Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Bronze Member Morroder's Avatar
    Join Date
    Jun 2012
    Posts
    53
    Missouri
    None
    Default
    You prefer turnbuckles over other systems?
  2. #12
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: Mahindra 5010 Cab vs Kioti Dk40SE Cab
    Quote Originally Posted by Morroder View Post
    No the Kioti is better it uses adjustable. Just push down and pull out. I will be using a QH so it won't matter much. Mahindra does have a extra year warranty. Compare cabs, that will be the difference.
    Murph
  3. #13
    Platinum Member jpm1's Avatar
    Join Date
    Feb 2008
    Posts
    590
    Panther Lake, Oswego County New York
    Mahindra 2810 HST, Kioti DK35SE HST
    I have both Mahindra and Kioti, without cabs and both are excellent, Mahindra is a little louder than Kioti i guess but it all boils down to #1 cost and #2 comfort. All i can say is drive um and see what hits your spot. Either way you WILL NOT be disapointed. Good Luck in your choice . . .John
    Attached Thumbnails Attached Thumbnails Mahindra 5010 Cab vs Kioti Dk40SE Cab-my-tractors-jpg   Mahindra 5010 Cab vs Kioti Dk40SE Cab-wilie-e-kioti-1-jpg   Mahindra 5010 Cab vs Kioti Dk40SE Cab-my-life-012-jpg
    Lord, Help me to be the man my dog thinks i am . . .John. Mahindra 2810HST, 108H loader with Quick tach buckets and forks. Kioti DK35SE HST with loader, Hyd. top link and second set of rear remotes, 60" and 66" buckets, Kubota 900 RTV and a bunch of other good stuff
    Buy more equipment, It makes life easier.!
  4. #14
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    LS has no dealer network in state to speak of
    Interesting....the website lists 14 dealers in the state, which seems pretty reasonable.
    My dealer sells both Kioti and LS, and when I test drove a DK50SE Cab, he said they wouldn't go below 50hp with a cab, unless it was a special order. He said they just didn't think the 40 or 45hp versions had enough power to deal with the extra weight (when added to counterweights, implement weights, and load weight), power draw to run the A/C, etc to really do a good job. Just something you may want to consider before you buy. R,
  5. #15
    Gold Member
    Join Date
    Feb 2011
    Posts
    297
    Outside of Detroit, MI
    DK50SE Cab
    Default
    I went through the same debate when I bought my tractor: http://www.tractorbynet.com/forums//...d.php?t=237796
    Beyond what I wrote there, I will add that the Kioti 3 point is way nicer than the 5010 and it has a lift control right there which is really helpful when you are setting up your attachments.
    Also, it is worth it to get the 50hp with the HST cab. Just too many things that use those extra HPs.
Similar Threads
  1. New 5010 w/ Cab Owner!!!!!!!!!
    By KrayzKajun in forum Mahindra Owning/Operating
    Last Post: 07-17-2012, 04:26 PM
  2. Comparison Case Maxxfarm 60 Cab or Kioti RX6010C Cab ?
    By MikeFarm in forum Buying/Pricing/Comparisons
    Last Post: 06-02-2012, 06:56 AM
  3. Is a Mahindra 5010 HST Cab the same as a TYM T503 Cab HST?
    By eagle107 in forum Mahindra Buying/Pricing
    Last Post: 12-02-2011, 02:07 AM
  4. 5010 HST/Cab Take a Backhoe?
    By HenRut in forum Mahindra Buying/Pricing
    Last Post: 04-23-2011, 10:09 AM
  5. Kubota L4240 cab or Kioti DK45SE HST cab
    By lsa in forum Buying/Pricing/Comparisons
    Last Post: 01-02-2009, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
