Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,116
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Default Re: Need a tractor to lift a ton on the 3 pt
    The Woodmizer is and will be "ground mounted".
    Need a tractor to lift a ton on the 3 pt-8x6sam_0378-jpg
    I only need to lift the log a foot or so. I used the 3 pt with shorter logs when I had the Satoh 670, worked great.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  2. #22
    Platinum Member ddb123's Avatar
    Join Date
    Oct 2011
    Posts
    529
    Southwest MO
    Bad Boy MZ 42"
    Default
    Doesn't the loader on the DK40 lift 2700 lbs? That would be as cheap as an L3240 I'd bet.
    1985 Ford F-350 6.9L diesel
    Bad Boy MZ 42"
    Kubota L3540 HST *gone!*
    Kubota L4300 Gear *gone!*
  3. #23
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Mahindra -------------
    Due to your application, I think you would be better off with a bit heavier tractor. Check the specs on a Mahindra 4530.
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  4. #24
    New Member
    Join Date
    Dec 2010
    Posts
    7
    North Carolina
    John Deere 4300 HST
    Yes, that is what my JD 4300 will lift. I have lifted some mighty large white oak trees and drug them out with the 3pt and a large chain.
  5. #25
    Gold Member Trials's Avatar
    Join Date
    Dec 2012
    Posts
    274
    ontario
    NH Boomer
    Put some wheels on it like this guy did ...but even bigger
  6. #26
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I like Trials suggestion above particularly if you can set up to back over your carriage. A smaller tractor would work and you can keep the wood cleaner by not dragging in the dirt. Should be better for the saw. Otherwise, something as simple as a Carolina engine lift or overhead hoist could lift the logs at the saw.
  7. #27
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by Johndeere3720 View Post
    A lot of good suggestions on here. I'm not sure if you thought of it but I think a skid steer would do the job. I use my 317 Deere to remove logs from the woods, all 8 ft long and ranging from 12"-24" in diameter. I usually will move several logs at a time (2-4), all using 48" pallet forks. Used construction machinery is cheap right now, I priced out a new 318D and they wanted $33k for one, so I got my 317 for 1/3rd the price with 1000 hours on it. Plus skid steers are very maneuverable which is priceless in the woods. Check out your local craigslist/dealer websites/machinery trader for prices. My 317 with the rear weights is rated to lift 2100 lbs. Just my
    I think a skid steer is a good idea. You put a grapple on it to lift the logs.
  8. #28
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    I'm afraid it's not going to be practical to lift 2,000lbs on the 3pt of any compact tractor. Even a 40+ hp full-size utility tractor is going to take a fair amount of front ballast to safely lift that much. I use a 1100lb post driver on my 5203 Deere (weighs about 6000lbs with fluid in the tires) and I need front weights even for that. To lift 2000lbs I'd probably need at least 500lbs of ballast.
    So, with that said, my vote is either for a 40+ hp 2wd utility tractor or a skid steer. You could find a nice one of either for around $10K.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  9. #29
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    a 60+ horsepower tractor will the fel might on some models brands my 70 hp kubota will with 3pt but not the fel its rated 1870ibs at 800mm from the pin id would look at a mahindra tractor in the 60 hp range good luck
  10. #30
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    A New Holland Boomer 40/50 or LS R4041/4047 will lift 2,469lbs at 24" behind the link ends, and 2,755lbs at the link ends.
Similar Threads
  1. Loader M7040 can't lift a ton
    By pbooch in forum Kubota Owning/Operating
    Last Post: 01-31-2016, 09:06 AM
  2. Long TON vs Short TON vs Gross TON!!!!!!!
    By LD1 in forum Trailers & Transportation
    Last Post: 07-21-2012, 07:03 AM
  3. Harbor Freight one ton VS two ton shop crane
    By sixdogs in forum Build-It Yourself
    Last Post: 03-09-2011, 09:49 AM
  4. Replies: 8
    Last Post: 07-18-2007, 09:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
