Results 11 to 20 of 36
03-13-2013, 07:03 PM #11New Member
- Join Date
- Mar 2013
- Posts
- 23
- Location
- Harrisburg, PA
- Tractor
- n/a
Re: Compact Tractor shopping - some questions
5 acres of yard, 5 acres of pasture. Pastures are not rough and we plan to build some sacrifice areas so they don't destroy the turf when it's fragile.
If I were to do the mowing with the tractor I'd expect to have a quick attach loader and mow without it.
Before we get into the question of what tractor will handle an 800lb square bale, are you saying that the lift rating at full height is not the limiting factor? If that's the case, what is the limiting factor?
As for the 40+ hp tractor and ZTR option, that's not a financial possibility. My budget is 20k, 25k tops, and I was not really expecting to buy new.
03-13-2013, 07:03 PM #12Super Member
- Join Date
- Apr 2000
- Posts
- 5,582
- Location
- Cedartown, Ga and N. Ga mountains
- Tractor
- 1998 Kubota B21, 2005 Kubota L39
Good advice given so far. If it were me I would be looking at loader lift capacity to meet your hay needs as I was comparing tractors. Given how far out an 800 lbs bail will sit a loader in the 1200 lbs lift range might work. If you ever think you might go to round bales you would need more. You are out of the 20 hp tractor range though. The other thing I would consider is how much mower I wanted to run. The general rule for a rough cut mowers is 5 PTO hp per foot of mower. A finish mower generally requires a bit less. A 20hp tractor will generally have around 16 PTO hp and is going to work best with a 4' mower. Five acres is a lot of mowing time with a 4' mower.
I would be looking in the 35 to 40 gross hp range.
MarkV
03-13-2013, 07:04 PM #13Super Member
- Join Date
- Nov 2011
- Posts
- 6,427
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
Zero turn and a Kioti DK 40 SE HST for 2700 lbs of muscle on your loader.
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
03-13-2013, 07:05 PM #14Super Member
- Join Date
- Nov 2011
- Posts
- 6,427
- Location
- Ohio
- Tractor
to TBN
03-13-2013, 07:16 PM #15Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,476
- Location
- north of upstate ny
- Tractor
- Kubota L4240 HST Cab
It is very hard to have one machine to:mow five acres of finish ground,mow another five of rough ground,lift 800lbs and do some snow removal.It can be done but you will have to compromise somewhere.It doesn't look like you have a lot of trees to mow around.My suggestion;L4240 Kubota with FEL,4WD,turf tires ,rear finish mower and bush-hog.Rear scraper blade should handle your snow removal duties.And yes I do own a L4240(600 hrs) and it has been a very good machine.DK40 Kioti,JD 4XXXmachines will have similar capabilities.
03-13-2013, 07:23 PM #16Bronze Member
- Join Date
- Jan 2013
- Posts
- 91
- Location
- St Helens, Tasmania, Australia
- Tractor
- JD 4105 / JD D110
G'day Dave,
I've just been through this process and the advice received by neighbours and the good people of Tractorbynet went a long way to getting my own tractor. I too have a small 6 acre horse property. I went with a John deere due to their local reputation, both in sales and (more importantly) support after you buy. Your neighbours (+ the 'word in the Pub') will have their own bias but generally won't stear you wrong.
If you can, include one of these neighbours when you go to the dealership... they'll be able to nod/shake-their-head at what's offered by the dealer. (hit the dealer up for an extra hat as part of the deal)
You've already put thought towards what you want to initially do with your rig. Good, that's a start. The adage expressed by everyone on this site is (if you can afford it) to get a horsepower one step up from what you reckon you need. I started out thinking about the JD 2720... which, with all of the attachments available, would be able to handle everything I could think of for a small property. At the dealership (with a friend along) we then bumped it up to the 3032E = more power and a larger selection of implements as it was a full Cat 1 Compact Utillity Tractor (CUT). The new CUT's now come in 'automatic' HST, so there's no gear shifting to be done. Everything runs off of a couple of hydraulic systems.
Then the price came up (which you can only see once you're at the dealership) and I was shown that the 4105 was less expensive! Just because it didn't have all of the fancy/pretty things (cruise control, anti-vibration deck, etc...) and it lacked a mid PTO. Mind you, there are a very limited number of implements that attach to a mid PTO. The mower deck is one of them but you can get a perfectly good rear PTO slasher or mower that does the same thing. Don't be dazzled be the goodies on offer, get what you need.
You will need a Front End Loader (FEL). Be warned that this is just the arms and a standard bucket... the implements that attach to it are another expense. I would recommend that your FEL be upgraded to operate a 4in1 bucket. Another FEL attachment you'll need will be a forklift/bale-spike combination. Comments on this site have said that they usually keep this attachment on most of the time!
