Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Re: Dump trailer, Finally decided what I am buying.
    Quote Originally Posted by kenmac View Post
    Is your trailer wired so, it will charge the dump battery from the truck when plugged in ? Mine wasn't but is now
    I haven't picked it up yet.
    We just got 12" of fresh snow last night so I didn't want to make the 1 hour trip today.
    I'm sure it is, but if not I will connect the battery to the constant 12+ lead on the cord.
    I may add a solar charger. the "Legend" brand that I had been considering came with a solar charger.
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Elite Member 94BULLITT's Avatar
    Join Date
    Feb 2011
    Posts
    4,164
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    Default
    Here is diagram of the trailer wiring. Depending on the vehicle you may have to run a wire for the charge. I think some dump trailers have a charge wire already hooked up on them.
    Trailer Wiring Diagrams | etrailer.com
  4. #23
    Super Member
    Join Date
    Feb 2008
    Posts
    7,869
    somewhere usa
    stuff
    Quote Originally Posted by 94BULLITT View Post
    Here is diagram of the trailer wiring. Depending on the vehicle you may have to run a wire for the charge. I think some dump trailers have a charge wire already on hooked.
    Good informative post, I have done business with etrailer for the last few years with good results.
  5. #24
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    I just sold my fifth wheel camper last summer.
    My truck is already set up with brake controller and 7 pin wiring harness.
    I just bought an 8 foot extension cord for the trailer harness.
    I mounted my trailer connector in the bed for the fifth wheel so now I needed a longer cord to reach to the dump trailer.
    I'm still waiting for my new receiver locking pin.
    Mailman never made it to the house with the storm today.
  6. #25
    Platinum Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    882
    Northeastern Minnesota
    M135GX, L5740, 301.5, RTV 900XT
    Default
    I think if it is a high quality trailer it will have the charge system already in place. Mine has a controller to prevent high amperage flow which might damage the wiring. It is surprising how fast I can draw down a battery on mine if I ave a short haul so it doesn't get a chance to really recharge. The controller has a green light when the battery is being supplied power from the truck, but when it reaches the heat limit it cuts out. It really shows when dumping because when the green light is on, the motor will really spin (this is with a significantly depleted battery) but when the light goes off, it slows to a crawl. I solved the problem by putting a second battery in the box (my battery box has a large tool carry space) and run jumper cables to the main battery when I'm doing a lot of short haul dumping, and especially when I use my tractor for doing the ailing because it doesn't have power for charging.
    L5740 w/FEL, 301.8 MiniHEX, RTV900, 13' tandem disk, 1 x 2 btm plow, 12' 3pt cultivator, bale spear, 7' rear blade, grading scraper, 6' KK tiller, pallet forks
  7. #26
    Super Star Member jinman's Avatar
    Join Date
    Feb 2001
    Posts
    18,990
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    The Deka Marine Battery in my Texas Pride brand dump trailer of similar size would give me 7 dumps before a recharge was needed. I would not push it that low all the time because it will sulfate up on you. I forgot and left mine mostly discharged for about 3 months and it was never the same afterward and lasted only about 2 years.
    Jim
  8. #27
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Quote Originally Posted by jinman View Post
    Dealer said the new trailer will dump 6-7 times without a recharge.
    I have battery maintainers for my truck and tractor and they are always hooked up when I am not using them.
    I have one for the new trailer also and RV power outlets on my property to plug it in.
    I will probably look for a marine shore line connector and mount it to the battery/pump box.
    Marinco On-Board Charger Inlet 150BBI - iboats
  9. #28
    Veteran Member JJZ 109's Avatar
    Join Date
    Feb 2009
    Posts
    1,037
    Chaumont, NY
    Bobcat S185 skid steer
    I got a new CAM Superline this fall. There's a built in battery charger. There's a port on the battery box to plug in an extension cord. Should be a handy feature.
    Like the OP, I have the ramps stored underneath. I also went with the combo tailgate & tarp roller. Went with 12' so that I can get a Bobcat S185 into it.
    Todd
    _____________________________________________
    "The trouble with quotes on the Internet is that it's difficult to discern whether or not they are genuine." --Abraham Lincoln
    2008 Bobcat S185 Skid Steer with enclosure, heat & A/C • Erskine model 2010 73" blower •TSC Boom Pole adapted to QA • Bradco 48" pallet forks • JLG T350 Boom Lift • 1997 Ford F Super Duty 7.3 Powerstroke w/ Altec AT 200A aerial lift • CAM Superline 6x12 dump trailer
  10. #29
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Well I took the day off and picked or the dump trailer.
    Dealer didn't have the lunette ring so I had to use the 2-5/16" ball coupler.
    I decided to order one off the internet when I got home.
    The trailer had white spoke wagon wheels but the dealer didn't have a spare to match.
    So I had them swap tires and rims from another trailer that had silver Mag Mods.
    I like the looks of them better anyway.
    I was home just after lunch and started fabricating a tarp roller.
    A replacement mesh tarp is around $75 - $85.
    I can't see why roller bearings are needed for something this simple.
    I am using 1" bar, pipe brackets and 1" sleeve collars to hold it in place.
    The trailer has been sitting outside for awhile and the silicone around the seams is weathered and peeling so I will reseal them this spring.
    Empty the truck didn't even know it was there, but there is enough tounge weight that it rode much nicer down the counrty roads.
    Dump trailer, Finally decided what I am buying.-new-dump-trailer-006.jpg Dump trailer, Finally decided what I am buying.-new-dump-trailer-007.jpg
    Dump trailer, Finally decided what I am buying.-new-dump-trailer-011.jpg Dump trailer, Finally decided what I am buying.-new-dump-trailer-012.jpg
    Dump trailer, Finally decided what I am buying.-new-dump-trailer-013.jpg Dump trailer, Finally decided what I am buying.-new-dump-trailer-014.jpg
    Dump trailer, Finally decided what I am buying.-new-dump-trailer-015.jpg Dump trailer, Finally decided what I am buying.-new-dump-trailer-018.jpg
    Tom
  11. #30
    Join Date
    Feb 2011
    Posts
    4,164
    It looks nice Tom. I like the silver modular wheels, they are favorite trailer wheel.
Similar Threads
  1. Finally decided to join
    By TOMLXIX in forum New Member Introductions
    Last Post: 11-15-2011, 05:52 PM
  2. Finally decided
    By 2002fb in forum John Deere Lawn & Garden
    Last Post: 04-13-2011, 09:55 PM
  3. Buying Advice Finally decided
    By sbohan in forum Kubota Buying/Pricing
    Last Post: 12-21-2010, 09:50 AM
  4. Finally decided on MF 1523
    By 73jeep in forum Massey Ferguson Buying/Pricing
    Last Post: 02-15-2006, 07:39 PM
  5. Finally decided on the B2410
    By seattle in forum Kubota Buying/Pricing
    Last Post: 05-18-2002, 08:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
