Results 31 to 40 of 69
02-01-2013, 12:43 AM #31
Well tomorrow I'm going to go check out the Rhino line. And i finally found a couple REAL Bush Hog dealers so I'm gonna check them out too.
02-01-2013, 05:24 PM #32
So I went to a few dealers today. Taylor Way was a bust. I got there and the salesman said that he had just received a new price sheet that morning and their medium duty 366 went from $1290 to $1710. The 486 that I liked went from $1890 to $2300. So I'm gonna stick with a big name. Bush hog Squealer 172 was $1800. Woods BB72x was $2095 and it looks a lot heavier than the Bush Hog. The hitch just looks kind of weak on the BH. I was wondering if anyone has had any problems in that area with their BH Squealer.
02-01-2013, 05:47 PM #33Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Re: Stoutest rotary cutter?
I thought the Squealer BH was the bottom of the line cutter from Bush Hog. I would check the specs ON LINE and compare the different models from each manufacturer then price comparable mowers. I would want a gear box at least 25 HP rated higher than my tractor or more. 1/4" plate all around including top which is where most rust out occurs and one with plenty of bracing for stiffness of deck. Also look at how the tail wheels are mounted. Some brands are really wimpy and see a lot of them bent. Look at the 3 PH brackets for robustness and make sure that they have the swivel joint so the tail end can ride up without stressing your top link. Some just have pin while the better quality have a swivel joint that allows a lot of movement up without binding anything
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-01-2013, 05:55 PM #34Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
This is one that I got rebuilt using Bushhog 307 gears, stump jumper and shaft. It is all 1/4" checker plate which is a bit thicker and heavier than regular 1/4" plate. I had the heavy dual plate type 3 PH put on and dual wheels on the tail to help it track more level on my mostly hilly terrain. Also you can see the swivel at the top link that was added to the original 3 PH frame.
02-01-2013, 10:59 PM #35
The squealer 172 is in the same class as the woods bb72x,land pride 1872 or 2072, and the rhino 172. However after seeing it in person and then seeing the woods there's really no comparison. The woods and land pride are just a lot beefier especially in the hitch. Nice rebuild on that old Hog. I don't think my tractor would pick it up but I like the way it was done.
Originally Posted by Gary Fowler
02-01-2013, 11:07 PM #36Elite Member
- Join Date
- Jan 2009
- Posts
- 3,564
- Location
- Preble County, Ohio
- Tractor
- Kubota B7800 with FEL
I went stout when my last rotary cutter and bought a Land Pride RCR1860. It was a good choice for me. I like the Woods stuff also. I have a PRD7200 RFM. Both were good choices for me.
........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
jerry clowers-a coon huntin story.
02-01-2013, 11:27 PM #37
My Kubota dealer has a guy that's thinking about trading in an RCR1872. If he does I'll probably buy it. It supposedly was very lightly used and is in showroom condition. We'll see....If he doesn't ill probably go for the Woods BB72x or the LP 2072. They look pretty heavy duty and I can afford them. Going any heavier is pushing me towards $3000 and I just can't do that right now.
Originally Posted by whistlepig
02-01-2013, 11:49 PM #38Platinum Member
- Join Date
- Apr 2011
- Posts
- 622
- Tractor
- cx70,5510,4630,5005
brown makes the toughest 6 foot cutter .best cutter for the money ,that's hard to say. i would price bush hog and john deere then rhino or land pride then woods and bush wacker then others.
02-02-2013, 12:02 AM #39
I you want a stout cutter as the title says look at the BB720. I would say that the BB72 is a good cutter but it is not up to what you say you are wanting. It fits into the category of the Landpride, King Cutter and others. A very nice unit but it is a light duty unit just like 90% of all the others mentioned.
JD 4720 - 400CX FEL, Woods BB-720 Brush Bull and BH90X backhoe, Salsco 6210XT PTO Chipper, Farmi 501 Logging Winch, Bo-Dozer Grapple, LP RBT4096, Cammond Road grader/leveler and Rankin Trash Forks
02-02-2013, 12:06 AM #40Elite Member
- Join Date
- Jan 2009
- Posts
- 3,564
- Location
- Tractor
Similar Threads
Mowing Rotary cutter leaving half cut grass on the left side of the cutter
By DON11630 in forum Owning/OperatingReplies: 16Last Post: 08-30-2012, 11:33 AM -
Rotary Cutter rotary cutter
By johnvickl in forum AttachmentsReplies: 1Last Post: 10-08-2010, 07:38 AM -
3-Point Hitch Rotary Cutter
By Richgvt in forum Kubota Owning/OperatingReplies: 12Last Post: 06-07-2010, 10:04 PM -
Rotary Cutter Help - Woods Dixie Cutter rotary cutter
By RussMan in forum AttachmentsReplies: 5Last Post: 09-26-2007, 08:14 AM -
Rotary Cutter Rotary cutter
By F350Lawman in forum AttachmentsReplies: 3Last Post: 08-05-2003, 02:26 AM
