Results 1 to 9 of 9
02-12-2013, 10:21 AM #1New Member
- Join Date
- Feb 2013
- Posts
- 2
- Location
- gopher gulch, Tx.
- Tractor
- 91 Case/IH 895
Need a mowing rig
My Case IH 895 does the plowing tilling etc, however I want to buy a rig just to be a mower. Looking at 8n, 9n, 2000 or 861 in my area and all are around 2500 with a shredder. Any thoughts?
02-12-2013, 12:33 PM #2
02-13-2013, 07:19 PM #3New Member
- Join Date
- Feb 2013
- Posts
- 2
- Location
- gopher gulch, Tx.
- Tractor
- 91 Case/IH 895
Re: Need a mowing rig
It will need to mow 40 acres of brush over some pretty hilly stuff. I was using my Case and a 6ft bush hog. But I need my tractor for other stuff. Most people tell me get an 8n, but I am partial to the diesel
02-13-2013, 08:54 PM #4
02-13-2013, 09:05 PM #5Platinum Member
- Join Date
- Feb 2012
- Posts
- 535
- Location
- Germanton, NC
- Tractor
- Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
The Ford 2000 or Massey Ferguson 135. They have a relatively low center of gravity but have the hp to run a 5 or 6 foot brush cutter and certainly a mower. The Perkins diesel in the 135 would be my choice (have one and love it). We have some steep hills and it works great in low range on the hills.
Like someone said elsewhere we are partial to the tractors that happen to sit in our yards. Your mileage may vary.
02-13-2013, 11:42 PM #6Gold Member
- Join Date
- Dec 2012
- Posts
- 467
- Location
- Belleville, MI
- Tractor
- Ford 8N, LS R4047H, Hustler FasTrack Sport ZTR
I love my 8N, but it's marginal with a 5' brush cutter. The other big issue is lack of a live/independent PTO. I'd lean towards either the 2000 or 861 depending on condition, as both have enough power to get the job done, and have live PTOs.
02-14-2013, 10:29 AM #7Gold Member
- Join Date
- Dec 2010
- Posts
- 254
- Location
- Pocahontas, Arkansas
- Tractor
- John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
I would definetly stay with diesel,for 40 acres you are going to get tired of putting gas in a 8n or any other gas burner. Diesel is safer for bushogging,specially when its dry, exhaust manifolds dont get near as hot, which i am sure you already know this. Like Ted said above, Massy 135 is a good one, I always liked Perkins engines, been around a few on irrigation wells, low center of gravity and weight, that is a good to have when bushogging in the hills. LUTT
02-15-2013, 01:21 AM #8Elite Member
- Join Date
- Feb 2011
- Posts
- 3,804
- Location
- NOT HERE
- Tractor
Stay away from a 9n. They only have a 3 speed trans. A 8n is a 4 speed but not live hydraulics or PTO. I would go with the 2000.
02-15-2013, 06:39 AM #9Gold Member
- Join Date
- Mar 2008
- Posts
- 280
40 acres is a lot, I would stay away from N's. Go with something that can easily LIFT and run a 6ft shredder. Even a 2000 gas can be marginal. Remember, there are early 2000's that are really the same as 600 series and later ones with 3 cyl gas/diesel, not all are live pto. If it's wide open space any old diesel farm tractor will work well, Oliver, Ford, MF, IH, etc, you could go 50hp and up. With a Ford I would want at least a 3000 or 4000. With the N you will be stuck with a 5ft cutter on a marginal tractor doing 40 acres. Even with the old 4cyl Fords I would stick with an 800/801 or 4000, at least you'll have a 172 engine to turn the shredder.
Similar Threads
how to rig up sprayer
By robbyr in forum Parts/RepairsReplies: 3Last Post: 07-21-2011, 01:09 AM -
Is this enough rig?
By teach in forum Trailers & TransportationReplies: 7Last Post: 12-03-2010, 01:47 AM -
My New Rig
By RoadHogg in forum Kubota Buying/PricingReplies: 9Last Post: 10-22-2010, 11:08 PM -
My New Rig
By jshbryan in forum Zetor, Century & BransonReplies: 9Last Post: 07-10-2007, 01:19 AM -
New Rig
By ChrisJ in forum Owning/OperatingReplies: 9Last Post: 05-04-2004, 10:15 PM