Tyre wise, I went with the R4. There are turf tyres and a half'n'half tread tyre available. I would discuss this with your dealer.
Definately invest in a chain-harrow to drag your paddocks to work in the horse manure (horses are VERY good at producing manure
). These harrows come in sections that can be added/removed or the whole thing can be flipped over to do a number of different tasks, such as dragging your arena. A rotary tiller for improving your paddocks is a suggestion too.
That's my advice for your initial purchase. You'll get more implements as you need them, but that's for the future.
Best of luck and keep us posted,
Randy
03-13-2013, 07:28 PM #17Veteran Member
- Join Date
- Sep 2007
- Posts
- 1,384
- Location
- Doniphan, Mo.
- Tractor
- Kubota L4240, B7800 & BX2660
I would look real hard at the Kubota GL3540 and the GL3940.. The GL4240 might be just a shade big. Also that would get you in the price range that you want.
03-13-2013, 07:33 PM #18
I think you will be much happier if you get a compact tractor to handle the large jobs and get a good commercial zero turn mower to do the mowing. You can do it all with the compact tractor if you have alot of extra time, but if you want to spend that time on things other than mowing and if the budget allows, get the ZT mower. Look at tractor dealers in your area to find one that fits your needs and for a zero turn, Grasshopper, Gravely, Country Clipper are all very good mowers.Let us know what you end up with.
03-13-2013, 07:37 PM #19New Member
- Join Date
- Mar 2013
- Posts
- 23
- Location
- Harrisburg, PA
- Tractor
- n/a
I have no reservations about maintaining two machines, especially if it's the best solution. I don't automatically buy the idea that a 2-ton tractor is the ideal machine for spending most of my time mowing.
I mentioned the ZTR to manage the trees, fence edges, and buildings with less clumsiness than the tractor. Plus I get to skip rearranging the attachments for mowing. It's not about achieving the manufacturer's maximum ground speed. So that's my uneducated comparison of tractor mower vs. ZTR.
I wasn't entirely clear in my first post - I would like to handle large square bales but it won't make sense if it adds $10k to the equipment investment. $10k buys a lot of small bales, or at least buys me a year to consider adding a skidsteer instead. This is why I was trying to understand the requirements for lifting.
03-13-2013, 10:50 PM #20Veteran Member
- Join Date
- Jan 2010
- Posts
- 1,285
- Location
- Piedmont, NC
- Tractor
- Kubota L4610 & BX2230, Farmall Super M, Super A
Dave, first of all, that's a beautiful place you have. It looks like someone has already put a lot of time and effort into it. It's laid out nicely from what shows on the aerial view. Seems to me you have two major functions to handle: a) upkeep of the property and b) your horse operation.
The upkeep tasks, mowing, driveways, general chores, can be done by any good quality compact tractor. The bigger your equipment, the faster that work can be done, so it's a money vs. time judgement only you can make. And, there's a good case for having a separate mowing unit, particularly since you have so much fenceline, driveways, buildings and landscape that will require trim mowing.
The horse operation is another matter. That horse barn has how many stalls? It looks huge, and if you're eventually going to have the herd to keep it full (what, maybe 20-25 horses?), you'll be dealing with some serious input/output issues (i.e. hay and grain in; manure out). I could easily see a respectable ag utility tractor for bales and a skid steer for manure looking right at home on a place like that. So if all goes well, that may be where you could someday end up, equipment-wise.
But, presuming you're in the "start-up" phase at the moment, it seems you'd at least need one good multi-tasking tractor to get the ball rolling. My vote would be for something big enough to do some serious work, probably something in the 35-40 hp range, or more. The Kubota Grand L's are top-notch, the deere 4000 series likewise and there are other excellent models from Kioti, Massey Ferguson and others, so you have quite a selection.
I think if you go smaller than that, you would be OK for a while, but you'd be back in the market again for bigger equipment as your horse operation grows and matures.
Similar Threads
Shopping for a new tractor
By area123 in forum Buying/Pricing/ComparisonsReplies: 12Last Post: 05-05-2010, 07:51 PM -
Tractor controls and general questions on Mitsubishi compact tractor
By BatCave in forum Mitsubishi/SatohReplies: 4Last Post: 11-10-2009, 12:41 PM -
Price Check TLB shopping...L45 / M59 Price Check and Questions
By ManAtArms in forum Kubota Buying/PricingReplies: 21Last Post: 09-12-2009, 11:12 PM -
Tractor Shopping
By Birdbrain in forum Buying/Pricing/ComparisonsReplies: 27Last Post: 04-13-2008, 04:52 PM -
tractor shopping
By itainme in forum Buying/Pricing/ComparisonsReplies: 13Last Post: 09-02-2003, 10:04 AM
