, 11:26 AM
  3. A bit less sport, a bit more utility?
    By KentT in forum ATVs & Utility Vehicles
    Last Post: 05-28-2009, 05:18 PM
  4. Logging tongs...need a bit of advice.
    By adegiulio in forum Attachments
    Last Post: 07-19-2003, 11:56 AM
  5. Technical Question
    By BigE in forum Kubota Owning/Operating
    Last Post: 05-14-2001, 04:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
