Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: 2WD vs 4WD Food plot and slopes
    I also prefer a disc for tractor. Folks with tillers usually overtill and get the soil so laden with air that it dries out too fast and generally is not usefull for planting when in that condition. A dics wont do that no matter how many times you go over it. Tillage should be done to the minimum to chop up all the vegetation and to a usuable depth loosen up the soil which doenst need more than 6-8 inches of working depth.
    A 40 HP 2WD tractor should pull an 8 foot disc in all but the most demanding conditions. One can alway raise up the cutting depth to lighten the load if needed.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Super Member
    Join Date
    Feb 2008
    Posts
    7,869
    somewhere usa
    stuff
    Gary,
    I have had good luck with tillers, no problem with their use for seedbed preparation. My point is that while disks are fine they are better suited to heavy tractors since the big requirement is to have enough draft to utilize them properly. The modern CUT's are light tractors which is suitable for using tillers and at the same time is better for mowing tractors too. When I had 4020's and a Case 1370 I used chisel plows and disks but that is a different world from today's small 1 ton tractors. Using the pto power to get the work and hp to the ground via a tiller just makes sense.
    First picture is my rear lawn and the second and third are one of my customers lawns. Tilling seems to work for me.
    Attached Thumbnails Attached Thumbnails 2WD vs 4WD Food plot and slopes-house-002.jpg   2WD vs 4WD Food plot and slopes-taylor-seedbed-1-31-2911   2WD vs 4WD Food plot and slopes-taylor-lawn-002.jpg
  4. #23
    Join Date
    Jan 2012
    Posts
    203
    Great North of Michigan
    Kubota L2500, Oliver Super55
    I have both a tiller and a disc. Both have there pluses and benefits. For doing a garden or soil where I know there's nothing to break my tractor the tiller is great but for doing my food plots the disc gets that chore. I don't need a refined seedbed, can roll right over stumps and don't have worry about unwinding barbed wire or anything else buried in the soil.
  5. #24
    New Member
    Join Date
    Dec 2012
    Posts
    1
    Latvija / Aizkraukle
    Yanmar F155 4WD
    Forgive me for my bad English, I use translator.
    In my case, is clearly better than 4x4 2x4. For example, I was working in a small town being accessible their allotments but also in neighboring gardens and even as I have created a small business. Was working the land for those who call me and are willing to pay for the service.
    Every client is different circumstances, different cultivable fields. Another is wetter and purvaināka land, another bigger hill or valley. Viemmēr is right at your fingertips when a lever with which you can switch on the front axle.
    If the front axle does not use the fuel consumption and tire wear is not so great. I have a Yanmar F155 4WD
  6. #25
    Gold Member dntfxr's Avatar
    Join Date
    Aug 2007
    Posts
    286
    north Louisiana
    Deere 2040,Ford 3610, Kubota b7100, Komatsu D20P-6
    Default
    I have both larger 2wd and a smaller 4wd tractor, also a disc and tiller. I have to agree the disc is the right tool for fields and foodplots, the tiller is better for gardens IME. As far as the tractors go, the larger 2wd works circles around the small 4wd in almost every way. I've only stuck the 2wd once and that was when I first was learning its limitations with a very large load in soft saturated muddy ground.That said the small 4wd is great for very tight quarters, such as at my deer lease on small trails, or mucking out stalls. These tractors are on opposite ends of the spectrum, yet they cost very similar money. All said, I'd recommend a nice older 2wd in the 40-50hp range and spend the rest on implements.
    '76 John Deere 2040 -mowing tractor
    '83 Ford 3610 -loader tractor
    '94 Kubota B7100 mfwd HST -garden tractor
    Komatsu D20P-6 -earth mover
  7. #26
    Super Member
    Join Date
    Feb 2008
    Posts
    7,869
    somewhere usa
    stuff
    How small a plot needs to be to utilize a tilller depends on the size of the tiller. If you use a large tiller you can cover alot of ground, if all you have used is a small tiller you think garden only. Same with a disk, a small one can't get as much done as a large one.
    For the small property owner it isn't always practical to have both a disk and a tiller. I do most of my work now in small plots of about 5 acres or less so a small tiller works well. My point though is that a large tiller about 13' wide can cover alot of ground and is capable of more than just a home garden. It seems that most members think of a tiller only for little jobs and I am just dispelling this myth.
  8. #27
    Elite Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    3,021
    From Vt, in Va, going to MS
    Kubota's - B7610, M4700
    Quote Originally Posted by jenkinsph View Post
    <snip> My point though is that a large tiller about 13' wide can cover alot of ground and is capable of more than just a home garden.<snip>
    And how big a tractor is needed to run a 13' tiller? 100HP? And how much would a 13' tiller cost? 13K?
    I think most of the discussion here was oriented to lower cost solutions.
    My rides - '95 Kubota M4700, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, new Woods BH70-X w/ 16" bucket and Woods thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, Winco 12KW PTO generator, Howse plow, 5' KK tiller with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
  9. #28
    Join Date
    Aug 2007
    Posts
    286
    north Louisiana
    Default
    A disc is pretty foolproof too, easy to maintain and in unfamiliar ground much less failure prone. I've hit big roots, rocks and chunks of concrete with both and the disc is much less trouble. But there is definitely a lot of overlap between the two implements and ain't nothin purtier than fresh tilled ground! Best solution? Get the bigger 2wd and get both implements!
  10. #29
    Super Member
    Join Date
    Feb 2008
    Posts
    7,869
    somewhere usa
    stuff
    Quote Originally Posted by newbury View Post
    I think you are missing the point. The point being that tillers are not just for your home garden.
    Large disks and large tillers are both expensive as are large field tractors. Small tillers and small disks are quite a bit cheaper and similarly priced.
  11. #30
    Super Member
    Join Date
    Feb 2008
    Posts
    7,869
    somewhere usa
    stuff
    Quote Originally Posted by dntfxr View Post
    Dntfxr,
    Don't get me wrong as I like both disks and tillers and have found that both do a pretty good job. Growing up in Louisiana with so much rain I remember how often disking had to wait for the ground to dry out enough so that we didn't get stuck. Didn't have a tiller back then but now wish we did. We had an Amco offset wheel disc and a deere 100 series disc harrow for the smaller tractors Farmall M and 3020 diesel. These did a good job for us and no complaints.
    Today having to use my 4520cut, 110tlb and 820 traversing finished lawn areas on a frequent basis the heavy tractors with filled tires would be a problem. Along with being easier to transport to and from jobs and not needing the high draft is a good choice for the lighter tractors. I should also mention that it is alot easier to change a tine that a disc blade if you were to break one. I have broken more disk blades than tines but would say that both a tiller and a disc are tougher than most think.
Similar Threads
  1. Food Plot Screen
    By Smallplot in forum Food Plots
    Last Post: 07-05-2012, 11:53 AM
  2. Fawn in my food plot.
    By Avondale in forum Food Plots
    Last Post: 09-30-2011, 12:48 PM
  3. A little food plot
    By Varmintmist in forum Food Plots
    Last Post: 09-28-2011, 06:56 PM
  4. Food Plot time again..
    By RobJ in forum Food Plots
    Last Post: 09-28-2011, 06:49 PM
  5. A little food plot
    By Varmintmist in forum Owning/Operating
    Last Post: 09-18-2005, 07:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
