Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    New Member farmerger's Avatar
    Join Date
    Sep 2003
    Posts
    14
    Chase, BC
    NH TC33D
    Default Re: Bigger Tractor or Add Excavator
    Great, now not only do I want a big orange tractor but I also am now suffering from shop envy thanks to your picture
    Quote Originally Posted by RFB View Post
    The kubota Grand L5740 has a very nice cab, cool in the summer and warm in the winter. It is rated:
    Engine (gross): 59 hp [44.0 kW]
    Engine (net): 57 hp [42.5 kW]
    Here's a pic of mine without the bucket or hoe mounted.
    Attachment 301758
  2. #12
    Join Date
    Sep 2003
    Posts
    14
    Chase, BC
    NH TC33D
    You got your kgs and lbs swapped, that 60D will lift 1300 kgs/3000 lbs to 10', but I see your point about height in the barn being an issue with an excavator. Oh well, I guess I'm going shopping for a bigger tractor with a cab. Looks like none of the TLBs have a cab?
    Quote Originally Posted by Grandad4 View Post
    Best I can figure, while the "compact" excavators have plenty of digging power, they don't have enough lift capacity on an extended boom to handle a 1,500 lb bale on a spear. And you might need to have the blade set for stability when raising that kind of load, so actually moving around with a bale could be a hassle. For example, a large compact like the Deere 60D, will lift 1,300 lbs, including the bucket, to 10 ft. above ground level.
    60D Excavator from John*Deere
    You'd need to get into larger equipment - probably 75 hp and up - to do better than that. If your hay barn is big enough to operate a full size excavator inside, I want to see it!
  3. #13
    Elite Member
    Join Date
    Jun 2012
    Posts
    4,004
    Waynesboro Va
    John Deere X310, JD LA 145
    Just an idea buy a used backhoe and keep your tractor. The FIL will pick up the hay and the hoe will dig the footers.
  4. #14
    Silver Member mowin's Avatar
    Join Date
    Sep 2012
    Posts
    123
    upstate ny
    JD 3320
    Dont think a EX is going to cut it for the bale work. What about a skid steer?
  5. #15
    Elite Member
    Join Date
    Jan 2010
    Posts
    2,539
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    Quote Originally Posted by farmerger View Post
    Sorry about the lbs/kg mixup... my bad. But I think you're going to be better off with a tractor for that work. No current small TLB's with factory cabs, but there are some nice add-on cabs (Laurin). Plus, I think someone mentioned there are pending updates to the kubota TLB models that will have factory cab options if you don't mind waiting. Bales would be child's play for an M59. As already noted, the big Grand L Kubota models do bale handling work for many people, along with similar equipment from the other brands. That size equipment could actually have some advantage in your application since it has a shorter wheelbase that a standard utility tractor. Plenty of ballast needed of course.
  6. #16
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    You can double-stack with a scissor on the three-point. Most CUTs will have enough lift capacity on the three-point to handle a full sized round bale, even if they won't do it on the loader.
  7. #17
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Kubota L5740HSTC3; B3000HSDCC
    You mentioned a cab, so here are some photos of the 5740 cab interior. The 3 point is Cat 1&2 and is rated at 2976lbs. I have lifted in excess of 2500 (weighed) with the FEL; it handles 1500 without breaking a sweat.
    Attached Thumbnails Attached Thumbnails Bigger Tractor or Add Excavator-img_1009-jpg   Bigger Tractor or Add Excavator-img_1010-jpg   Bigger Tractor or Add Excavator-img_1011-jpg   Bigger Tractor or Add Excavator-img_1014-jpg   Bigger Tractor or Add Excavator-img_1018-jpg
    Bigger Tractor or Add Excavator-img_1019-jpg
  8. #18
    Join Date
    Sep 2003
    Posts
    14
    Chase, BC
    NH TC33D
    Nice, thanks for the pics.
  9. #19
    Join Date
    Dec 2005
    Posts
    667
    Central Maine
    Having used both for digging holes and trenches ( and currently owning a bulldozer backhoe) the excavator digs circles around a backhoe. With a backhoe you spend a lot of time repositioning and it gets old. With an excavator and the longer boom there is less repositioning and you just drive it from where you sit which is much easier and faster. Plus, when you hit that tree root or rock or stump the backhoe will stall out and the excavator will rip it out. Once I fix the final drive on the 2010 it gets sold and I am buying an excavator.
  10. #20
    Silver Member EdK's Avatar
    Join Date
    Apr 2002
    Posts
    122
    Central NH
    Kubota M6800, Case 580E Super
    Quote Originally Posted by Ed of all trades View Post
    I'll second this idea. True, an excavator will out-dig a construction hoe if that is really the focus of the equipment. However the monster loader of the TLB is a big plus.
Similar Threads
  1. Will my tractor be ok with bh or need bigger?
    By mooch in forum Kubota Owning/Operating
    Last Post: 04-02-2011, 07:29 PM
  2. I really need a bigger tractor
    By Robert_in_NY in forum Rural Living
    Last Post: 02-16-2009, 06:10 PM
  3. The Bigger The Tractor, The Less You Use It.....
    By JimMorrissey in forum Kubota Owning/Operating
    Last Post: 08-17-2004, 08:38 PM
  4. I need a bigger tractor???
    By goatman in forum Iseki
    Last Post: 03-28-2004, 11:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
