Results 31 to 33 of 33
01-07-2013, 09:40 PM #31New Member
- Join Date
- Dec 2012
- Posts
- 21
- Location
- ontario
- Tractor
- NH Boomer
Re: Need a tractor to lift a ton on the 3 pt
BTW: the log hauler in the picture above, was being drawn by a Honda 4 wheeler
I imagine you could do a lot better with a compact tractor.
01-07-2013, 11:45 PM #32
If it's a hobby have you thought about making something? Something like an engine lift with larger wheels and instead of a cylinder to lift the logs you could make a way to attach the other end of the lift arm to the loader. The wheels could be the fulcrum and the arm can be attached to the loader (if you have a SSQA on your tractor would make it real easy). Since you don't need to lift it high you could make the lever with a 4 to 1 advantage. You could put a ballast box on the end of the lever so the tractor would only be needed to make up the small difference between the ballast and the weight.
Kubota L4240,Case 580K backhoe, Case 450 Dozer
01-10-2013, 07:18 PM #33Gold Member
- Join Date
- Apr 2012
- Posts
- 358
- Location
- Deep in the Heart of Dixie- Central Alabama and the Mississippi Delta
- Tractor
- 2003 Mahindra 3510
MAHINDRA !!!
Get you some!!!!!PROUD AIR FORCE DAD
Similar Threads
Loader M7040 can't lift a ton
By pbooch in forum Kubota Owning/OperatingReplies: 36Last Post: 08-25-2012, 10:07 AM -
Long TON vs Short TON vs Gross TON!!!!!!!
By LD1 in forum Trailers & TransportationReplies: 36Last Post: 07-21-2012, 07:03 AM -
Harbor Freight one ton VS two ton shop crane
By sixdogs in forum Build-It YourselfReplies: 7Last Post: 03-09-2011, 09:49 AM -
1990 3/4 ton Suburban, Lift Kit, Swampers, 4.56 gears
By HHR in forum Private Party AdsReplies: 0Last Post: 01-19-2011, 09:08 AM -
backhoe+8 ton jack+3 ton come-along= minus one stump
By irwin in forum ProjectsReplies: 8Last Post: 07-18-2007, 09:10 PM
