Page 7 of 7 FirstFirst ... 4567
Results 61 to 69 of 69
  1. #61
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,665
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    Default Re: Stoutest rotary cutter?
    Quote Originally Posted by Chilly807 View Post
    That'd be me.. for one. I ended up using more chain than I thought, and the density (between each vertical strand) isn't as high as I'd like. Use nothing less than 5/16 chain, and I'd recommend 3/8 if you can swing it. The weight of the chain is ALL that's keeping stuff under the mower. To be honest, I don't know how effective it really is. The solid guards are more effective, but don't allow as good a finish on the cut. I've bent my rear guards (solid steel) from backing into stuff, I just pound 'em back out with a hammer later.
    You don't need a lot of weld to hold the chain on, just a good tack on each side. I overdid mine, as usual. I'd recommend bolting the steel bars on first, then weld the chain to them to reduce bending and distortion. I had to pound mine out flat after welding.
    http://www.tractorbynet.com/forums/a...ter-chain.html
    If you look at the density of the chain on the front of TripleR's cutter in the pics he posted in that thread, that's what you should have.
    Sean
    Thanks, the solid rubber on our LP or Woods did a poor job of keeping stuff under the mower. I still have them on our Woods and stuff flies out from under there all the time while the chains on our renter's batwing cutter keep stuff under there as he mows right by our house every once in a while. The ones on my LP do a good job of keeping stuff from flying out from under there and as mentioned gives a better cut.
  2. #62
    Veteran Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    2,010
    Missouri
    Kubota M9540, JD2210
    Sean
    Sean, thanks for posting the link. I just bought a JD1008 cutter with rubber belting. I think I'll build a set of chains using your idea as a pattern. Larry says he gets a better cut with chains and I'm all about that!! Thanks again for the link.
    Richard
  3. #63
    Silver Member dbaer78's Avatar
    Join Date
    Apr 2012
    Posts
    148
    nashville,indiana
    kubota mx5100hst
    Default
    Thanks for the link Sean. I'm definitely going to go with 5/16" or 3/8" chain. The Bush-Hog 286 we use at work uses 5/16" I think and it works well.
  4. #64
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,026
    texas
    kubota M7040 &m7040
    Quote Originally Posted by ovrszd View Post
    I got some good visual thoughts about your post. I also had a good chuckle over it. Sometimes Women think we are just totally stupid don't they?? And I guess sometimes we are....
    Yeah she cursed me alittle bit last time she found a cow pie with the Nikes.
  5. #65
    Join Date
    Apr 2012
    Posts
    148
    nashville,indiana
    kubota mx5100hst
    Default
    Well my new cutter was delivered today. I couldn't wait until things started growing again to try it out so I took it back to the back power line and did some winter shredding. The previous owners hadn't maintained it for a long time and I want to turn it back to pasture or hay. After a few hours of use I think the 172 Rhino is going to be right at home here. Seems to be heck for stout for a "standard" duty cutter.
    Attached Thumbnails Attached Thumbnails Stoutest rotary cutter?-image-3367746161.jpg   Stoutest rotary cutter?-image-171647037.jpg   Stoutest rotary cutter?-image-1356951256.jpg   Stoutest rotary cutter?-image-105607168.jpg   Stoutest rotary cutter?-image-424879967.jpg
  6. #66
    Join Date
    May 2009
    Posts
    628
    South Mississippi
    2008 John Deere 5303 MFWD
    Default
    Looks like a good place for a deer plot!
  7. #67
    Join Date
    Apr 2012
    Posts
    148
    nashville,indiana
    kubota mx5100hst
    Default
    That's another option. Good eye!
  8. #68
    Join Date
    May 2006
    Posts
    2,010
    Missouri
    Hope you enjoy your new cutter. I've got a Rhino SE6 that I've outgrown. I've not had any problems with it at all. Very good equipment.
    Richard
  9. #69
    Join Date
    Apr 2012
    Posts
    148
    nashville,indiana
    kubota mx5100hst
    Default
    Thanks. And that's what everyone else has said about Rhino equipment which is a big reason I bought one. The only thing I dislike about the cutter is the Comer gearbox is made in China but it seems like most of the gearboxes on cutters are foreign made.
Similar Threads
  1. Mowing Rotary cutter leaving half cut grass on the left side of the cutter
    By DON11630 in forum Owning/Operating
    Last Post: 08-30-2012, 11:33 AM
  2. Rotary Cutter rotary cutter
    By johnvickl in forum Attachments
    Last Post: 10-08-2010, 07:38 AM
  3. 3-Point Hitch Rotary Cutter
    By Richgvt in forum Kubota Owning/Operating
    Last Post: 06-07-2010, 10:04 PM
  4. Rotary Cutter Help - Woods Dixie Cutter rotary cutter
    By RussMan in forum Attachments
    Last Post: 09-26-2007, 08:14 AM
  5. Rotary Cutter Rotary cutter
    By F350Lawman in forum Attachments
    Last Post: 08-05-2003, 02:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
