Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    New Member
    Join Date
    Apr 2010
    Posts
    5
    Northern WV
    Mahindra 4025
    Default Need advice on first tractor
    First off, my property is all hill and clay. I am looking into getting my first tractor and am stuck.
    Tractor A weighs 5000lbs, is 86-90" wide, 41hp, and is 2WD.
    Tractor B weighs 2600lbs, is 56" wide, 36hp and is 4WD.
    Both come with similar FELs, though A has a little more capacity.
    A is $18,233
    B is $18,700
    My tasks would be moving the occasional round hay bale, field mowing, snow removal (not much), gravel road creation and maint, various digging and grading, and running a single bottom plow to break some new ground for various small scale gardening.
  2. #2
    Super Star Member jerrybob's Avatar
    Join Date
    Mar 2010
    Posts
    18,785
    Somewhere in Washington
    yanmar 186D....JD LT180....DR Brush Cutter
    Default Re: Need advice on first tractor
    Both would work for you but I'd go for 4wd. That feature can really make a difference depending on ground conditions. You don't mention some other important issues....like condition, number of hours, make, options like weights....etc.... All things being equal......4wd is the option I'd go for. Good luck.
    Most of the stuff people worry about.......ain't never gonna happen anyway!
    Tacocat spelled backwards is Tacocat
  3. #3
    New Member
    Join Date
    Apr 2010
    Posts
    5
    Northern WV
    Mahindra 4025
    Both are new. I guess I am really concerned about stability, and after watching my neighbor tow my f150 like it was nothing up a slippery muddy slope with his old 2wd, I am questioning whether weight and stability are more valuable. Tractor A has a 4WD version for 3500 more, but I really want to keep things under 20
  4. #4
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,676
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    It is hard to beat weight for traction. You better find out how much those round bales are, and look at loader capacity, too. I am of the school that buying bigger/heavier is better than getting one that will just barely do what you want. But it is your money...
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  5. #5
    New Member
    Join Date
    Apr 2010
    Posts
    5
    Northern WV
    Mahindra 4025
    Yea, the round bales I get are 4x4s and weigh around 700ea... not those crazy monster round bales.
    I have no brand loyalty, but the tractors in question are A: Mahindra 4025 and B: kubota L3800.
  6. #6
    Join Date
    Mar 2010
    Posts
    18,785
    Quote Originally Posted by trimpy View Post
    Both are good tractors.....good quality.
  7. #7
    Join Date
    Jan 2013
    Posts
    164
    Brookfield,Nova Scotia
    Sears GT
    go with the 4wd and I bet U'll never look back.
  8. #8
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,800
    Waynesboro Va
    John Deere X310, JD LA 145
    4x4 will give you more stability on hills, going down hill on a tractor is one time some people don't think about but with directional tires you can have a nice slide, if all goes well.
  9. #9
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    You can pretty much get "all of the above" (weight, 4WD, power, etc) + a loader with at least twice the capacity, and more standard features (remotes, work lights, etc), and stay under, or right at, $20K if you look at either Kioti or LS, and probably Bobcat (close outs, so deals can be found).
    I thought it would take a while to max out my LS, but I was wrong....even if I went two steps bigger, I still would run into situations calling for more....time to borrow the neighbors backhoe, crawler or excavator!
  10. #10
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Unless tractor B can be set out wider then 56" with wheel spacers or rim adjustments I would go with the 5000 lb - 90 " wide machine. You will have the mass to hold back loads going down your hills and the stability to work slopes much steeper then can with the very narrow 56" machine and as soon as you touch the brakes going down a hill with a load behind you it becomes a factor of machine weight times the width of the rear tires.
Similar Threads
  1. Re: Another Tractor, need advice
    By MacTractor in forum Kubota Buying/Pricing
    Last Post: 11-25-2012, 10:42 AM
  2. Tractor Advice
    By blueridgerunner315 in forum Owning/Operating
    Last Post: 11-08-2011, 12:29 PM
  3. Buying Advice tractor advice
    By fiddlehead1969 in forum Kubota Buying/Pricing
    Last Post: 06-29-2009, 08:05 AM
  4. New tractor advice
    By JerseyRay in forum Buying/Pricing/Comparisons
    Last Post: 06-14-2006, 07:31 AM
  5. Need advice for a new Tractor:)
    By kcook in forum Buying/Pricing/Comparisons
    Last Post: 07-17-2005, 12:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
