Page 9 of 15 FirstFirst ... 6789101112 ... LastLast
Results 81 to 90 of 141
  1. #81
    Join Date
    Aug 2012
    Posts
    955
    Hartford, SD
    Kubota L3400F
    Default Re: Compact 4wd v. Larger 2wd utility tractor?
    Quote Originally Posted by Ted Summey View Post
    RNR has the best advice, go drive some. You might even ask one of the dealers to let you demo a machine on your site. I drove tractors for a week at various dealers before making my decision. Customer service helped put the Kubota dealer at the top of the list.
    Mine is a 2wd gear model with FEL. It is light in the rear end without ballast on the hitch but I haven't gotten it stuck even on theses red clay hills during the winter. Does it spin some? sure it does but so does the 4wd Kubota M5700.
    My FIL farmed these red clay hills for nearly 50 years with 2wd tractors and never got one stuck and I have yet to get one stuck (24 years). My personal opinion is that 4wd is over rated for hobby farming. For those of you doing extensive loader work or moving snow on a regular basis it IS essential.
    To say 2wd tractors for loader work are obsolete goes a little too far. Mine works fine with ballast on the 3pt hitch.
    I built a 1,000 lb counter weight and wow...what a difference!
  2. #82
    Platinum Member Ted Summey's Avatar
    Join Date
    Feb 2012
    Posts
    556
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    I've been planning something similar built using a barrel.
  3. #83
    Super Member JDgreen227's Avatar
    Join Date
    Nov 2003
    Posts
    6,722
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Quote Originally Posted by sdkubota View Post
    Click image for larger version.
Name:	Rear Wt #4.jpg
    While I admire your inventiveness, there have been MANY times I have tried to move a large rock with the FEL on my deere and if I didn't have MFWD there was no way I could move it. Now, about your counterweight...you don't state how often you actually have it on your tractor or for what purpose you use it for. On my tractor the MFWD option adds 300 lbs. of weight and I cannot remove it. HOWEVER, it is ALWAYS available, I don't have to (bleep) around installing or removing it, and best of all I still have the option of installing an implement (blade, plow, disc, etc.) on the rear 3 point. And as far as fuel economy goes, I would rather haul around 300 extra lbs. all the time than 1,000 pounds some of the time, especially when I don't have to waste time installing and removing a rear counterweight.
    Always be willing to admit your shortcomings, there is no shame in not knowing how to do something. The shame is in NOT admitting you don't know how to do it.
    If you have a small truck, limit yourself to small loads, if you want to carry the big stuff, get a big truck.
    Never be ashamed of making a mistake. The only people who never (bleep) up are people who never try to do something new.
  4. #84
    Gold Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    490
    Belleville, MI
    Ford 8N, LS R4047H, Hustler FasTrack Sport ZTR
    Quote Originally Posted by JDgreen227 View Post
    That sort of overlooks the fact that to take full advantage of the FEL you're going to need a counterweight regardless of 2wd or 4wd, so you still wind up hauling extra weight around, and have to mess around removing and installing it with some regularity. Hanging an implement off the back helps, but that's not usually enough weight to truly max the FEL potential.
  5. #85
    Gold Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    331
    North Idaho
    Ford 3000-Rhino 554,Co-Op ,Honda ,Gilson riding mowers
    And if you're going to have a counterweight why not consider a gannon or similar boxblade with top and tilt- right around a 1000lbs. right where you need it and very handy for motorcycle trails, driveways and many other uses...
  6. #86
    Gold Member
    Join Date
    Nov 2012
    Posts
    276
    Perth, ON
    Kioti DK40SE HST Cab, Mechron 2200
    Quote Originally Posted by agsanders View Post
    Thanks, that's what I've kinda been thinking. You can get one of these package deals around here -3032e, box blade, bush hog, FEL - for around $20k. Or the equivalent Kubota. This is mainly a toy for me and I'm not wanting to spend $35k+ on a toy. By the time I got a 4wd utility tractor with its toys, it's well over $30k.
    I've enjoyed reading your thread. I don't normally but into someone elses conversation, but...
    I just traded my 2005 Kioti CK 25 HST w/ 1,188 hrs on a 2012 CK 35 HST (Friday). The dealer gave me (final tally) 87.4% of my original investment in trade. I like the size of this series so I stayed with it.
    The real issue is, that in the 7-8 years I had this tractor, I never had it into the dealer once. It never let me down. The dealer will send you filters and such if you don't ever pass by his door. The $$ issue, saved almost $8,000 over JD eqiuiv.
    As far as accessories, I find used and auction finds are a cheaper way of acquiring the toys I needed (wanted).
    Just sayin...
