Results 31 to 40 of 50
01-05-2013, 12:30 PM #31
01-05-2013 12:30 PM # ADS
01-05-2013, 12:41 PM #32Veteran Member
- Join Date
- Nov 2011
- Posts
- 1,127
- Location
- Near Winnipeg, Mb, Canada
- Tractor
- John Deere 2305, 2320,Z465
Re: Minimum $$ investment to mow 3 ac of pasture
I think your question about damaging a mid mount mower (mmm) on rough terrain can be summed up like this. A mmm craftsmen type mower will be destroyed before the warranty is up. A mmm on a Kubota type machine are far superior to the craftsmen(not even the same league). the Kubota type mmm will stand up but its not the best either. A 3ph mower will be best. Bush hog is the right machine for rough areas. From my experience, I used a Farm king rear discharge rear mount 3pth mower to recover about 8 acres of coarse grass. It wasn't a pasture but not far from it either. After 2-3 years the grass was much nicer and thinner. I was able to spread dirt in the rough areas and now I use a zero turn mower. I don't know that's where you want to go. I think a rear finish mower will take care of your smooth and rough area. Keep in mind anything that's 3 ph mounted will not be nimble.
Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
01-05-2013, 12:41 PM #33Super Member
- Join Date
- Feb 2008
- Posts
- 7,869
- Location
- somewhere usa
- Tractor
- stuff
I think that Kubota would be a poor choice for the field in the picture. Not enough ground clearance, get something with taller wheels, gear would be fine since it is open field mowing. Something like a deere 790 comes to mind or similar Kubota, Massey or Ford. I mention the Deere 790 only because I am familiar with Deere models more than the other brands, these were cheap and simple tractors.
01-05-2013, 12:50 PM #34
That field looks like it was potato rows that never got reworked and just grew back with wild grass . You might have a problem getting any one to cut that , I'd want to rip that up and level it .
01-05-2013, 01:12 PM #35Super Member
- Join Date
- Feb 2008
- Posts
- 7,869
- Location
- somewhere usa
- Tractor
- stuff
I was wondering about that too.
If it were to be smoothed with a land plane then the Kubota would work. I have never been a fan of flooding fields as it seems to be a waste of alot of water. I would say I am not familiar enough with the climate in this locale to pass judgement but it is very likely the OP could smooth this up and mow afterwards with just about anything.
01-05-2013, 02:00 PM #36Elite Member
- Join Date
- Feb 2011
- Posts
- 4,172
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
Roger
My Threads
01-05-2013, 04:30 PM #37Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,524
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
mid mount finish mowers are harder to find for many machines.. though you might find a farmall with a IH belly mower. I have a cub with one.. a 44"'er
finish mowers will get beat up by rough pasture.
I'd simply get a 5' mower and just not tear around like speed racer when mowing the first pass around the perrimeter.
used tractor is like a used car.
test it.
start good?
oil pressure good?
seem to have power?
leaks?
steering good?
oil in water? water in oil?
ask to test it out.. pto, lift.. etc.
an honest seller won't balk at that type of request.
01-05-2013, 05:43 PM #38New Member
- Join Date
- Jan 2013
- Posts
- 14
- Location
- Idaho
- Tractor
- Bobcat CT235
Great post, thanks! It's gonna get printed out. I will need to figure out what the "crankcase ventilation blow-by" is, lol.
Those are funny comments on the hay field! I am fairly sure it's supposed to be like that, and it doesn't look different than my neighbors. In fact, the previous owner mentioned he had it re-corrugated last year when we were walking around the place. My wife was reading your posts and said "YES!!" when she saw the idea of smoothing it out. Again, though, I don't know how that could work given the ditch irrigation. If any irrigation experts have an idea...
01-05-2013, 05:52 PM #39Gold Member
- Join Date
- Jul 2011
- Posts
- 356
- Location
- Mabank Texas
- Tractor
- Mahindra 4025
For 3 acres a high end zero turn might work well for you.
01-05-2013, 05:56 PM #40Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,524
- Location
- Central florida
- Tractor
if that's all he ever wated to do was mow grass.
I reccomend a nice padded chair and seatbelt if the pasture is as said... and it will beat the ztr to death
Similar Threads
Disk and pasture renovator and Horse Pasture?
By HoustonBrama in forum AttachmentsReplies: 8Last Post: 08-03-2008, 09:54 PM -
do you mow your horse pasture?
By RussMan in forum Rural LivingReplies: 10Last Post: 08-01-2008, 11:44 AM -
To mow or not to mow septic drain field
By adlertom in forum Rural LivingReplies: 5Last Post: 09-01-2004, 11:47 PM -
when to mow horse pasture
By mjhoover in forum ProjectsReplies: 6Last Post: 05-17-2002, 10:50 AM
