Page 5 of 7 FirstFirst ... 234567 LastLast
Results 41 to 50 of 66
  1. #41
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Kubota L4400 Gear Ag Tires
    Default
    Quote Originally Posted by xring100 View Post
    Awesome the NH is a larger heavier tractor generally a good thing for a tractor of that size. I'm sure you'll be happy
    i looked hard at the T4000 series when i bought the Kubota at that time NH stopped building them and was gearing up the T4s i could not find one on the lots that had what i wanted. I ended up with orange instead no regrets.
    Dave
    Yeah the 9540 or any kubota really are fine tractors That I would be proud to own. I just feel the T5050 fits my needs better. And before this gets into a brand bashing thread like so many other threads have done. I think all the tractor makers make fine tractors not just NH and Kubota. Thumbs up.
  2. #42
    Veteran Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    1,382
    Central MA, Lakes Region NH
    Kubota L4610 and John Deere 410
    Default
    Quote Originally Posted by Fordman1981 View Post
    Well they came down some more on the NH so it's a done deal they are installing the loader today and should deliver it Thursday. I will post pics once its delivered.
    Wahoooo!
    Congratulations! We're all looking forward to some pics!
    Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
    Rear Remotes Install
    How to search TBN
  3. #43
    Gold Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    435
    Livingston County, Michigan
    Kubota M8540
    Default
    Quote Originally Posted by TripleR View Post
    Thanks for the information Dave, I thought I remembered someone had an 8 speed, but couldn't remember. My sons and I both operate our tractors and usually run one to two gears higher than I do or even in a different range, I really like the choices of a 12 speed, but used a four, five and six speed for many years farming. I guess it is what you get use to.
    No problem i would have liked the 12 spd and the extra 3 pt capacity but i had to draw the line somewhere. As i was already buying a tractor that is about 40-50hp more tractor than what 80% of the people on this forum would recommend and every single dealer for my usage. I was also planing ahead for the future. Prior this tractor i was using a 6 speed so 8 is still an upgrade i still have not had to ask my neighbors to use their compact tractors but they keep coming to me to use my services
    Dave
    Dave
  4. #44
    Join Date
    Dec 2012
    Posts
    435
    Kubota M8540
    Default
    Yeah the 9540 or any Kubota really are fine tractors That I would be proud to own. I just feel the T5050 fits my needs better. And before this gets into a brand bashing thread like so many other threads have done. I think all the tractor makers make fine tractors not just NH and Kubota. Thumbs up.
    Agreed they are both excellent tractors and both have their strenghts. if its going to live in the field the NH is better suited than the 9540 you would have to go to a larger kubota for fair comparison. NH has more experience building the larger tractors as this is their core business for them. Where as kubota is more into the compacts and utility tractors.
    Dave
    Dave
  5. #45
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,659
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    Default Re: Kubota M9540 or New Holland T5050???
    Dave
    Oh, I know what you mean. I use the L5740 on 90+ percent of the stuff on my home farm, but from time to time, I have to go get our M8540. I had a bad washout this spring and my son got on one side of the washout with the M8540 and I got on the other side with the L5740 and there were times the L5740 just wouldn't get it done.
    Of course I use the L5740 on the other farm too, but unless it is just convenience or clearance, the M8540 does it.
    Attached Thumbnails Attached Thumbnails Kubota M9540 or New Holland T5050???-dscn0357.jpg   Kubota M9540 or New Holland T5050???-dscn0353.jpg   Kubota M9540 or New Holland T5050???-dscn0334.jpg
  6. #46
    Join Date
    Mar 2009
    Posts
    13,659
    Missouri
    Agreed, I could be happy on orange/green/blue/red etc., no brand promotion/bashing here.
  7. #47
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    1,290
    W. Central Louisiana
    JD 5085M; NH TN70A; Ford 2600
    I think that was a wise move. The NH is a lot more tractor for the same money, since you're getting it used.
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    JD 457 round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    Don’t ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
  8. #48
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Default
    Picture sent from dealer tractor has loader on ready for clean up and delivery tomorrow.
    Attached Thumbnails Attached Thumbnails Kubota M9540 or New Holland T5050???-image-195895887.jpg
  9. #49
    Join Date
    Dec 2012
    Posts
    435
    Kubota M8540
    Default
    Very nice what size are the front tires they look wide in that shot
    Dave
    Dave
  10. #50
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Default
    The front tires are 380-85-r24
    The rear are 460-85-R34
Similar Threads
  1. Kubota M9540
    By DT86 in forum Ag Tractors & Machinery
    Last Post: 08-27-2012, 09:42 PM
  2. Buying Advice information on a New Holland T5050
    By watsonja in forum New Holland Buying/Pricing
    Last Post: 07-12-2012, 07:36 AM
  3. New Holland T5050 FIRE!!!
    By jqshaw01 in forum Owning/Operating
    Last Post: 05-12-2012, 11:34 AM
  4. Insurance New Holland T5050 FIRE!!
    By jqshaw01 in forum New Holland Owning/Operating
    Last Post: 05-11-2012, 12:19 PM
  5. Buying Advice Kubota M9540 DT-1 and M9540 DH...
    By Jet Star in forum Kubota Buying/Pricing
    Last Post: 03-20-2012, 07:28 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
