Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Silver Member TractorBob1529's Avatar
    Join Date
    Apr 2009
    Posts
    108
    North Carolina
    MX5100DT
    Default Re: JD 450 Dozer vs Case 450 Dozer
    That's what I though. Worth looking into. I guest I'm back to square one. Better than a 6ft backhoe on a MF1529. Got to keep looking.
    Kubota MX5100DT w/ LA488 Loader
    Kubota KX121-3 w/Thumb
    Ford F8000 Dump Truck
    Land Pride Scrape Blade and Land Plane
    Walenstien BXM42 Chipper
    KK Tiller w/ SpeeCo Quick Hitch
    More upgrades and attachments still to come
  2. #12
    Gold Member
    Join Date
    Mar 2012
    Posts
    378
    NSW Australia
    Tractors16-600hp Farm & Earthmoving Equip, Trucks etc.
    Quote Originally Posted by TractorBob1529 View Post
    Not to change the subject, but I found a JD 450 track loader. I know it don't have the 6-way blade, but I think I can get about the same work done. Should I even consider the track loader instead of a dozer? The loader is an mid 70s, but it's cheaper by almost half. $3500.00 And I miss being in Texas.
    Consider also that a track loader will not push anywhere near as hard as an equivalent sized dozer & is a "lightweight" in ripping tasks, but IMO if your heart's set on a crawler & I could only own one machine I'd personally take a track loader every time over a dozer because of it's extra versatility - as for repair costs it's much the same, whilst in theory the track loader may be marginally higher than a dozer generally it works out about the same (or worse for dozer) because of extra abuse dozers are subjected to.
  3. #13
    Join Date
    Apr 2009
    Posts
    108
    North Carolina
    MX5100DT
    Is there not one machine that does it all and never breaks down? And for cheap too! I can only dream, until then I keep looking and turning wrenches.
  4. #14
    Gold Member
    Join Date
    Mar 2012
    Posts
    378
    NSW Australia
    Yep there's actually two machines like that - it's the one I don't own & the other one's a shovel.....
  5. #15
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,473
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Quote Originally Posted by MBTRAC View Post
    If you have never broken a shovel, then you have never used one in the proper manner.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  6. #16
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,473
    Not to get side tracked, but one of the things that get me is how so many people call tracked machines money pits. If one was to take into consideration of how much work is done with a tracked machine, is it really any more that what a wheeled machine would cost to do the same amount of work? The money pits are the machines that are warn out and on the verge of breakdown. But then doesn't that apply to any machine? I suppose that yes the tracked machine costs more to R&R, but if you take into consideration of how much work has been done by that machine, is it really that costly? I think that they aren't any different than ANYTHING ELSE, if you happen to get it at the end of it's normal life, then it is going to cost you a bunch of money to get it back to good working order.
    Buy a 50 year old house that has had minimal maintenance, you don't just move in and expect to live there for the next 50 years without spending some money.
    Just my
    Brian
  7. #17
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Brian,
    I think it is more a matter of people buying a worn out machine because of the lower initial entry price and thinking they will save money. You are right that a track machine can do alot of work but you have to get one that has some work left in it or be prepared to pay to put the life back in it. You have to be prepared for this either way.
  8. #18
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,473
    Steve, I understand this. I guess I didn't express myself well. If a person buys old worn out anything, they need to expect to put money into it. Yes a warn out tracked machine is going to cost more to put some life back into it than a wheeled machine. No different than buying a 100 year old, 1000 square foot house and a 100 year old, 3000 square foot house. One is going to cost more to rejuvenate than the other. Common sense.
    Sometimes I forget that there are people that don't realize this and that that is why we are here, to help them out.
    Brian
  9. #19
    Member cmbertrand's Avatar
    Join Date
    Feb 2011
    Posts
    34
    03' TC40da NH, 95' JCB 214
    Default
    I just finished...or thought I finished, an early 80's model case 450b. Been in weeds for last 10 yrs or so. Pretty simple little dozer. Had all undercarriage done and few other things. Got about one hour seat time before fuel pump quite working. Gotta jump on that next.
    Attached Thumbnails Attached Thumbnails JD 450 Dozer vs Case 450 Dozer-image-4123022076-jpg
  10. #20
    Gold Member
    Join Date
    Mar 2012
    Posts
    378
    NSW Australia
    Quote Originally Posted by MtnViewRanch View Post
    Just my
    Sure $ for $ in the right application a crawler can't be beaten, $ for $ in the wrong application a crawler is without doubt the most expense way to move material.
    The key factors to operating any crawler economically are:
    - an experienced operator who can make the most out of the machine without over-stressing it
    - limiting travel to the absolute minimum so the tracks only turn if they are productive
    - using a machine right sized for the application
    - owning a "good" machine, that is one that is not beyond economic operation/repair
    There's good reason traxcavators( i.e crawler loaders) are a dying breed, there are progressively less sub D7 sized dozers used in commercial operations & fewer smaller contractors own dozers....for most they no longer make economic sense & as an "aged" machine they're even harder to justify as a cost effective "investment" operating as a "tool of trade" on farms even if you value your seat time @ zero $'s - sure we always know someone who manages through good managment (or pure luck) to save dollar by owning/operating to clear their land, but for every 1 who comes out in front there are at least 10 who end up behind the 8 ball........IMO owning a crawler is akin to an ex wife who just keeps trying to bleed you dry.....
Similar Threads
  1. late 70s case 450 dozer
    By jrobe44 in forum Parts/Repairs
    Last Post: 03-12-2014, 06:09 PM
  2. case 450 dozer question
    By b7200hsd in forum Construction Equipment
    Last Post: 01-27-2013, 12:36 AM
  3. john deere 450 c dozer
    By hatt64 in forum Construction Equipment
    Last Post: 10-11-2012, 09:31 AM
  4. John deere 450 dozer winch
    By RyanL in forum Construction Equipment
    Last Post: 03-06-2012, 02:41 PM
  5. 450 C dozer trouble on incline
    By Thom2 in forum John Deere Owning/Operating
    Last Post: 05-19-2010, 07:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
