Results 11 to 20 of 26
01-08-2013, 08:14 PM #11Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,956
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Re: New Kubota M7040 HDC + Implements
You guys that don't like the self leveling loaders realize that with Kubota they are hydraulic and you can turn it off and on. What is there to not like?
If it was mechanical, I would not want one either.
01-08-2013 08:14 PM # ADS
01-08-2013, 08:45 PM #12
01-08-2013, 09:20 PM #13Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,956
- Location
- Tractor
Some people just don't like it. My brother hates mine, I like it. I do wish that mine would be able to turn off and on like the Kubota units do though.
01-08-2013, 09:47 PM #14Veteran Member
- Join Date
- Dec 2010
- Posts
- 1,771
- Location
- SW VA
- Tractor
- David Brown 885, Kubota RTV 900, Kubota 9540
When all I'd ever spent time running was non leveling I thought self leveling was pointless. When I started using loaders with self leveling I hated it. Then after using a deere backhoe with self leveling for a while I had come to accept it. Now I've got the Kubota with the new fangled valve to turn it on and off but I've always used it as self leveling.
Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
01-09-2013, 02:34 AM #15Member
- Join Date
- Jan 2013
- Posts
- 28
- Location
- Salem, OR
- Tractor
- Case IH Farmall 95
Hey everyone,
Thanks for the great advice. My dealer just called and has now told me that they can't get me the M7040 HDC. So I have a few choices....wait for the new M7060 HDC which should be out in April or get a remaining M6040 HDC.
I dont' have to get this now but would prefer to get a 40 series tractor with the tier 3 engine (which is tried and true) instead of the new tier 4 engine. Any thoughts? Ideally the M7040 HDC would have given me a few extra hp at the PTO to run smaller hay equipment. Most of the mower/conditioners and small square balers tend to require about 50 hp at the PTO. Technically the M6040 HDC should run it fine....but is getting the M6040 HDC a mistake?
As you can tell, I don't have real experience at this and have tried reading books and researching on-line. But I guess the real lesson will begin once I start using the equipment.
Thanks everyone for your great advice...you guys are awesome! You have already saved me a ton. It's hard to rely only on the equipment dealer for real-life advice.
01-09-2013, 08:12 AM #16
01-09-2013, 08:24 AM #17
01-09-2013, 09:06 AM #18
Other that tier 4 stuff if its the size tractor you want. In my opinion I wouldn't down size, if anything I'd try to go a little bigger like the 8040 since you would be gaining more power mainly and have pea e of mind that you have the power when needed vs kicking yourself later especially if you are going to be haying.
I like to push buttons that I dont know what they do to find out. Theres some I wont push anymore
01-09-2013, 12:38 PM #19Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,956
- Location
- Tractor
01-09-2013, 12:56 PM #20Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,841
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
Yeah, we hated our mechanical one, but one you could turn on and off free and I'd take it. My father in law bought the one with the self leveling feature because every time someone borrowed the tractor it would come back with a bent hood and or covered in dirt etc. I finally quit taking the hood off and banging it back out, it still has a big dent from 20+ years ago.
We took the self leveling feature off the Case as it would hold more dirt without it.
Similar Threads
Operators manual for M7040 HDC
By Tx Jim in forum Kubota Owning/OperatingReplies: 3Last Post: 10-12-2012, 09:19 PM -
'11 M7040 HDC
By Tx Jim in forum Kubota Owning/OperatingReplies: 5Last Post: 10-10-2012, 06:48 PM -
M7040 HDC
By Tx Jim in forum Kubota Buying/PricingReplies: 20Last Post: 10-01-2012, 05:16 PM -
M7040 HDC & HDC-1 changeover
By Builder in forum Kubota Buying/PricingReplies: 12Last Post: 04-29-2011, 09:00 AM -
New M7040 HDC-1 price advice?
By enfield in forum Kubota Buying/PricingReplies: 15Last Post: 01-20-2011, 09:12 PM
