Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
  1. #31
    Platinum Member JohninCT's Avatar
    Join Date
    Jul 2001
    Posts
    910
    Central CT
    Struck Magnatrac 6000, Kioti DK40SE
    Default Re: Cordless impact wrenches
    Quote Originally Posted by bcp View Post
    That's cool. Here's a video of it
    Swench Wrench Operation - YouTube
    "I don't do landscaping... I do battle with vegetation"
  2. #32
    Join Date
    Mar 2009
    Posts
    1,029
    Lee, IL
    John Deere 1070
    Quote Originally Posted by 94BULLITT View Post
    I know they make their own air tools.
    souix also makes a lot of their air tools. Their drills (which are outstanding) are souix, and their die grinders may be as well. I haven't figured out their impacts yet, I think they may be CP, but not sure.
    as others have stated, for price I would go with dewalt, especially because you have batteries that will work on other things. I have yet to be disappointed with anything dewalt. If you have the money, check out the snap-on. The ingersolls look interesting as well, and I would look into those if I didn't care about battery compatibility.
  3. #33
    Elite Member 94BULLITT's Avatar
    Join Date
    Feb 2011
    Posts
    3,853
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    Quote Originally Posted by mikehaugen View Post
    If they own Souix then they kind of make their own.
  4. #34
    Veteran Member brain55's Avatar
    Join Date
    Jan 2008
    Posts
    1,193
    Brentwood, CA
    Default
    That's what I was thinking too.
  5. #35
    Join Date
    Mar 2009
    Posts
    1,029
    Lee, IL
    John Deere 1070
    not to start a debate here, as it is not relevant to the topic, but Ford Motor Company used to own Volvo, does that mean a Volvo s80 is made by Ford? I know some people consider it the same thing, I don't though. Many companies own other companies but have no bearing on the manufacturing process, especially in the tool world. Check out Apex Tool Group, lots of companies under the same parent company- though very different tools at very different degrees of quality. Just my opinion... yours' may differ.
  6. #36
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    I have 4 Milwaukees.
    1/4" Hex & square grive
    3/8" square drive
    1/2" Square drive.
    All are the newer 18 volt Lithium Ion
    The 1/2" is 450 ft/lbs.
    I think that is under rated / what a work horse.
    I too have been using it more than my composite 1/2" IR2131
    Just wish it had a variable torque setting.
    It is so darn easy to over torque bolt with it at first.
    I am going to invest in some pre-set torque sockets.
    Accutorq (ACC10-0322) 10 Piece Lug Nut Torque Socket Set - Amazon.com
    Check CPO milwaukee for great deals
    http://www.cpomilwaukee.com/milwauke...efault,sc.html
    CPO has other web sites like Metabo, Skill, Bosch, Dewalt
    http://www.cpooutlets.com/
    I have bought mfg refurbished and they work and look like new.
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  7. #37
    Join Date
    Feb 2011
    Posts
    3,853
    Default
    Quote Originally Posted by BIG DOOLEY View Post
    3/8" square drive
    1/2" Square drive.
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=294628"/>
    I recommend buying a quality torque wrench (snap on) instead of torque sticks, they are not that accurate.
  8. #38
    Join Date
    Mar 2009
    Posts
    1,029
    Lee, IL
    John Deere 1070
    I have always wondered how these work, it is usually not very clear. Are they simply made to different "springyness" and absorb impacts past a certain point, or what? Also, how inaccurate are they? For things like wheels, wouldn't +/- 10% be acceptable, or are they worse than that?
  9. #39
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    I have 2 snap-on torque wrenchs 1/2"
    Also a 3/8"
    OTC 1/4"
    I just like to spin bolts/nuts up quick close to torque with a gun and final hand torque always.
    The Milwaukee is so darn fast and powerful I have shot past the spec. needed.
    I have learned to be quicker with the trigger and short bursts.
    With the air gun I would just turn the regulator down
    There is no adjustment with the milwaukee, but the portability is great.
  10. #40
    Join Date
    Feb 2011
    Posts
    3,853
    Default
    They are supposed to kick back at a specified amount of torque. The problem is if you have a good strong impact it can over come the torque stick and over torque. I have seen some wheels torqued in excess of 180ftlb and it was supossed to be 100. With a torque stick there are too many varibles like the operator, impact, air pressure(or I guess now days battery charge), and the torque stick itself. Yeah +/- 10% would be acceptable for a wheel, it is not like it is a internal engine part but at the same time a wheel is a safety matter so I would not trust a torque stick. If a wheel falls off it could kill somebody. These tire shops and inspection stations that use torque sticks also warp alot of rotors. I always pull a torque wrench on a wheel.
Similar Threads
  1. Opinions on Electric Impact Wrenches
    By Gordon Gould in forum Owning/Operating
    Last Post: 06-13-2011, 06:46 PM
  2. Cordless Impact Driver
    By bigtiller in forum Related Topics
    Last Post: 12-06-2009, 09:17 PM
  3. Big impact wrenches
    By tractorman1234 in forum Rural Living
    Last Post: 08-23-2008, 04:52 PM
  4. Cordless impact wrenches
    By RickB in forum Parts/Repairs
    Last Post: 01-23-2008, 03:55 AM
  5. Impact and Torque Wrenches
    By glennmac in forum Attachments
    Last Post: 04-21-2002, 01:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