    Rick
    Kioti DK40SE HST Cab, KL401 FEL, KB 2485 Backhoe, Mechron 2200,
    Land Pride 3572 Rear Blade, Pete 2 Skidder Winch,
    Speeco 3pth Wood Splitter, Meteor SB68 Pull Type Snow Blower
  7. #87
    Gold Member
    Join Date
    Dec 2010
    Posts
    254
    Pocahontas, Arkansas
    John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
    To the op, I have 16 acres of woods and small fields at my residence, I found a good deal on a 4200 4wd hyd. deere. Now, I would like to have a little more horsepower for mowing and bushogging, but pushing, this little rig is pretty good for its size. I had my timber cut off last spring and been using it like a little dozer cutting roads and pushing up what is left of the tops after I cut firewood, it is just a little slower than a bigger machine. You got to treat them like a little kid, little bites at a time instead of big ones. You didnt state whether you had any other property that you may have to haul your tractor to, you have to do much hauling, tractor size is also something to consider, most people dont have the means to safely transport larger equipment safely. That can run up more cost.(Buying a larger trailer, truck to pull said trailer,etc)This may be a non issue for you though. I have rental property, deer hunting property, and family cemetary to keep up, so I haul a lot. Whatever you choose, go with 4wd, large or small.
    4wd makes a small tractor bigger so to speak. If you get 4wd in a large one, well thats just berries. By the way, not pushing John Deere, I looked at Kubota, NH, and Mahindra. I am friends with the salesmen at our NH dealership, where they also sell Mahindra, in a small tractor, they had rather sell you a Mahindra. The same goes for the CIH dealership, they sell Kubota also, and would rather sell you a Kubota in a small tractor. LUTT
  8. #88
    New Member
    Join Date
    Feb 2013
    Posts
    19
    Thomasville, GA
    JD 3032e
    Thanks. I don't really need to transport it anywhere. It will simply stay at the house. I'm gonna go take a look around soon. I was planning to go yesterday, but it was monsoon season here. I have several deere and kubota dealers close by. I also have a mahindra dealer close. By close, I mean 10-15 miles. Kioti is 60 miles away. New holland is 60 miles. LS is 100+ miles. Between kids, work, etc. it's tough to find time for toys.
  9. #89
    Join Date
    Oct 2012
    Posts
    331
    North Idaho
    Been lurking for a long time. First time posting. I have about 15 acres that I need to maintain. All wooded. I would like a tractor for general bush hog work, cutting trials, moving dirt and generally just messing around. No mowing of fields, heavy plowing, etc. The terrain is slightly rolling without any steep hills. Combination of planted pines and virgin hardwoods.
    I've talked to several different people about my needs. Some recommend one of these compact 4wd packages - JD 3032 w/ FEL, box blade, bush hog for instance. Others recommend something like a JD 5045 w/ associated implements. I'm not hung up on deere, just giving examples. We have all the major dealers within a short distance.
    I have spent hours reading threads but I need some help and advice.
    After rereading your original post a couple of things came to mind, The woods have sometimes made me want a smaller tractor because of navigating thru the trees trying not to rip the canopy off on low hanging branches, also I have to clean horse stalls with the loader and its amazing how fast a wall can get pushed out or how big a 40 hp tractor can seem if you do any work in a barn or out building, on the other hand all the other work that Iv'e ended up using a tractor for the most part made me glad to have purchased larger machines than what I thought I needed. Hope this helps
  10. #90
    Join Date
    Nov 2003
    Posts
    6,722
    Central Michigan
    Quote Originally Posted by sd455dan View Post
    sd455dan, what you say brings up something I never even considered prior to buying my deere and I thought I really researched the purchase well...but didn't consider overall height with the ROPS, fortunately the model I chose came with the folding ROPS otherwise it wouldn't have fit into the barn or garage I keep it in. I had a good buddy with a Ford 1520 that I borrowed before buying my tractor and should have realized a machine with a fixed ROPS was over 7 foot clearance. Since I also mow under a lot of trees I am glad my tractor has that feature.
Similar Threads
  1. Buying Advice 2wd or 4wd Kubota? Compact or not?
    By andythomasday in forum Kubota Buying/Pricing
    Last Post: 04-03-2012, 11:18 AM
  2. Traction in snow - 4WD Compact vs 2WD Utility
    By Cowboy3008 in forum Buying/Pricing/Comparisons
    Last Post: 01-29-2011, 05:29 PM
  3. Snow Equipment Owning/Operating Larger 2WD vs Smaller 4WD for plowing snow
    By jedon in forum Snow Removal
    Last Post: 07-06-2008, 08:39 PM
  4. 4WD Compact vs. 2WD Utility
    By timb in forum Owning/Operating
    Last Post: 07-26-2002, 07:31 PM
  5. compact utility or utility tractor
    By Anonymous Poster in forum Buying/Pricing/Comparisons
    Last Post: 06-28-2002, 10:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
