Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 66
  1. #51
    Gold Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    435
    Livingston County, Michigan
    Kubota M8540
    Default Re: Kubota M9540 or New Holland T5050???
    Impressive that explains why they look a lot wider and taller sidewall than my 12.4 R24's on mine. Its because they are Should be good with that loader in soft ground
    Dave
  2. #52
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Kubota L4400 Gear Ag Tires
    Default
    Yeah I hope this tractor turns out to be a real workhorse. She looks impressive just hope her work ethic matches her looks
  3. #53
    Join Date
    Feb 2013
    Posts
    34
    Branchport NY
    Kubota MX5100, Kubota M9540, Allis Chalmers G
    Congrats!
    Not trying to hijak the thread, but the M9540 that I checked out at Marshall Machinery in PA, was a total POS. More things broken than working. I will NOT go there again as the salesman basically lied to me over the phone and I wasted about $200 in fuel and a full day.
    Going to check out a M9540 open station in Ohio Monday with 2000 hours, 1353 loader 12 speed and 2 remotes.. Looks to have had a much easier life. It is at a green dealership and they said it is a local 1 owner trade in... $24K
    Jonathan
  4. #54
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Default
    Good luck on the 9540 I hope this one turns out to be a better tractor for you. When I looked at the 9540 it looked to be a well made tractor. I personally like the cab a little better on the T5050 though.
  5. #55
    Join Date
    Feb 2013
    Posts
    34
    Branchport NY
    Yeah cab is out of my budget.. I wasn't planning on getting a loader either (I have one on my MX5100) But this one in Ohio comes with a loader which is even better as it is 4X4 and a heavier capacity loader, and it is bobcat style QT which should be the same as my MX5100, and so it will fit the bucket I have and my homemade forks...
    Jonathan
  6. #56
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,026
    texas
    kubota M7040 &m7040
    Congrats on the tractor...
  7. #57
    Join Date
    Dec 2012
    Posts
    435
    Kubota M8540
    Default
    Quote Originally Posted by SSweet9c1 View Post
    Jonathan
    The 1353 is a monster it has 1000lbs more lift capacity than the one on the 5100 plus a bunch more lift height. I can off load 3000 lbs pallets from a semi truck. Hope it works out for you and that your homemade forks are seriously over built for the mx5100 because the breakout force on the 1353 is 4900 lbs 800mm forward of the piviot hope this one works out for you
    Dave
    Dave
  8. #58
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Default
    Quote Originally Posted by foreman Etexas View Post
  9. #59
    Join Date
    Nov 2012
    Posts
    458
    mansfield,Il
    john deere
    Will that tractor go up Carl's hill ?
  10. #60
    Join Date
    Dec 2012
    Posts
    435
    Kubota M8540
    Default
    Quote Originally Posted by kevin37b View Post
    If you put some green paint on for traction it shouldn't be a problem
    The only hill I've ever had a hard time climbing or pulling something up was a mixture of solid ice and hard pack snow on a gravel road.
    Dave
    Dave
Similar Threads
  1. Kubota M9540
    By DT86 in forum Ag Tractors & Machinery
    Last Post: 08-27-2012, 09:42 PM
  2. Buying Advice information on a New Holland T5050
    By watsonja in forum New Holland Buying/Pricing
    Last Post: 07-12-2012, 07:36 AM
  3. New Holland T5050 FIRE!!!
    By jqshaw01 in forum Owning/Operating
    Last Post: 05-12-2012, 11:34 AM
  4. Insurance New Holland T5050 FIRE!!
    By jqshaw01 in forum New Holland Owning/Operating
    Last Post: 05-11-2012, 12:19 PM
  5. Buying Advice Kubota M9540 DT-1 and M9540 DH...
    By Jet Star in forum Kubota Buying/Pricing
    Last Post: 03-20-2012, 07:28 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
