Page 7 of 7 FirstFirst ... 4567
Results 61 to 66 of 66
  1. #61
    Join Date
    Feb 2013
    Posts
    35
    Branchport NY
    Kubota MX5100, Kubota M9540, Allis Chalmers G
    Default Re: Kubota M9540 or New Holland T5050???
    lol Yeah my forks are off of a 4000# lift capacity hyster, welded to a quick tach plate with a fair bit of reinforcement to the plate.. I have an un-liftable object I can test it out on to make sure the relief valve works correctly! The added height will be a bonus too.. But the biggest advantage is the FWA, as my 5100 is 2wd, which is OK, but not ideal...
    Jonathan
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #62
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Kubota L4400 Gear Ag Tires
    I've been out of town working so haven't been home to use my new T5050 yet Ahhh work. Well I have always said I would rather be too busy struggling to keep up than sitting at home with nothing to do and no money coming in Ok so here is why I'm posting even though I'm not home to use it I am looking for stuff for it What do you guys think of this Box blade can it handle the 95 hp beast It is rated for 50hp to 100 hp but is 95hp too close to the upper limits of it's ratings? 96" Category I&II XTreme Duty Box Blade by Everything Attachments
  4. #63
    Veteran Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    1,558
    Central MA, Lakes Region NH
    Kubota L4610 and John Deere 410
    Default
    In my opinion no. Although they claim "extreme duty" it really isn't. Look at the weight of that thing, it's only 815 lbs for an 8' blade. Compare that to the "only" heavy duty (not "extreme" duty) landpride HR3584. I believe that blade is close to 1200 lbs and although not rated for 100 hp like the one you linked to, it's a whole lot stronger than that EA one.
    You have to be careful how companies rate their equipment. I find that EA rates theirs as stronger than many do and name them to sound super heavy duty when they really aren't. Just compare their specs to other HD box blades and even rotary cutters for example.
    I have a landpride HRL 3578 and it weighs 981 lbs at only 6.5' wide and also it's a low profile design. It is very well built and I would use it on your tractor but even then, you still have the power and weight to tear up a HD implement.
    Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
    Rear Remotes Install
    How to search TBN
  5. #64
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,854
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    I honestly can't say, but Piston makes some interesting observations. I prefer a 1000+ for that size tractor and use a Land Pride HR3584 weighing 1117 pounds and looks like the Woods Gannon HD24284HB Box Scraper. HD24284HB Landscape Equipment, the HD24484HSD Box Scraper is a bit stronger and you can get them stronger than that. We don't have a Woods dealer close, so I went with Land Pride and it has worked well, may not be as strong as the Woods; just don't know. I can't go heavier as I use mine on our M8540 and L5740.
    The Land Pride says it is only good for 65 HP, but is made of the same material dimensions as the Woods rate to 80 HP and no stress or strain so far. In my opinion, to get the full potential out of that much HP and weight, you are going to want a pretty heavy box blade, not knocking EA stuff, just stating some opinions.
    Good luck shopping.
    Attached Thumbnails Attached Thumbnails Kubota M9540 or New Holland T5050???-dscn0334.jpg   Kubota M9540 or New Holland T5050???-dscn0724.jpg   Kubota M9540 or New Holland T5050???-dscn0721.jpg
  6. #65
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    5,964
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    If you want the thing to work and not have structural problems, don't get anything that is less than 125lbs per foot of width. The ideal unit for you would be 1200-1600lbs
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  7. #66
    Join Date
    Jan 2011
    Posts
    223
    North Carolina
    Quote Originally Posted by MtnViewRanch View Post
    Thanks to everyone for the replies for far. The weight was a concern of mine too. The actual strength I'm up in the air on the video goes over how the built it and it seems built very strong. I'm going to look at some of the other products that people have suggested.
    MtnViewRanch,
    If you would PM me the price on the Top and tilt and the part number I will probably be looking to order in the next week or so.
    Thanks,
    Fordman
Similar Threads
  1. Kubota M9540
    By DT86 in forum Ag Tractors & Machinery
    Last Post: 08-27-2012, 09:42 PM
  2. Buying Advice information on a New Holland T5050
    By watsonja in forum New Holland Buying/Pricing
    Last Post: 07-12-2012, 07:36 AM
  3. New Holland T5050 FIRE!!!
    By jqshaw01 in forum Owning/Operating
    Last Post: 05-12-2012, 11:34 AM
  4. Insurance New Holland T5050 FIRE!!
    By jqshaw01 in forum New Holland Owning/Operating
    Last Post: 05-11-2012, 12:19 PM
  5. Buying Advice Kubota M9540 DT-1 and M9540 DH...
    By Jet Star in forum Kubota Buying/Pricing
    Last Post: 03-20-2012, 07:28 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
