Results 41 to 50 of 98
02-20-2013, 10:04 PM #41New Member
- Join Date
- Sep 2011
- Posts
- 13
- Location
- Altoona, WA
- Tractor
- Kubota BX24
Re: Ford vs chevy vs dodge
Our 94 F-350 crewcab turbo diesel has 250k and is still pulling strong with 16 mpg. A lot of trucks will not pull a heavy load up our steep 1/2 mile long driveway. Our Ford pulls anything. I suspect it is the antislip differentials.
I don't do my own maintenance and my conclusion is that diesel's are more expensive too maintain. Our truck has been rock solid. I was a marine engineer working on navy ships long ago. Our ford reminds me of one of those old navy ships. You just keep fixing them up and upgrading.
02-20-2013, 10:06 PM #42New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Summerfield, NC
- Tractor
- Ford 1500, Kubota 4240, Ingersoll 2014
Ive been looking into the same question for my tow rig, bear with me on the info
Chevy/GMC
06-07 duramax - most of the injector problems were resolved by this point, went to the 6sp allison
01-02 - injectors were mounted under intake, hard/expensive to get to and replace
Ford
97-02 7.3 powerstroke - engines and drivetrains seem to hold up well, latter body style has better steering
Dodge
95-early98 - 12v cummins- basically bulletproof motor, avoid auto trans, front hubs don't hold up well on 4x4
late 98-02 - 24v injector lift pumps dont seem to hold up but motors themselves hold up well, avoid 53 block
Ive only been looking into the trucks before the more stringent emissions in '07 hope this helps
02-20-2013, 10:32 PM #43Silver Member
- Join Date
- Dec 2012
- Posts
- 221
- Location
- Miami, Fl
- Tractor
- Baddest LS P7010C south of Palm Beach County
What the heck is a 53 block.
02-20-2013, 10:38 PM #44New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Summerfield, NC
- Tractor
It was the casting #from the engine block. There have been numerous accounts of these blocks developing a crack over time. Doesn't seem to be a problem for the other castings.
02-20-2013, 11:01 PM #45Silver Member
- Join Date
- Dec 2012
- Posts
- 221
- Location
- Miami, Fl
- Tractor
Where do you find this number.
02-20-2013, 11:05 PM #46Bronze Member
- Join Date
- Dec 2012
- Posts
- 56
- Location
- Western NC
- Tractor
- green
Agree here. We run 7.3 Super Duty's and they are pretty rugged. My personal truck is a 2001 7.3 SRW. I have an exhaust brake installed and a turbo saver timer. I don't think I've done anything to the rotors in over 6 years, the exhaust brake, and a manual transmission help with that. I regularly haul 8-10,000 lb loads of cattle from June-Dec and drive it every day around the farm. They go through ball joints, glow plugs, cam shaft position sensors and other little crap but mostly your turn the key and they run. Sometimes I fantasize about an Allison tranny in it, at the end of a busy day when my knee starts to wear out.
If you can get away with a smaller, cheaper rig then do it. I just bought tires for my truck (Cooper) and they were $730. My farm vet drives a Prius. Stuffs all his gear in there and saves a ton of money over the Dodge Cummins he used to drive.
Between the front ends, extra oil, fuel economy, etc you might look at the new little diesel I think Chevy is coming out with, or a toyota, or some other small truck. Diesel trucks are meant to work hard. I know it is all in perspective, but I'd rather drive my little VW diesel car than anything. It is comfortable, quiet, tight steering, park anywhere; everything my truck isn't. But alas, I am a farmer and can't get the work done with a little sedan. For straight up transportation, a car is the way to go.
JD 5085M *JD 6110 w 640 loader *JD 6330 *AC F2 Gleaner * Ford 7.3 PSD x 2
02-20-2013, 11:10 PM #47
02-21-2013, 06:27 PM #48
02-24-2013, 10:50 AM #49Super Member
- Join Date
- Feb 2008
- Posts
- 7,736
- Location
- somewhere usa
- Tractor
- stuff
I have four Fords because the dealership is better than the other brands in my locale. The 99 F550 and 2002 F350 with the 7.3 engines have worked out well. The 2003 F250 and 2005 F550 with the 6.0 have had more problems for sure. Most of it has been under warranty though and covered by Ford. I would like to buy a couple of new trucks but don't have a warm and fuzzy feeling about any of the new diesels' offered today. I have been waiting to see if any of the manufacturers could come out with a good diesel engine again. It appears to me the EPA is strangling all the manufacturers and won't let up.
I would like to strangle the EPA instead, with a few less restraints all of the top brands could have great engines.
02-24-2013, 11:26 AM #50Gold Member
- Join Date
- Dec 2010
- Posts
- 254
- Location
- Pocahontas, Arkansas
- Tractor
- John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
This is the most sensible statement I have ever heard on this subject, the dealer is why I drive a chevy. There good, local and I like them. I have never been much on buying a truck over in the next county, or state, just over maybe 1500 dollars differance either. I would like to go back to a diesel, and probly will, but the EPA is the biggest hold up on the those trucks. jenkinsph, thanks for the post. Every time these Chevy,Dodge,Ford comes up, they turn into a you know what match. But to me it is more about the dealer, cause if you drive any brand long enough, you will eventually get it worked on for something. LUTT
Similar Threads
Chevy Diesel News & 8-speed Trans. PLUS Ford/Chevy 10 speed Trans.
By BIG DOOLEY in forum Trailers & TransportationReplies: 32Last Post: 12-26-2012, 01:27 PM -
Ford vs Chevy - once and for all
By mwb in forum Trailers & TransportationReplies: 23Last Post: 02-27-2012, 03:43 PM -
Adam's Ford vs Cooper's Chevy
By mjncad in forum Trailers & TransportationReplies: 8Last Post: 01-02-2012, 11:43 AM -
Diesels - Dodge vs Chevy 2500 older models
By michellesc7 in forum Trailers & TransportationReplies: 46Last Post: 06-23-2008, 08:44 PM
