Results 11 to 20 of 34
01-23-2013, 09:13 AM #11
Re: Grand L 4240 for Grapple Work
The grapple is a little heavier than I wanted, but it is very well made and offered features that I really wanted. The 72" std bucket weighs about 320lbs so the grapple does cost me about 300lbs of lift. I was able to work with the grapple for about 1 hour clearing and moving brush. Seemed to work great with the limited amount of time I have been able to use it so far. I think the loader on the L4240 should be pretty comparable to the MX5100's so I don't anticipate that I would lose lift capacity, just 8 HP. Not sure if losing the HP will have much if any affect on the work I am doing with the grapple. The MX5100 does have a beefier front axle and wider R4 front tires, which in theory should help with FEL type applications. Don't know if it would be enough to notice a difference compared to the L4240 though...
01-23-2013, 09:22 AM #12
That has been my expectation, is that the 3pt hitch should raise smoothly enough to be able to feature up the box blade and spread gravel smoothly. My understanding is that the jerky 3pt hitch problem is only with the single internal cylinder design on the Standard L's and the MX models.
Has anyone ever come across a report of problems with the dual external cylinder design on the Grand L's and M's?
01-23-2013, 09:24 AM #13
01-23-2013, 09:27 AM #14
- Join Date
- Mar 2009
- Posts
- 18,915
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
I realize it is not an apples to apples comparison, but I traded my L5030 in on a L5740 for reasons other than horsepower and in normal use, I really don't find I can do anything with the L5740 that I couldn't with the L5030, both run out of traction before power. I would have bought a L5240 if a L5740 hadn't been available.
More HP can be good, but it's not always the best indicator of capability.
01-23-2013, 11:23 AM #15
01-23-2013, 01:39 PM #16
- Join Date
- Feb 2011
- Posts
- 8,975
- Location
- Virginia
- Tractor
- yes
Now is the time to add a cab to the deal.
01-23-2013, 01:58 PM #17
01-24-2013, 12:42 AM #18
Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
01-24-2013, 09:35 AM #19
- Join Date
- Feb 2011
- Posts
- 8,975
- Location
- Virginia
- Tractor
- yes
I think he will find a L4240 is more usable with the dual speed hydro. You can do just about anything in medium range.
01-24-2013, 09:36 AM #20
I am leaning toward swapping for the Grand L 4240. I really liked it when I was shopping and almost bought it then, but was lured by the additional power at a lower cost of the MX5100. Of course I would not have purchased the MX5100 if I had known that the 3pt hitch was going to be so jerky.
As long as my FEL performance will be comparable with the root grapple, I don't think I will miss the 8 HP since I don't do much PTO work.
Similar Threads
Tires Picking up Glenn's Work - R1W Tires Grand L's
By slowzuki in forum Kubota Owning/OperatingReplies: 59Last Post: 05-27-2016, 10:39 AM -
Grapple work casualty
By AirForceIP in forum Mahindra Owning/OperatingReplies: 32Last Post: 02-28-2012, 09:36 AM -
grand L 4240
By bigbull338 in forum Kubota Buying/PricingReplies: 12Last Post: 10-17-2011, 07:17 PM -
Root grapple for a Grand L 4240 / LA 854
By Tbird1 in forum AttachmentsReplies: 15Last Post: 08-17-2011, 08:56 PM -
Grapple Grapple and work lights
By Code54 in forum AttachmentsReplies: 10Last Post: 09-03-2005, 08:53 PM
